Hi all! It looks like everyone around here is super supportive - who knew this kind of community existed? I was pointed here by a member at vwvortex. Thanks in advance for helping me out if you're able (or considering it if you're unable!)
I'm in an odd spot; I commute about 2 miles, and don't put really more than 7-8k miles on my car per year. That said, my oil looks disgusting after only a few short months, so I thought I'd reach out here. I have a bit of a rough ride on a cold engine (garage kept at night), and recently had a couple misfires. After new plugs on each cylinder, a gas tank can of sea foam, and a new coil on a misfiring cylinder, the CEL and misfires are gone, but I still have the rough ride so my next stop is the fuel system. I saw the sticky post about how to ask for what I need, so here goes:
1. What kind of vehicle you have - a 2012 Volkswagen Jetta GLI (TSI 2.0T engine)
2. What your owner's manual says -- not just viscosity, but certifications (look for acronyms like API SM, ILSAC GF-4, etc.) and change intervals as well - OM says SAE 5W-40 or SAE 5W-30. VW 504 00, VW 503 00, VW 502 00 specification. Change interval = every 12 months or 10k miles.
3. Where you live - Southwestern suburbs of Chicago
4. How you drive (easy? hard? fast? slow?) - I don't redline, and usually drive about 5 over the speed limit... Long interstate trips are usually 75mph (not often in this vehicle), and locally, I never exceed 45 or so. Not a hard accelerator, but I don't 'dog' it, either.
5. What your daily drive is like (short trips? long trips? city? highway?) 2.5 miles or so each way. It "warms up" but never gets hot.
6. Whether your car has any known problems. None, really, other than what was mentioned in the intro (rough ride on a cold engine). This problem is recent (as of the cold).
Most of my suspicion is that I took the car into an oil change facility (that didn't replace my plug washer with a new one so I had to return for a leak) - and never had a problem prior. I REALLY want to get out whatever is in this engine and replace it with the right stuff. Your recommendation is welcome. Thanks again for considering!
-Matt
(edit = bolded answers to initial inquiries)
-Matt
