Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
Back to Basics II
by MolaKule. 12/14/18 04:31 PM
"SG(+)" 15w40 or better oil 1987 BBC 454
by F239141. 12/14/18 03:52 PM
All Mazda 3’s have bad OCV’s?
by buster. 12/14/18 03:44 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
74 registered members (AndyB, Ag76, 69GTX, 4WD, andyd, 11 invisible), 1,287 guests, and 38 spiders.
Topics295,090
Posts4,927,579
Members66,684
Most Online2,553
Oct 27th, 2018
Getting oil sample when not changing out the oil #4640450
01/19/18 08:22 PM
01/19/18 08:22 PM
Joplin
Cressida Offline OP
Cressida  Offline OP
Joplin
Normally I've always taken my oil sample in the middle of an oil drain when I'm changing the oil. However, I would like to take a sample of oil now without draining it all out.
Is it acceptable to thoroughly clean the oil drain plug area and then loosen the plug enough so that oil is running out and fill my sample bottle that way?
I do not have a pump that I can pump oil out of the dip stick tube and would run the engine a few minutes before getting the sample.
Re: Getting oil sample when not changing out the oil [Re: Cressida] #4640458
01/19/18 08:32 PM
01/19/18 08:32 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
You can get a Wix pump at Napa or on line. Got one off my wish list for Christmas haven't used it yet. Think it was on Amazon for $42.
2004 Corolla 126813
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Getting oil sample when not changing out the oil [Re: Cressida] #4640534
01/19/18 10:53 PM
01/19/18 10:53 PM
CA
CharlieBauer Offline
CA
I have a hand held sampling pump but in retrospect should have gotten a one handed brake bleeder vacuum pump instead.
Can use that for other things more comfortably eg brake bleeding, drain and fills of power steering reservoir, brake fluid reservoir etc.
You want the type where the tube is removable and doesn't touch anything ie just like the oil sampling pump.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Getting oil sample when not changing out the oil [Re: CharlieBauer] #4640590
01/20/18 12:39 AM
01/20/18 12:39 AM
CA
user52165 Offline
user52165  Offline
CA
Another reason to have a Fumoto.
Re: Getting oil sample when not changing out the oil [Re: user52165] #4640622
01/20/18 04:32 AM
01/20/18 04:32 AM
NY
demarpaint Offline
demarpaint  Offline
NY
You still have to dump half the sump to get a good sample. It is recommended a sample be drawn after about half the sump has been drained. So if you're using a Fumoto valve to capture a sample w/o changing the oil you'd still have to dump half the sump to get a "good" sample. IMO you'd be better off sucking out the dipstick tube if you didn't plan on changing the oil.
God Bless Our Troops
Re: Getting oil sample when not changing out the oil [Re: Cressida] #4640640
01/20/18 06:30 AM
01/20/18 06:30 AM
Joplin
Cressida Offline OP
Cressida  Offline OP
Joplin
If I had a pump or means of getting the sample from the dipstick I would have already done so.
Anyone else have a technique for getting a sample from either the filter or oil drain plug when not changing the oil?
Re: Getting oil sample when not changing out the oil [Re: Cressida] #4640644
01/20/18 06:41 AM
01/20/18 06:41 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I've used a small clear vinyl hose snaked down the dipstick tube and siphoned oil out that way. Takes quite a while as it's such a small tube but works great.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Getting oil sample when not changing out the oil [Re: Cressida] #4640646
01/20/18 06:44 AM
01/20/18 06:44 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
Run it for a while so all the oil gets mixed up and loosen the drain plug enough for it to seep into your container.
Tell the sample analysis guys what you did and it'll be fine
Cable ties should hold it
Re: Getting oil sample when not changing out the oil [Re: Olas] #4640834
01/20/18 10:33 AM
01/20/18 10:33 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
...Or just clean your catch pan well....open the drain plug...sample at whatever point you desire....run the plug back in...use a clean funnel and reuse the oil.
Let it all empty. There's no need to "Little Dutch Boy" the flowing oil.
Re: Getting oil sample when not changing out the oil [Re: Olas] #4642410
01/21/18 10:17 PM
01/21/18 10:17 PM
Joplin
Cressida Offline OP
Cressida  Offline OP
Joplin
I did it this way and it seemed top work pretty well. I did get the little Dutch Boy effect.
Thanks for all the suggestions.
