Trying to fix chainsaw
by turtlevette
06/23/18 06:48 PM
tire rotation
by marine65
06/23/18 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
Food Safety - If You Have Children
by Zee09
06/23/18 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
06/23/18 05:02 PM
Chain cleaning and lube
by dadinfo
06/23/18 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
mobil 1 rebate check
by Fitter30
06/23/18 03:52 PM
Cab mount failure
by ram_man
06/23/18 03:31 PM
02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
79 registered (2015_PSD, 2004tdigls, Balrog006, asiancivicmaniac, AndyB, 10 invisible), 1470 Guests and 50 Spiders online.
65303 Members
67 Forums
285870 Topics
Page 1 of 3 1 2 3 >
#4653177 - 02/01/18 01:06 PM Has anyone here gone full solar?
HemiHawk Offline
Loc: PA,US
In the beginnings of looking into panels for the house, and a whole setup. It looks like by some calculators that the return would be 7-10 years depending on usage and current rates. Considering usage typically doesn't go down, and rates don't either, it could be sooner.
Right now I have heat pump heat, and oil backup. I assume both of these would still function, but was also reading about ditching the oil backup in favor of electric units. Seems like the total systems wattage would need to be adjusted to account for that though. Right now I go through about $500-$650 a year for the cold weather oil heat.
For those that have made the leap, what downsides have you noticed? If you were to go through the process again, what would you do differently?
2016 Nissan Frontier Pro4x
2017 VW GTI sport
1997 Jeep GC 4.0
#4653210 - 02/01/18 01:50 PM Re: Has anyone here gone full solar? [Re: HemiHawk]
IndyIan Offline
Loc: Ontario, Canada
If you are going off grid you would want to keep the oil or some other backup heating system. Enough solar panels and batteries even to run a heat pump seems like it would expensive in your climate, and winter cloud cover. You don't want all your heating to rely on the sun to be shining even for 1 day out of 4 in winter.
We thought quite hard about going off grid at our place, built in 2004, but it was just to expensive. We still have a propane tank and run a gas stove, and a gas hot water tank for heating,hot water, and would have bought a gas dryer. Running a large freezer though was going to cost like $4k more and getting power to our house went down to $11k, as Hydro1 decided to put in two poles for free on our road, so we went with the grid.
We also had second thoughts on solar after visiting a fellow who had a relatively huge budget for off grid electricity and still was running a generator quite often...
That was 14 years ago though, and prices and technology have changed for the better, so go find someone local who's doing it and talk to them.
If your house runs pretty well passively, with little energy needed you have a chance. If you need to have a forced air fan blowing most of the time or have a sump pump that can run for days at a time in the spring, or after heavy rain. Even a house full of ac-dc power supplies and electronics plugged in 24/7 will cost real money in sizing the system.
07 Focus ZXW, 5spd manual, 206km M1 5W30
18 Outback 2.5 CVT 5km FF
#4653227 - 02/01/18 02:07 PM Re: Has anyone here gone full solar? [Re: HemiHawk]
Shannow Offline
Loc: 'Stralia
Most of the time when the solar is producing, people aren't home to use it, so it goes to the grid.
Then you draw on the grid when everyone gets home from work.
If you want to be "full" solar, you need batteries...and double your payback.
My employer does a system called "redback", which can schedule things like HVAC, washing machine and drier to run while you aren't home. Can be coupled with batteries and time of use meters to reduce daily costs.
I think it's about 3.5Kw panels, 3.5KW batteries and the smarts for $10k Oz.
#4653239 - 02/01/18 02:17 PM Re: Has anyone here gone full solar? [Re: Shannow]
HemiHawk Offline
Loc: PA,US
I was looking into battery solutions (like tesla powerwall), but mostly for low energy appliances in the evening. Things like lights, and TV.
Like Indy mentioned, I don't foresee this being a full "off the grid" solution. As I have AC that needs to run almost all the time (dogs) and sump pump that runs very often after rain.
Setting things to run during the day is a great idea, and will probably help extract more from the system. One benefit I have is there is zero shade over my roof, so that should hopefully help.
2017 VW GTI sport
1997 Jeep GC 4.0
#4653256 - 02/01/18 02:54 PM Re: Has anyone here gone full solar? [Re: HemiHawk]
OVERKILL Offline
Are you going to be doing net metering or is solar subsidized in your area?
2016 Durango Limited
2016 Grand Cherokee SRT
#4653270 - 02/01/18 03:16 PM Re: Has anyone here gone full solar? [Re: HemiHawk]
AZjeff Offline
Loc: PV Az
Having moved to Az from Pa and familiar with how many winter days are overcast it would seem you'd need a lot of panels to be net zero energy through the the dark months.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP *gasp*
16 Silverado 1500 4.3 Ecotec3, DI, AFM 5W-30 PP
Why know when you can guess?!
#4653273 - 02/01/18 03:20 PM Re: Has anyone here gone full solar? [Re: HemiHawk]
UberArchetype Offline
Loc: CO
Adequately sizing the system is important. I suspect most solar contractors and companies assume an optimistic weather profile in their calculations. We installed a max-allowable system here 3 years ago, with satisfactory results, so far. The first year was great, and there was only one month our previously banked kilowatts did not cover, resulting in a small shortfall. IOW, I was only out of pocket for about $50 worth of electricity for the entire year. But the weather was pretty great here all that year, too. Last year was on average, about 20% cloudier overall and it directly translated to electric bills in Jan, Feb and March (the short daylight months).
