Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
17 registered members (billt460, dlundblad, ctechbob, avi1777, cjolson140, 2 invisible), 549 guests, and 56 spiders.
Topics286,171
Posts4,903,550
Members67,572
Most Online2,967
Mar 10th, 2019
Thicker Oil for Timing Chain Rattle #4650120
01/29/18 01:28 PM
01/29/18 01:28 PM
Atlanta, GA
RoGuE Offline OP
RoGuE  Offline OP
Atlanta, GA
My sisters 2005 Explorer 4.0 V6 has that terrible chain rattle (with only 30k miles on it). It used to only be audible on a cold startup, but now you can hear it all the time so who knows how much longer this thing has. It's come up on a year since it's last oil change using 5w-30 Pennzoil Platinum, probably less than 3k miles (lots of short trips). Would it be beneficial to use a thicker oil to try and quiet it down?
2007 Chevrolet Malibu
2.2L Ecotec
Re: Thicker Oil for Timing Chain Rattle [Re: RoGuE] #4650123
01/29/18 01:31 PM
01/29/18 01:31 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
No.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Thicker Oil for Timing Chain Rattle [Re: RoGuE] #4650125
01/29/18 01:31 PM
01/29/18 01:31 PM
Wisconsin
emmett442 Offline
emmett442  Offline
Wisconsin
If it's as bad as you say, the chain guides are already chunked/broken. Thicker oil won't help a thing.
You'll need to replace the guides.
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
Re: Thicker Oil for Timing Chain Rattle [Re: RoGuE] #4650148
01/29/18 01:46 PM
01/29/18 01:46 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Magnatec 5W20 helped somewhat on my 4.6 2V, but it generally only rattled when it was cold. If it rattles all the time, it may already be too late.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Thicker Oil for Timing Chain Rattle [Re: RoGuE] #4650151
01/29/18 01:48 PM
01/29/18 01:48 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
You can try some High Milage 10w30.
But better to pull the motor and replace the timing components, front and back. If they break it takes the motor with it.
yup
Re: Thicker Oil for Timing Chain Rattle [Re: Jimzz] #4650170
01/29/18 02:02 PM
01/29/18 02:02 PM
Atlanta, GA
RoGuE Offline OP
RoGuE  Offline OP
Atlanta, GA
I don't have the tools, time, or knowledge to do it myself and I priced it around and it is an extremely expensive job, nearly as much as a whole motor replacement. I let her know what could happen but she just can't afford it now. This car has been plagued with issues. Weird electrical issues, HVAC blender issues, computer says change oil all the time even after resetting it, TPMS issues, abysmal fuel economy (our Suburban gets better gas mileage), peeling paint even though it is almost always garaged.
2.2L Ecotec
Re: Thicker Oil for Timing Chain Rattle [Re: RoGuE] #4650190
01/29/18 02:12 PM
01/29/18 02:12 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Well, with broken chain guides and a worn chain throwing timing out of spec, no wonder.
No oil is going to fix the engine.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Thicker Oil for Timing Chain Rattle [Re: RoGuE] #4650192
01/29/18 02:12 PM
01/29/18 02:12 PM
Northeastern Vermont
littleant Offline
littleant  Offline
30k is pretty low milage. There are 2 chain tensioner's (oil pressure fed) they could be plugged. I would change both of them before I did anything with the chains. But first you should drop the oil pan to see if pieces of the chain guides are in the pan. If they are then installing new tensioner's would not help. There are plenty videos online on changing the tensioner's. The engine would have to come out to change all the timing chains. I would not go to a heavier oil. Also that 4.0 is an interference engine and if the chains go when driving bent valves will more then likely occur.
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: Thicker Oil for Timing Chain Rattle [Re: RoGuE] #4650195
01/29/18 02:17 PM
01/29/18 02:17 PM
PimTac Offline
PimTac  Offline
It sounds like she is on borrowed time. If she cannot afford the fix what will she do when the timing chain or the guides decides to go?
Cannot see signatures any longer so it doesn’t matter.
Re: Thicker Oil for Timing Chain Rattle [Re: RoGuE] #4650197
01/29/18 02:19 PM
01/29/18 02:19 PM
Rio Rancho, NM
Pajero Offline
Pajero  Offline
Rio Rancho, NM
Sorry to hear that. She may want to consider trading it in? But, everything is about $$$$$. Only a matter of time.
Good luck!
Respectfully,
Pajero!
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 133,xxx
Fram Ultra/ Snorkel with Pre-filter
K-9-Co-pilot
Re: Thicker Oil for Timing Chain Rattle [Re: RoGuE] #4650201
01/29/18 02:25 PM
01/29/18 02:25 PM
OK, USA
bradtech Offline
bradtech  Offline
OK, USA
Might be a bad ground somewhere(electrical issues).
17 Chevrolet Malibu 3k 5w30 AC Delco Full Syn
08 Hyundai Santa Fe 78k 5w20 GTX HM OEM Filter
93 Chevy S10 203k 10w30 GTX HM ACDELCO PF52E Filter
Re: Thicker Oil for Timing Chain Rattle [Re: Pajero] #4650213
01/29/18 02:29 PM
01/29/18 02:29 PM
Atlanta, GA
RoGuE Offline OP
RoGuE  Offline OP
Atlanta, GA
Is dropping the absolutely necessary or could there be any chunks that would come out the bolt hole?
That's a good question she would have to answer if/when it happens. Probably won't be another Ford.
Good luck!
Respectfully,
Pajero!
Agreed, money is everything. Trade-in could be an option but with maybe a $5k-6k valuation would it be worth it? Who knows, maybe this will keep running for another 10 years rattling away.
2.2L Ecotec
Re: Thicker Oil for Timing Chain Rattle [Re: emmett442] #4650265
01/29/18 03:16 PM
01/29/18 03:16 PM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
++++ We had a 2002 Explorer with the same condition starting at 37,000 miles and the UOA showed huge iron level in the oil along with the tell tale chain rattling sound at around ~2200 rpm, then it got worse. At that time the repair cost was very expensive and the replacement parts were the exact same junky parts that caused the problem initially. Traded it in for a new 2005 Explorer with the 4.6 V-8 which we still have with over 194,000 miles grin.
Whimsey
Re: Thicker Oil for Timing Chain Rattle [Re: RoGuE] #4650279
01/29/18 03:28 PM
01/29/18 03:28 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Use proper oil. Fix chain. Tensioners?
2015 Ford F250 w/Powerstroke
Re: Thicker Oil for Timing Chain Rattle [Re: RoGuE] #4650301
01/29/18 03:56 PM
01/29/18 03:56 PM
littleant Offline
littleant  Offline
Rogue the pieces are most likely larger and would not come out of the drain. The pan should not be that hard to do. At this point I would not drive the vehicle. A little investigation can go a long way. Remember a vehicle with a blown engine is worth a heck of a lot less then a vehicle with a noisy engine. There a people out there (private sale) that can do the repairs for 3-400 dollars. A nice summer project for them.
