Separating toddlers from their parents?
by fdcg27
27 minutes 23 seconds ago
gm 8.6 truetrac
by Spitter
32 minutes 17 seconds ago
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
43 minutes 21 seconds ago
Rockauto 5% off
by Spitter
45 minutes 8 seconds ago
fumoto oil valve
by Santo
58 minutes 24 seconds ago
Grand solar minimum...
by ridgerunner
Today at 07:57 PM
Pentofrost coolant $10 Autozone
by PD001
Today at 07:49 PM
The things you find cleaning Garage 30+ btls slob
by digger327
Today at 07:20 PM
Castrol GTX Magantec 0w20 - 6 pack $21.99 - Amazon
by 04SE
Today at 07:07 PM
Havoline Pro DS 5w20 $3.15/quart - Amazon
by 04SE
Today at 07:06 PM
Needing New Dipstick
by Geauxtiger
Today at 05:11 PM
'98 Mercedes E300TD Rotella T5 10W-30 5k miles
by KenO
Today at 04:35 PM
Premium guard oil filters
by Jaha24k
Today at 04:09 PM
76 super motor oil- synthetic blend 5w-30
by Jaha24k
Today at 04:07 PM
Who makes the Mopar 5038041AA filter?
by Quattro Pete
Today at 03:55 PM
Ruger Mini-14, yay or nay?
by 28oz
Today at 03:51 PM
USPS long long delivery to BlackStone Labs
by Pajero
Today at 02:58 PM
House A.c. vent leaking water
by motor_oil_madman
Today at 02:55 PM
"synthetic" gear oil and LS additive?
by nthach
Today at 01:54 PM
Supertech wix ST8 5514 miles
by jakewells
Today at 01:38 PM
Santo, aligoodn, memyself, MichiganKid419, kaphouston
65273 Registered Users
104 registered (addyguy, 2002 Maxima SE, AITG, Aero540T, 2015_PSD, 9050lx, 15 invisible), 1554 Guests and 30 Spiders online.
65273 Members
67 Forums
285622 Topics
#4663047 - 02/11/18 02:49 PM forced crankcase ventalation
red7404 Offline
Loc: KS
would it be a good idea to use a small rotary air pump to suck crank case air out of the crank case. and NOT push air into the intake of the engine. but just dump the crank case air to the atmosphere. and DONT even talk about the environment, I am thinking out loud.
#4663049 - 02/11/18 02:51 PM Re: forced crankcase ventalation [Re: red7404]
Reddy45 Offline
Loc: USA
Why forced though? The old school valve cover breathers worked fine right?
#4663052 - 02/11/18 02:55 PM Re: forced crankcase ventalation [Re: red7404]
dlundblad Offline
Loc: Indiana
I don’t think we’d see a difference because it’d have to be a variable speed thing in tune with the engine. Too much or too little may cause seal failure.
With the “normal” way, you have the increased vacuum as the RPM’s increase.
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4663054 - 02/11/18 02:58 PM Re: forced crankcase ventalation [Re: red7404]
Linctex Offline
Loc: Waco, TX
A properly designed PCV system does exactly this.
#4663062 - 02/11/18 03:02 PM Re: forced crankcase ventalation [Re: red7404]
Linctex Offline
Loc: Waco, TX
Many race cars use a system like this:
#4663065 - 02/11/18 03:03 PM Re: forced crankcase ventalation [Re: red7404]
Trav Offline
Loc: MA, Mittelfranken.de
The movement of the piston does force air through the crankcase one way or another. LOL
#4663078 - 02/11/18 03:09 PM Re: forced crankcase ventalation [Re: red7404]
Olas Offline
Loc: Manchester, England
A rotary pump would work but would also be electrical or mechanical load.
This device http://www.jegs.com/i/Moroso/710/25900/10002/-1 uses waste exhaust energy to perform the same function.
Cable ties should hold it
#4663089 - 02/11/18 03:19 PM Re: forced crankcase ventalation [Re: red7404]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
Yes. I have this on 4 vehicles now, although I do route back to the air intake, via the filter box. Neither air filter or intake tract ever get oily at all.
Crankcase emissions can smell. For some reason, Rotella oil stinks it up the worst by a large margin.
They don't circulate fresh air into the crankcase. I let a little bleed air come in through a filtered inlet, but the system still maintains 9" of vacuum at all times.
Only if the pump is belt driven. I use Ford electric emissions pumps.
It doesn't. When the engine is under the most load, the crankcase gases increase, and the amount of vacuum decreases.
That system works good if you have open headers with no mufflers. Otherwise, the one-way valves pretty much remain closed at all times and the system does not function.
#4663178 - 02/11/18 04:22 PM Re: forced crankcase ventalation [Re: red7404]
CT8 Online   content
Loc: Idaho
Years ago there were vacuum pumps made for the crankcase ,I haven't followed hot rodding for years.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4663196 - 02/11/18 04:42 PM Re: forced crankcase ventalation [Re: red7404]
BrocLuno Offline
Loc: Kalifornia Kollective
Pro-Stock and other classes use vacuum crankcases. Worth maybe 5 HP net at 9,000 RPM. On the street at 2,700 - worth nothing - might even be parasitic ...
#4663296 - 02/11/18 07:30 PM Re: forced crankcase ventalation [Re: red7404]
red7404 Offline
Loc: KS
well OK my friends here have some very good ideas. and some info i didnt know. thanks.
#4663314 - 02/11/18 08:01 PM Re: forced crankcase ventalation [Re: red7404]
NYEngineer Offline
Loc: NY, NY
As stated earlier, race cars do this. There are belt driven and electrically driven vacuum pumps. It's regulated by a valve that controls the amount of leakage back into the engine.
Race guys do it for improved ring seal. In some cases the horsepower increase is fairly significant.
#4663526 - 02/12/18 06:45 AM Re: forced crankcase ventalation [Re: BrocLuno]
Cujet Offline
Loc: Jupiter, Florida
Actually, it depends on the engine design. Pumping crankcase air under and between each cylinder can take significant work. Manufacturers now strive to reduce losses by designing in airflow management.
An inline 4 can have quite a bit more losses than a V8 depending on design.
Evacuating a crankcase is a time tested method to reduce losses. It can be done on a single cylinder engine with just a one way reed valve. Lets the air out, but not back in. The pressure quickly stabilizes at about 1/2 atmosphere.
#4663945 - 02/12/18 01:41 PM Re: forced crankcase ventalation [Re: red7404]
andyd Offline
Loc: Marshfield , MA
OOOh, thats the thingee that fills the carb up with oil when you tip the mower the wrong way. grin2
Edited by andyd (02/12/18 01:42 PM)
Thick oil is better grin2
#4664209 - 02/12/18 06:50 PM Re: forced crankcase ventalation [Re: BrocLuno]
DoubleWasp Offline
In much lesser classes, running 1000HP engines, the gains are 10HP per 1" of vacuum. This has been solidly demonstrated over decades.
