Honda Pilot Oil specs US vs Overseas
by parshisa. 12/17/18 06:23 AM
Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
64 registered members (bigal51, BeerCan, b1amgm47, Best F100, aquartlow, 94astro, 5 invisible), 1,261 guests, and 49 spiders.
Topics295,174
Posts4,929,165
Members66,700
Most Online2,553
Oct 27th, 2018
When are air filters considered dirty? #4659326
02/07/18 05:39 PM
02/07/18 05:39 PM
Pa, USA
NH73 Offline OP
NH73  Offline OP
Pa, USA
When are air filters consider dirty and in need of replacement? Sure the OM says to replace at certain intervals, but most don't have hour meters and some my ZT with hour meter says 1 year or 200 hours, which every comes first. Well after almost 6 years, I hardly have 100 hours.
2017 Toyota RAV4 Hybrid
2004 Ford Explorer Sport Trac
2012 Gravely ZT XL 48 w/ Kawasaki FR730
Re: When are air filters considered dirty? [Re: NH73] #4659331
02/07/18 05:44 PM
02/07/18 05:44 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
If this is a lawn mower then at least yearly. Does it have a foam pre-filter? You can always vacuum it mid season. If you were cutting all nice green grass it might not be a big deal. But if its the middle of the summer with dried grass and dust, then its another story. Leaf time also with a mulching blade will generate lots of dust.
2015 Ford F250 w/Powerstroke
Re: When are air filters considered dirty? [Re: NH73] #4659339
02/07/18 05:54 PM
02/07/18 05:54 PM
Canada
boraticus Offline
boraticus  Offline
Canada
Rule of thumb says that when you hold a paper filter up to the sun or bright light and can't see light through it, it's dirty. When it is dirty, I just blow it out with compressed air. I've done in numerous times and it seems to have worked for me.
Oiled filters usually show a build up or film of dirt on the intake (outside) of the foam. Some oiled filters have two layers a coarse outer layer and a fine inner layer. If the exterior layer is in need of cleaning, chances are that both filters should be cleaned.
If a filter is real dirty, it will cause the engine to run rich and in extreme situations, will cause rough running and black exhaust.
Depending on operating conditions, some filters can last a long time. Cutting grass with little to no dust has little effect on air filters. Dry dusty conditions on the other hand can clog a filter quickly and require often cleaning and likely result in much shorter service life overall.
Re: When are air filters considered dirty? [Re: NH73] #4659373
02/07/18 06:29 PM
02/07/18 06:29 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
It's been my experience that an air filter has to be pretty dirty to cause a restriction. They look terrible but still flow fine.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: When are air filters considered dirty? [Re: NH73] #4659409
02/07/18 06:59 PM
02/07/18 06:59 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
when the restriction gauge that the factory didn't install, but you did, shows too much restriction.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: When are air filters considered dirty? [Re: boraticus] #4659422
02/07/18 07:13 PM
02/07/18 07:13 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
This.
I only replace the element if I see any damage.
Re: When are air filters considered dirty? [Re: E150GT] #4659430
02/07/18 07:25 PM
02/07/18 07:25 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
You've installed restriction gauges on your OPE air filters?
What are your guidelines on say a riding mower / ZTR vs a push mower vs a weedwacker regarding numerical values for too much restriction?
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: When are air filters considered dirty? [Re: NH73] #4659448
02/07/18 07:47 PM
02/07/18 07:47 PM
[email protected] CZ firearm factory
Marco620 Offline
Marco620  Offline
I replace mine every 100k miles. I buy the Injen Nano filter (XX1010)blue and throw a pantyhose layer on top and then my AEM Prefilter. Even when I used AEM Dryflow filter and the cutouts to a buffer pad for prefilter in my intake resonator all my filters stay clean.UOA's show virtually no particles. Been running the Injen Nano / AEM Dryflow types since 2013.
15' Civic R18 200,090k 0w20 Redline/Archoil9200/TEIN/Eibach/Injen/Tanabe Sustec/Borla Exhaust!
Going for 238,900 milestone. My house to moon is 238,900 miles!
Son of a Navy Corpsman. Support veterans!
Re: When are air filters considered dirty? [Re: NH73] #4659592
02/07/18 10:17 PM
02/07/18 10:17 PM
CA
spackard Offline
spackard  Offline
CA
It's harder to tell with a constant-speed engine. With a mower, if you aren't able to mow as much a path as you are used to it's either the blade needs sharpening, the AF needs cleaning/replacement, or the valves need adjusting, if adjustable. In my experience.
Re: When are air filters considered dirty? [Re: NH73] #4659667
02/08/18 04:50 AM
02/08/18 04:50 AM
Detroit
Motorking Offline
Motorking  Offline
Detroit
From an engineering standpoint, they are considered "dirty" when they are restrictive. You can ad a cheap restriction gauge (available at most truck parts stores) to any air cleaner housing on the dirty side
Jay M Buckley
FRAM
(248) 808-4551
Please email filtration questions to the email below for fastest response.
[email protected]
Re: When are air filters considered dirty? [Re: NH73] #4660137
02/08/18 04:27 PM
02/08/18 04:27 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
^^^^ I can't believe this dicussion on installing restriction gauges on OPE air filters has made it to this level of a Technical Training Director of a major filter manufacturer.
Motorking, I'll ask you the same question I asked earlier in this thread.
Re: When are air filters considered dirty? [Re: NH73] #4661647
02/10/18 07:50 AM
02/10/18 07:50 AM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
My Honda gets filled with grass every year. I just blow it out and reuse. I change it every other year.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: When are air filters considered dirty? [Re: NH73] #4661999
02/10/18 01:55 PM
02/10/18 01:55 PM
FL
CharlieJ Offline
CharlieJ  Offline
FL
My mower with a B&S 550e engine has a foam air filter. The mower gets hard to start when the filter is dirty from the air restriction and is acting as a choke. Thatís when I know the filter is dirty and to clean it. Happens once or twice a year.
'07 Mazda3 2.3 Mobil 1 HM 5w-30
'84 Mazda Rx-7 Valvoline Maxlife 10w-30
Re: When are air filters considered dirty? [Re: NH73] #4662100
02/10/18 03:45 PM
02/10/18 03:45 PM
Pa, USA
NH73 Offline OP
NH73  Offline OP
Pa, USA
I decided blow out the air filters this time. They still look a little dirty, but I can see light through them. Also got myself a spark plug gap gauge. They checked good. Don't need to buy air filters and spark plugs. Might as well get as much life out of them as you can.
