Have owned this car (01 echo) for a bit over one year now (good highway beater), currently at 228,000kms (142k miles). Unsure of the service history prior so did a couple short OCI's but she seems pretty clean. Ran this XG4967 for two OCI's first one just 5,000km (~3k miles) took it off and inspected it and used it again for another 8,100kms (~5k miles) total time in service was about 13 months.
Tried out this exhaust pipe cutter for the first time, harder than I thought it should be to get in there... Any damage to the can or end caps is from still having to force it out a bit.
Unsure when or if ever the PCV valve was done, threw a new one on. It hadn't used a drop of oil until the last 2k kms, then used quarter of a quart.
Also put a magnetic drain plug on for the second OCI, some particles, but nothing significant.
Oil used was mostly Mobil1 EP 5w30, with a bit of Castrol Edge 5w30. Small Sump, always have leftovers in the jugs.
Didn't exactly use any of the oils or filter to their full potential, but now that I know there are no issues I am hoping to start running 2 10,000km OCIs on one XG4967 (still well under the 32,000km allowance).