PA is going be a hit on the weather factor. Go big or stay home.
#4653328 - 02/01/18 04:19 PM Re: Has anyone here gone full solar? [Re: HemiHawk]
Shannow Offline
Loc: 'Stralia
On Oz electricity prices, the powerwall doesn't pay itself back within the 10 year warranty period. (Insurers are getting antsy about Lithium in/near residences too).
We have a bunch of options available in Oz, which includes lead, and Redox flow for domestic applications.
To give an example, a guy at work about 3 years ago built a full self sufficient house with panels, batteries, and nothing coming in (except prolonged bad weather), and it was about $35k.
#4653338 - 02/01/18 04:32 PM Re: Has anyone here gone full solar? [Re: HemiHawk]
madRiver Offline
Loc: New England
Those ROI calculators have the recent adminstration's tariffs in them?
#4653354 - 02/01/18 04:50 PM Re: Has anyone here gone full solar? [Re: HemiHawk]
PandaBear Offline
Loc: Silicon Valley
If I were to do off grid solar with battery for evening use in cold climate, I'd still not take out oil / propane based heating for electric. That's suicidal.
I'd definitely buy a laundry dryer that has a timer and run them during day time on low heat, maybe also a freezer in the garage with a big ice pack, and only run it during day light hours. Those 2 would be the low hanging fruits to reduce battery need.
Edited by PandaBear (02/01/18 04:51 PM)
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#4653364 - 02/01/18 05:04 PM Re: Has anyone here gone full solar? [Re: HemiHawk]
Donald Offline
Loc: Upstate NY
Most people who install solar panels stay on the grid and use it to cover electricity but heat with oil or gas.
If your going to try and use it to heat also with a heat pump it should be a new very efficient one with booster coils. You need to stay on the grid. The booster coils will take enough power there is no way you could power them off grid.
2015 Ford F250 w/Powerstroke
#4653440 - 02/01/18 07:14 PM Re: Has anyone here gone full solar? [Re: HemiHawk]
14Accent Offline
Loc: MN
I have a great roof for solar... and great light exposure.
Unfortunately, in MN, there's no WAY I could ever go off the grid completely. Just too darn cold. Good thing natural gas is still cheap...
However, I could see myself producing enough electricity in a month to cover what I use. I'm almost never here, nor is anyone else, and when I am I use relatively low-energy devices. TV, almost all LED lighting, phone charger, etc. My monthly electric bill is somewhere between $40-$75, and with my perfect sun I could probably start selling electricity back to the power company immediately.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
#4653480 - 02/01/18 08:10 PM Re: Has anyone here gone full solar? [Re: HemiHawk]
Linctex Offline
Loc: Waco, TX
I haven't gone "grid tied" yet, but getting there. I currently do 100% solar in two outbuildings, but it's going to all be integrated over the next couple of years.
"Stand-alone" solar requires some very expensive batteries.
#4653531 - 02/01/18 09:44 PM Re: Has anyone here gone full solar? [Re: HemiHawk]
Snagglefoot Offline
Loc: Alberta
Took a one week solar course at the local college. The prof said, if you are on the grid, stay on it and just net meter. Our power is cheap (8 cents U.S. per kWH), so it takes a long time to pay out the system. 10 to 25 years depending if you do it yourself or pay someone who is doing it for a living.
For off grid, you get a generator, large propane tank, panels, inverter, etc and a battery bank large enough for 3 days of cloudy skies. If itís cloudy for more than 3 days the generator charges up the battery bank and you coast for another 3 days. Repeat as neccesary. The house heat in the winter is a propane furnace or boiler, passive heat and a wood stove. Also propane stove but electric fridge.
Edited by Snagglefoot (02/01/18 09:55 PM)
#4653700 - 02/02/18 07:38 AM Re: Has anyone here gone full solar? [Re: HemiHawk]
raytseng Offline
Loc: CA
There are statements here that are [censored] if you think about it. They are not from the mindset of someone whos offthegrid first, but someone who's lookong to just seamlessly keep their same full consumer lifestyle.
If you're going off the grid and solar you start thinking about every watt. For example, you don't run the dryer midday to save energy, what you do is not run the dryer at all and just line dry or air dry everything.
https://www.amazon.com/Best-Sellers-Home-Kitchen-Clothes-Drying-Racks/zgbs/home-garden/695488011
you dont watch tv at night you read a book or go to sleep.
Put yourself into the mindset of no electricity like you are camping or maybe RV camping with a generator as the baseline, and the solar just gives you back the ammenities you feel are most important. E.g. internet.
If you cant do that, put yourself in the mindset of a second or third world country where you have no electricy. do you think they have dryers or huge freezers? You will need to change your lifestyle to be more simple.
There also exist propane fridges and feeezers, they are not too efficient but the waste heat goes to your house so its not completely wasted. Downsize of course
Edited by raytseng (02/02/18 07:46 AM)
Page 1 of 3 1 2 3 >
