Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
128 registered members (14Accent, 86lxjunker, 2015_PSD, 01rangerxl, 17 invisible), 1,948 guests, and 57 spiders.
Topics286,163
Posts4,903,356
Members67,569
Most Online2,967
Mar 10th, 2019
Odd situation - what oil? #4653961
02/02/18 02:40 PM
02/02/18 02:40 PM
IL
mwdoher Offline OP
mwdoher  Offline OP
IL
Hi all! It looks like everyone around here is super supportive - who knew this kind of community existed? I was pointed here by a member at vwvortex. Thanks in advance for helping me out if you're able (or considering it if you're unable!)
I'm in an odd spot; I commute about 2 miles, and don't put really more than 7-8k miles on my car per year. That said, my oil looks disgusting after only a few short months, so I thought I'd reach out here. I have a bit of a rough ride on a cold engine (garage kept at night), and recently had a couple misfires. After new plugs on each cylinder, a gas tank can of sea foam, and a new coil on a misfiring cylinder, the CEL and misfires are gone, but I still have the rough ride so my next stop is the fuel system. I saw the sticky post about how to ask for what I need, so here goes:
1. What kind of vehicle you have - a 2012 Volkswagen Jetta GLI (TSI 2.0T engine)
2. What your owner's manual says -- not just viscosity, but certifications (look for acronyms like API SM, ILSAC GF-4, etc.) and change intervals as well - OM says SAE 5W-40 or SAE 5W-30. VW 504 00, VW 503 00, VW 502 00 specification. Change interval = every 12 months or 10k miles.
3. Where you live - Southwestern suburbs of Chicago
4. How you drive (easy? hard? fast? slow?) - I don't redline, and usually drive about 5 over the speed limit... Long interstate trips are usually 75mph (not often in this vehicle), and locally, I never exceed 45 or so. Not a hard accelerator, but I don't 'dog' it, either.
5. What your daily drive is like (short trips? long trips? city? highway?) 2.5 miles or so each way. It "warms up" but never gets hot.
6. Whether your car has any known problems. None, really, other than what was mentioned in the intro (rough ride on a cold engine). This problem is recent (as of the cold).
Most of my suspicion is that I took the car into an oil change facility (that didn't replace my plug washer with a new one so I had to return for a leak) - and never had a problem prior. I REALLY want to get out whatever is in this engine and replace it with the right stuff. Your recommendation is welcome. Thanks again for considering!
-Matt
(edit = bolded answers to initial inquiries)
Re: Odd situation - what oil? [Re: mwdoher] #4653964
02/02/18 02:43 PM
02/02/18 02:43 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Go to Walmart and pick one of the 3 available 0W-40 oils: Mobil, Pennzoil, or Castrol.
They're all 3 ~ $25/jug.
As for the misfires, due to your usage habits, you're probably due for a walnut blast.
"Zed's dead baby, Zed's dead."
Re: Odd situation - what oil? [Re: rooflessVW] #4653975
02/02/18 02:58 PM
02/02/18 02:58 PM
Eastern Seaboard
Collingwood Offline
Collingwood  Offline
Eastern Seaboard
I have heard of this. Can you run us through the "walnut blast" process?
Re: Odd situation - what oil? [Re: mwdoher] #4653978
02/02/18 03:04 PM
02/02/18 03:04 PM
Displaced Texan in Mexico City
Gimpy1 Offline
Gimpy1  Offline
Short trips where the oil doesn't get up to operating temp are a real killer since moisture doesn't have time to evaporate out. My wife's New Beetle is in the same situation she only drives about 6km each way. Other members may chime in and correct me, but what I did is to change the oil change interval, and change it every 4500 miles or every 6 months which ever comes first. It's usually every six months since I have to go to the US every six months anyway, I just get a gallon jug of the Castrol euro 0w40 at wally world and bring it back with me. You also may want to get a UOA from blackstone to see exactly what is happening to the oil.
Re: Odd situation - what oil? [Re: mwdoher] #4653987
02/02/18 03:18 PM
02/02/18 03:18 PM
South OZ
KL31 Offline
KL31  Offline
South OZ
Oil change facility.... Hmmmm I'd start by never going to those places and replace your own oil asap with one that rooflessvw previously recommend. See how it runs after that and then tackle whatever else could be the issue.
95 MX-3 2.5L|Shell Helix Ultra 5W40|Wix 51356
04 Focus 1.8L|Wesfil Cooper WZ63|Valvoline MST 5W30
05 Kluger 3.3L|Wesfil Cooper WZ418|Magnatec 10W30 Semi Syn
Re: Odd situation - what oil? [Re: rooflessVW] #4653988
02/02/18 03:19 PM
02/02/18 03:19 PM
PA,US
HemiHawk Offline
HemiHawk  Offline
PA,US
This! I have a similar engine in my GTI. The owners manual actually suggests running the engine at high RPM, like 3rd or 4th gear, on the highway for X amount of time (20 minutes??). The idea is to get everything hot enough to burn off junk. I don't plan on doing that, but it does show that the engineers are aware that these engines need to get hot and run to keep in working order.
