Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
Flow How: PourPoint warmer than CCV "0w" Temperature 0w20
by oil_film_movies. 03/25/19 05:31 PM
Oil filter material list?
by shibby6600. 03/25/19 04:49 PM
Insights on commission paying jobs?
by Pat in Speedway. 03/25/19 04:29 PM
Decode a vehicle VIN for production Month & Year?
by Ed_Flecko. 03/25/19 04:29 PM
Wix 51522 vs Fram XG9837
by RDY4WAR. 03/25/19 04:13 PM
Rural King: 20K Lumen LED Tripod Worklight $34.93
by skyactiv. 03/25/19 03:55 PM
How do I find out which Honda Engine?
by Gebo. 03/25/19 03:08 PM
Moltex increases their footprint, hiring
by OVERKILL. 03/25/19 02:53 PM
Rislone complete fuel system gas treatment
by Fitter30. 03/25/19 02:29 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
122 registered members (77GrandPrix, agpatel, Aero540T, anndel, Andya, ammolab, 11 invisible), 2,070 guests, and 65 spiders.
Topics286,425
Posts4,908,062
Members67,622
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Timing belt broke. Interference Engine. Screwed? #4631713
01/11/18 06:59 PM
01/11/18 06:59 PM
Detroit
Kurtatron Offline OP
Detroit
Not my car. Coworkerís car. 2004 Saturn L300 V6. The V6 is an interference engine. The engine just cut out while driving down city roads. Coworker had it towed to a shop. Mechanic said at first the problem was just the serpentine belt. I found that odd. I donít think a serpentine belt would cause a car to die suddenly while driving.
2 weeks later the mechanic tells my coworker the timing belt looks bad also. So he is going to replace that. The mechanic acknowledges the engine is an interference engine, but says he cannot verify if the engine is destroyed until he replaces the timing belt so he can check for compression. Does that seem right? Could the engine have survived really if the timing belt broke or maybe just slipped? Is there no way to verify the engineís condition without installing a new timing belt?
Re: Timing belt broke. Interference Engine. Screwed? [Re: Kurtatron] #4631718
01/11/18 07:06 PM
01/11/18 07:06 PM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Well, IDK if there is a way to check that the valve(s) haven't clashed with the piston(s) without removing the head(s). However, I do know of instances where the timing belt has snapped on interference engines and all was OK.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Timing belt broke. Interference Engine. Screwed? [Re: Kurtatron] #4631722
01/11/18 07:12 PM
01/11/18 07:12 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Sounds right to me. There is a slight possibility itís ok though. My mechanic once had an Xterra come in with a broken timing belt (interference engine) and it ran fine after a replacement.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Timing belt broke. Interference Engine. Screwed? [Re: Char Baby] #4631726
01/11/18 07:13 PM
01/11/18 07:13 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Sure-a compression test will show any bent valves. But, when in doubt, change the timing belt, don't ask me how I know!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Timing belt broke. Interference Engine. Screwed? [Re: Kurtatron] #4631729
01/11/18 07:14 PM
01/11/18 07:14 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Luck of the draw on an interference engine. If it won't turn over then you'd know it's messed up, but if it turns over and seems OK, then it would have to get a timing belt on it to do a compression and/or leak down test.
Re: Timing belt broke. Interference Engine. Screwed? [Re: Kurtatron] #4631736
01/11/18 07:20 PM
01/11/18 07:20 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
put a scope down spark plug holes.
takes almost no time and might show severe issues.
honestly its probably junk and not worth fixing 80+% of the time.
Re: Timing belt broke. Interference Engine. Screwed? [Re: Kurtatron] #4631746
01/11/18 07:31 PM
01/11/18 07:31 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Bore Scope each plug hole and look ...
Re: Timing belt broke. Interference Engine. Screwed? [Re: Kurtatron] #4631749
01/11/18 07:33 PM
01/11/18 07:33 PM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
In case if a timing belt jump, it can damage valves. Had an instant with 7th Gen Civic, now breaking a timing belt means definitely valves are bent, possibly quiet a few.
If it's not turning over while cranking, definitely (some valves) or head needs to be be replaced. We took the route of a re-manufactured/machined head, it was rather cheap option.
Good luck.
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Timing belt broke. Interference Engine. Screwed? [Re: Kurtatron] #4631750
01/11/18 07:34 PM
01/11/18 07:34 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
Yeah there are cheap chineses borescopes out there for $9.99 nowadays. This mechanic sounds like a chump, but I'm only hearing the story, what, thirdhand?
Re: Timing belt broke. Interference Engine. Screwed? [Re: Kurtatron] #4631764
01/11/18 07:40 PM
01/11/18 07:40 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
If your coworker gets real lucky, a timing belt might fix things.
If not, then the engine is screwed and it would be time either to junk the car or look for a replacement engine from a yard, on which the shop should of course do a timing belt replacement prior to installing it.
Whether an old Saturn would be worth this depends upon the car.
If it's trashed, then just trash it. If it's well cared for and pretty nice, then it might well be worth a used engine install.
Your post shows why timing belt engines must have the required service done.
Do this and you'll have no problems, while if you don't, you may.
This also poses a bit of a dilemma when buying a used car. Has the belt been changed as required or not?
A buyer often has no service documentation available, although a hunt through the glove box or spare tire well will sometimes yield a trove of receipts.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: Timing belt broke. Interference Engine. Screwed? [Re: BrocLuno] #4631766
01/11/18 07:42 PM
01/11/18 07:42 PM
wv
krismoriah72 Offline
wv
In those engines the ac compressor can lock up causing the serpentine to lock and can shear the timing belt. Basically the mechanic at this point has a blank check in his hand...it could be alot of things.
I am sure that after it happened the driver cranked and cranked to restart..if it did fail then the damage is done. Top end and possibly some pistons depending on the extent.
Re: Timing belt broke. Interference Engine. Screwed? [Re: Kurtatron] #4631773
01/11/18 07:45 PM
01/11/18 07:45 PM
New England
madRiver Online content
madRiver  Online Content
New England
This is a $1500 car at best, I would not put much money into this abomination Saturn made out of an Opel.
Re: Timing belt broke. Interference Engine. Screwed? [Re: Kurtatron] #4631793
01/11/18 08:10 PM
01/11/18 08:10 PM
Fort Worth, Texas
clinebarger Online content
clinebarger  Online Content
Fort Worth, Texas
I thought all the L300's were crushed by now, That engine was a real POS!!
2001 Chevy Camaro L92/4L80E
Re: Timing belt broke. Interference Engine. Screwed? [Re: Kurtatron] #4631798
01/11/18 08:16 PM
01/11/18 08:16 PM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
Ah yes, the same POS L81 engine that moved the Catera, a few Saabs, and the Vue before the Honda J series engines came into play
They're real fragile, especially with bending valves
Unless he adores the car, and has free labor, I think it's gmae over for this one
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: Timing belt broke. Interference Engine. Screwed? [Re: Kurtatron] #4631802
01/11/18 08:24 PM
01/11/18 08:24 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
That car uses the awful Saab motor. Many of them did not even make it to 60k on the original timing parts.
As said unless they love the car to death just dump it now. It bends valves very easily so I doubt its ok.
yup
Page 1 of 3 1 2 3
