What would you do...
by Bailes1992. 03/19/19 05:28 AM
'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
49 registered members (Bailes1992, 87sammy, billt460, alcyon, Black_Thunder, bcossa2001, 4 invisible), 669 guests, and 52 spiders.
Topics286,049
Posts4,901,492
Members67,551
Most Online2,967
Mar 10th, 2019
1985 Dodge Ram 225 Slant 6 Rotella T4 2600k #4629568
01/09/18 07:00 PM
01/09/18 07:00 PM
AL
Backwoods41695 Offline OP
AL
Hi, guys. Here's my second UOA on the Dodge. Surprisingly insolubles went way down this time. This engine is kind of dirty inside from sitting for so many years. So I've been doing short intervals to clean it out. Let me know what you guys think!
2007 Ford F-150 5.4L 3V
Motorcraft Synth Blend 5W-20
1985 Dodge Ram D100 225 Slant 6
Shell Rotella T4 15W-40
Re: 1985 Dodge Ram 225 Slant 6 Rotella T4 2600k [Re: Backwoods41695] #4629575
01/09/18 07:06 PM
01/09/18 07:06 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
I think it looks great. Keep on using the Rotella 15w40 and thanks for posting smile
Re: 1985 Dodge Ram 225 Slant 6 Rotella T4 2600k [Re: Backwoods41695] #4629631
01/09/18 07:46 PM
01/09/18 07:46 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
Nice UOA from this old dear.
I would imagine that these things typically shed metal at rates that would make a Honda owner blanch, and Blackstone seems to agree.
Also, kudos to you for being unafraid to use a grade that suits your climate.
These things probably called for 10W-30 but a 15W-40 HDEO is fine for the temperatures that you see.
From a cleaning point of view, though, this oil has only a normal PCMO dose of calcium and but a smidge of mag.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: 1985 Dodge Ram 225 Slant 6 Rotella T4 2600k [Re: Backwoods41695] #4629633
01/09/18 07:47 PM
01/09/18 07:47 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
The slant 6 was all the way up until 1985?
Definitely a tough engine...
Re: 1985 Dodge Ram 225 Slant 6 Rotella T4 2600k [Re: Backwoods41695] #4629663
01/09/18 08:11 PM
01/09/18 08:11 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Use some Engine Oil Flush at the end of your next short OCI. CRC, Motor Medic, etc available at Walmart. Just pour it in a warm/hot engine, idle it for 5 mins or so. Drain out, etc...works like magic. smile
Re: 1985 Dodge Ram 225 Slant 6 Rotella T4 2600k [Re: Backwoods41695] #4629710
01/09/18 08:34 PM
01/09/18 08:34 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
I'd run a can of BG109 for the last 100 miles and then change. It'll clean nicely and it's not there for the whole OCI smile
Re: 1985 Dodge Ram 225 Slant 6 Rotella T4 2600k [Re: Linctex] #4629815
01/09/18 10:16 PM
01/09/18 10:16 PM
SD
zrxkawboy Offline
zrxkawboy  Offline
SD
'87, actually
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: 1985 Dodge Ram 225 Slant 6 Rotella T4 2600k [Re: Backwoods41695] #4629872
01/09/18 11:36 PM
01/09/18 11:36 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Metal wear rate is good.
OCI could be extended to 5k or more.
Re: 1985 Dodge Ram 225 Slant 6 Rotella T4 2600k [Re: Backwoods41695] #4630031
01/10/18 08:11 AM
01/10/18 08:11 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
I suspect that the higher metals in the first UOA are from long-term corrosion from inactivity.
The insoluble count will also include some of the muck/stuff that's getting flushed out; hence the improvement.
These two relatively short OCIs are flushing out the old stuff.
I expect it will settle even a bit further with use, presuming the use continues in a more normal fashion and does not sit for long periods.
The FP is a tad low and fuel a tad high; probably due to carb'd engine. No harm; just an observation.
If you're going to operate it with reasonable consistency, then I'd agree longer OCIs can be done; try 5k miles next time.
These old slant-six engines are incredibly hard to kill; they just keep running and running and running and ...
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 1985 Dodge Ram 225 Slant 6 Rotella T4 2600k [Re: dnewton3] #4630295
01/10/18 11:54 AM
01/10/18 11:54 AM
AL
AL
Thanks for the replies, everyone! I think the fuel dilution and low FP may be related to how long I warm up the engine on cold mornings. When I start it, I let it run a good 15 minutes to let the cab get toasty on the inside and all that time with the choke on is probably to blame.
Now that the insolubles have taken a dive for the better, I'll start extending my intervals longer now. I honestly never thought my wear numbers would be this good on this truck, but I'm glad I was wrong.
Re: 1985 Dodge Ram 225 Slant 6 Rotella T4 2600k [Re: Backwoods41695] #4630512
01/10/18 02:35 PM
01/10/18 02:35 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Good results out of this leaning tower of power.
Re: 1985 Dodge Ram 225 Slant 6 Rotella T4 2600k [Re: zrxkawboy] #4630823
01/10/18 08:16 PM
01/10/18 08:16 PM
Rabbit Creek, Alaska
jayg Offline
jayg  Offline
'87, actually
On trucks in Mexico through 91 I think
2018 Ford Ecosport AWD- Napa 0w20
2017 Ram 1500 Ecodiesel- CP Triton ECT 5w40
1973 Datsun 240Z 10w30- VWC from '73
1973 Triumph Bonneville 750- M1 5w50
1967 BSA 441 Victor Special- M1 5w50
Re: 1985 Dodge Ram 225 Slant 6 Rotella T4 2600k [Re: 53' Stude] #4631105
01/11/18 08:08 AM
01/11/18 08:08 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Exactly, report looks good, low iron wear metals, keep using the Rotella T4 15W40.
I like the old slant six engines.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: 1985 Dodge Ram 225 Slant 6 Rotella T4 2600k [Re: Backwoods41695] #4634044
01/13/18 10:21 PM
01/13/18 10:21 PM
Watertown, New York
cronk Online content
cronk  Online Content
Watertown, New York
My parents had a 1985 Dodge truck with a slant 6 as well. It was the farm truck. A 2wd "Prospector" edition, with a 4 speed standard shift.
It was a pretty tough truck. What I learned to drive stick on!
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: 1985 Dodge Ram 225 Slant 6 Rotella T4 2600k [Re: cronk] #4634080
01/13/18 11:13 PM
01/13/18 11:13 PM
AL
AL
These engines definitely are tough. This one is the D100 "Custom" with a TorqueFlite automatic. It was my Grandad's old truck. I put it on the highway at 75 quite a bit with no issues. Gonna run her till she quits! If that happens, I'll be rebuilding the engine.