Sounds like you need a once a week highway run.
2016 Nissan Frontier Pro4x
2017 VW GTI sport
1995 Mustang GTS
Re: Odd situation - what oil? [Re: mwdoher] #4653991
02/02/18 03:27 PM
02/02/18 03:27 PM
South Texas
Insertcoolname Offline
South Texas
I agree with above people.
Pennzoil currently has a $10 rebate / 5 qt jug
This rebate includes the euro formulations bringing
The price down to roughly $13 ish per 5qt jug
When purchased at walmart
Pennzoil platinum euro 0w40 meets ur VW 502 spec
Pennzoil rebate
Theres the link to the rebate.
Also, if you provide your own oil + filter most shops
Will change the oil for labor only if that is an option.
Pepboys will do it around $18 labor only last time i checked.
Good luck!
04 Camry 2az-fe 209k
M1 5w30
PremiumGuard filter
Re: Odd situation - what oil? [Re: mwdoher] #4654003
02/02/18 04:00 PM
02/02/18 04:00 PM
Lakeside, CA
Blkstanger Offline
Blkstanger  Offline
Lakeside, CA
Take it out on the freeway once in a while and blow it out. Cars need to be driven hard once in a while to blow out all the built up carbon and crud.
99 Jeep WJ 4.7 197,000 Maxlife 10w30, Fram Ultra.
Re: Odd situation - what oil? [Re: mwdoher] #4654005
02/02/18 04:01 PM
02/02/18 04:01 PM
IL
mwdoher Offline OP
mwdoher  Offline OP
IL
Thanks for the quick and meaningful feedback, everyone. The money for the oil really isn't a concern for me; the difference between 15 and 35 dollars for high quality oil is a fortune cheaper than the local quick-lube synthetic price gouge - and I just realized today how genuinely simple it is to change on these cars, so I'll be doing it myself. That said, thanks for all the advice. My gas tank is just about empty, so I'll toss some Techron into the tank right before I add my usual V-Power gas, and will burn some time on the expressway at about 3500-4500 RPM (hopefully 25-30 minutes or more, and ideally a couple different times). I then plan to change my own oil and filter right after that tank is empty. All of this seems like stuff that needs to happen regardless. If the bumpy ride prevails after that, I'll look into some local shops that do the walnut blast service as I hear the dealerships like to make a bit of extra cash on the task.
Thanks again, all. I'll keep y'all posted.
Re: Odd situation - what oil? [Re: mwdoher] #4654012
02/02/18 04:07 PM
02/02/18 04:07 PM
PimTac Offline
PimTac  Offline
Those VWs love to run and you should do exactly that. Take the long way home and take longer trips just to keep everything running smooth.
Cannot see signatures any longer so it doesn’t matter.
Re: Odd situation - what oil? [Re: Collingwood] #4654019
02/02/18 04:23 PM
02/02/18 04:23 PM
North Carolina
North Carolina
Intake manifold comes off and a media blaster is used to clean the intake valves.
Cold start misfires and rough running are a symptom of carbon build up. Frequent short trips and quicky-lube changes are the number one cause.
Re: Odd situation - what oil? [Re: rooflessVW] #4654033
02/02/18 04:58 PM
02/02/18 04:58 PM
Oshawa, Ontario Canada
JC1 Online content
JC1  Online Content
Guy at work had that done on an Audi Q5. Cost him $1200 Canadian.
Why would a quick lube oil change cause that problem? Isn't it more of an engine design issue (direct injection) combined with short trips?
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Odd situation - what oil? [Re: mwdoher] #4654049
02/02/18 05:16 PM
02/02/18 05:16 PM
North Carolina
North Carolina
Depends on what a quick lube used. If a Jiffy Lube, they probably used Pennzoil Platinum 5W-40. That's good stuff.
Otherwise, it was probably some generic ILSAC 5W-30 - higher noack, and lower viscosity than what his VW needs. Higher noack means more oil vapor hitting the valves, and a lower viscosity could mean more seepage past valve stems.
Re: Odd situation - what oil? [Re: rooflessVW] #4654053
02/02/18 05:19 PM
02/02/18 05:19 PM
IL
mwdoher Offline OP
mwdoher  Offline OP
IL
I mean, I paid over $100 for the "premium synthetic" at a Pennzoil-branded mom and pop place. I can find the receipt and let you know - at least what's on paper - is in the engine. I feel like it was a Mobil One 5w-40 or something...
Re: Odd situation - what oil? [Re: mwdoher] #4654060
02/02/18 05:28 PM
02/02/18 05:28 PM
North Carolina
North Carolina
It was likely a correct oil. How many miles on the car? Are you the original owner?
I still suspect carbon BU. Cold start misfires are a dead giveaway.
