Toslink optical audio cable (plastic) experience
by ffhdriver. 09/20/18 11:30 AM
A woman I work with wants an affair with me!
by Drew99GT. 09/20/18 11:08 AM
ACEA A5/B5 REQUIREMENTS
by Kjmack. 09/20/18 10:56 AM
Carolina Reaper hot peppers
by gman2304. 09/20/18 09:54 AM
New Fram air filter?
by irv. 09/20/18 09:15 AM
Any golf cart experts?
by HawkeyeScott. 09/20/18 09:15 AM
EU Subaru 2.5 FB engine oil
by IMPALA08. 09/20/18 08:16 AM
02 Focus head replacement
by Eric Smith. 09/20/18 08:08 AM
A5/B5 or A3/B3
by ka9mnx. 09/20/18 07:53 AM
2018 Mazda 3 2.5 Castrol or Mazda Moly
by mazdamonky. 09/20/18 07:44 AM
What fuel are you running?
by Matagonka. 09/20/18 07:25 AM
Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
108 registered members (Aero540T, 2004tdigls, ABomb369, 2013ecof150, 9 invisible), 1,690 guests, and 42 spiders.
Topics290,710
Posts4,848,776
Members66,021
Most Online3,590
Jan 24th, 2017
traction in 2wd pickup #4640260
01/19/18 06:17 PM
01/19/18 06:17 PM
Ceciltucky Maryland
Oldtom Offline OP
Oldtom  Offline OP
Ceciltucky Maryland
I have a 2WD Toyota pickup which has very little traction on slippery surfaces. I get a tremendous amount of wheel spin in reverse trying to back up on a slick surface, but I can sometimes ease up a slippery slope in first gear. Why is there so much difference in wheel spin between first and reverse, since all other factors are equal?
Thanks in advance for any advice.
Re: traction in 2wd pickup [Re: Oldtom] #4640262
01/19/18 06:21 PM
01/19/18 06:21 PM
South Carolina
eyeofthetiger Offline
South Carolina
Accelerating in reverse transfers weight off the rear and towards the front.
You should look into a limited slip, detroit locker, or mini spool, depending on your preferences and budget. I went with the mini spool in my truck because I don't care about shredding tires.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: traction in 2wd pickup [Re: Oldtom] #4640275
01/19/18 06:36 PM
01/19/18 06:36 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Before you look into a traction aiding device for your differential you should add weight to the bed and use good tires designed for the task, real snow tires. I've driven lots and lots of miles in a 2wd truck in the winter in the Upper Peninsula of Michigan, in fact I made it through a 300+ inch snowfall winter with all season tires on all 4 corners and nothing more than 5 70# sand sausages in the bed of a 1988 2wd 4 speed Toyota truck. Get weight, if it still doesn't help enough, get tires. Then and only then should you look into adding a limited slip.
Luke
Re: traction in 2wd pickup [Re: eyeofthetiger] #4640276
01/19/18 06:36 PM
01/19/18 06:36 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
The Detroit in the rear of my truck shreds tires too.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: traction in 2wd pickup [Re: Oldtom] #4640283
01/19/18 06:42 PM
01/19/18 06:42 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Or sell the 2WD and get a 4WD.
If you want the job done right......do it yourself.
Re: traction in 2wd pickup [Re: Oldtom] #4640288
01/19/18 06:47 PM
01/19/18 06:47 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
500 pounds of weight and a set of studded snow tires would work wonders. That's what's on & in the GMC in my sig, it hasn't got stuck yet. Or spend several grand on a posi & keep the junky all seasons-you'll be disappointed, and poorer.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: traction in 2wd pickup [Re: FlyNavyP3] #4640290
01/19/18 06:50 PM
01/19/18 06:50 PM
wv
krismoriah72 Offline
wv
What he said..
My father rarely missed a day of work due to bad roads using this formula.
Studded tires or deep tread winter tires..and a few hundred pounds in the bed across the axle were his formula in a 70s model C10 3 speed on the column.
Re: traction in 2wd pickup [Re: Chris142] #4640291
01/19/18 06:52 PM
01/19/18 06:52 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
My cousin had a 80's toyota 4x4 pickup with a detroit in the back and it was evil in the snow.... Even in 4wd it made turning left in an intersection not very predictable in the snow.
Get some good narrowish snow tires and some weight in the back and the truck will drive much better.
07 Focus ZXW, 5spd manual, 210km M1 5W30
18 Outback 2.5 CVT 10km 0W20 "bulk subaru" whatever that is
Re: traction in 2wd pickup [Re: IndyIan] #4640298
01/19/18 07:00 PM
01/19/18 07:00 PM
South Carolina
South Carolina
I drove a 2wd pickup with a detroit locker in Michigan winters and it was almost unstoppable. The tail likes to slide around a little bit, but letting off the throttle straightens it right out (results may vary with a manual transmission).
Re: traction in 2wd pickup [Re: eyeofthetiger] #4640308
01/19/18 07:11 PM
01/19/18 07:11 PM
iowa
Traction Offline
Traction  Offline
iowa
Well a mini-spool is about the worst thing to EVER, EVER use in a street vehicle, period. And a locker is not far behind. Tire choice, and weight distribution would be the first thing to do for addressing a traction issue.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: traction in 2wd pickup [Re: Oldtom] #4640315
01/19/18 07:15 PM
01/19/18 07:15 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Thank you for the review of Detroit locker. The only LSDs I've had are BMWs. They are a definite improvement over an open diff in snow.
Driving on dry roads isn't a trouble if you use Lube with a friction modifier
Get some good narrowish snow tires and some weight in the back and the truck will drive much better. A D handled flat shovel is useful for parking and taking off some times too.
Thick oil is better grin2
Re: traction in 2wd pickup [Re: Oldtom] #4640337
01/19/18 07:39 PM
01/19/18 07:39 PM
Ceciltucky Maryland
Oldtom Offline OP
Oldtom  Offline OP
Ceciltucky Maryland
Thanks for the info. I am going to get a spare set of rims with studded snows. I have enough junk lying around for ballast :-)
Re: traction in 2wd pickup [Re: Oldtom] #4640405
01/19/18 08:41 PM
01/19/18 08:41 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
300 lbs of concrete pavers is what I use.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: traction in 2wd pickup [Re: Oldtom] #4640462
01/19/18 09:35 PM
01/19/18 09:35 PM
Oneida County, NY
rsylvstr Offline
rsylvstr  Offline
Oneida County, NY
And with all that weight, you start sliding and now you have momentum that you canít stop.
And most people donít secure their weight ballast enough. Get in a bad accident and the junk becomes a missle or bunch of middles.
2013 F150 SCrew Lariat 4X4 5.0 3.55
2012 Altima SL that still vibrates.
2018 Polaris Sportsman 850 SP. Polaris fluids and filter.
Re: traction in 2wd pickup [Re: Oldtom] #4640464
01/19/18 09:37 PM
01/19/18 09:37 PM
North Carolina
4ever4d Offline
4ever4d  Offline
North Carolina
I have found that an empty plastic drum lying on it's side and strapped very well then filled with water works very well. The drum is light enough to lift in and out but after filling is plenty of weight. Just drain the water after bad weather is over and good to go.
04 Chevy Colorado 3.5 I5 5w-30 OEF
07 Honda Element 2.4 I4 5w-20 OEM
10 Nissan Rogue AWD 2.5 I4 5w-30 OEF
Amsoil Products & Fram or Wix Filters
