Let's Talk Bed Pillows
by LoneRanger
06/20/18 09:21 AM
Changed Speedo Gear on 700r4 Tailshaft
by Pike51
06/20/18 09:20 AM
Which do you prefer: ZL-1 Camaro or GS Corvette ?
by Mr Nice
06/20/18 08:41 AM
CVT Discussion
by Sierra048
06/20/18 08:28 AM
Can't get Unifi AP V2 to work on TDS...
by WhizkidTN
06/20/18 07:34 AM
Need mini grease gun
by Duffyjr
06/20/18 07:02 AM
Mazda 6 O2 sensor - CA emission
by Chester11
06/20/18 06:57 AM
Brake Bleeder
by supton
06/20/18 06:56 AM
As close to blowing out as you can get
by wwillson
06/20/18 06:04 AM
changing tranny filter
by Dennisistheman
06/20/18 06:04 AM
From small things...
by Silk
06/20/18 05:57 AM
Anyone signing up for the Space Force
by Shannow
06/20/18 03:58 AM
Pennzoil Platinum at Walmart
by TheLawnRanger
06/19/18 11:21 PM
Mopar OEM and Fram Ultra Oil filters, '18 Jeep JL
by IndyFan
06/19/18 10:45 PM
What’s the odds..
by Eric Smith
06/19/18 09:51 PM
Who can relate?
by Reddy45
06/19/18 09:43 PM
No more oil changes
by goodtimes
06/19/18 09:19 PM
Separating toddlers from their parents?
by fdcg27
06/19/18 08:50 PM
gm 8.6 truetrac
by Spitter
06/19/18 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
06/19/18 08:34 PM
Theraven, battleman13, Shassis, Santo, aligoodn
65276 Registered Users
87 registered (853okg, 28oz, 9050lx, 2015_PSD, 2009Edge, 330indy, 10 invisible), 1531 Guests and 29 Spiders online.
65276 Members
67 Forums
285641 Topics
Page 1 of 2 1 2 >
#4626521 - 01/06/18 11:40 PM 2005 GMC Diesel 2500 Truck- no start
WyrTwister Offline
Loc: Texas
This truck belongs to one of my cousins .
Month or two ago , the truck acted up , low on power & would not exceed 65 mph . Next start , ran fine .
We were visiting last weekend . It repeated the same symptoms . Both to & from a ~ 50 mile round trip , with one off - on cycle .
A few days latter & crank - no start . My cousin changed the fuel filter & used the manual pump to fill the filter & burp the air from it .
Suggestions , please . We have been searching you tube videos .
Thanks , :-)
Wyr
God bless
#4626543 - 01/07/18 12:57 AM Re: 2005 GMC Diesel 2500 Truck- no start [Re: WyrTwister]
Rolla07 Offline
Loc: MTL, CANADA
No codes?
Guessing here but...fuel pump?
Edited by Rolla07 (01/07/18 12:58 AM)
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
#4626556 - 01/07/18 02:06 AM Re: 2005 GMC Diesel 2500 Truck- no start [Re: WyrTwister]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
That truck has no fuel pump but the high pressure pump itself. Sucks it out of a pumpless tank.
Big question is, when he pumped it up, did he bleed the fuel out through the on-engine bleeder?
That thing needs a computer scan like nobody's business.
Those symptoms leading to a no-start make me first thing of fuel. Secondly, a close second, they make me think of a dead FICM. Not unheard of.
In the middle of the two is chafing of the FICM harness where it passes over that metal bracket near the alternator.
Start by making sure it was pumped up and bled from the engine mounted bleed, then see if it starts. If it doesn't, scan the computer and see what it has to say. That particular engine generally throws a bunch of codes when something that catastrophic goes on.
#4626604 - 01/07/18 06:02 AM Re: 2005 GMC Diesel 2500 Truck- no start [Re: WyrTwister]
WyrTwister Offline
Loc: Texas
He said the check engine lite is not on . I guessed scanning for codes would not yeald any information ?
Thanks , :-)
Wyr
God bless
#4626662 - 01/07/18 08:10 AM Re: 2005 GMC Diesel 2500 Truck- no start [Re: WyrTwister]
64bawagon Offline
Loc: Michigan
Its likely an LLY duramax if its an 05. If it did in fact go into a reduced power scenario then it has a code in it. Thats the first place to start. Everything other than that is just a WAG. If its fuel related my first move would be to rebuild or replace the fuel filter head, start with the cheap and easy stuff.
How many miles are on it and does it have any tuners ?
Edited by 64bawagon (01/07/18 08:11 AM)
05 Duramax Chevy(SOLD), 64 Chevy wagon, 10 Jeep Wrangler, 17 Equinox (rental), 18 Silverado 1/2 ton
#4626699 - 01/07/18 08:57 AM Re: 2005 GMC Diesel 2500 Truck- no start [Re: WyrTwister]
Audios Offline
Loc: Lyndhurst NJ
On my TDI, ive problems with the anti shudder valve sticking closed or partially closed, so this starves the engine of air, or will not allow it to start. I just had to clean it all out at the entrance to the manifold, no problems since.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2005 BMW M3 BMW Twin Power 10/60
1998 BMW M3/4/5 Fuchs 5/40
2007 Mercedes GL320 CDI Fuchs 5/40 GT Pro XTL
#4626845 - 01/07/18 11:45 AM Re: 2005 GMC Diesel 2500 Truck- no start [Re: WyrTwister]
DNVDMAX Offline
Loc: Richmond, VA
Mine had similar symptoms from a collapsed plastic fuel line under the truck and a fuel filter head (housing/mount) that was leaking air. No fuel leaks were visible as it is under suction and not pressure. The o rings in the filter head were not holding a prime in the fuel system. Oreillys had the filter head rebuild kit for ~$22.
06 GMC 2500HD DMAX EFILIVE M1 TDT 5w-40 FRAM Ultra
91 GMC K1500 5.7L 5w-30 Quaker State HM Bosch D+
72 Nova 350 SBC 74mm AirWerks Turbo 15w-40 HDEO
#4626874 - 01/07/18 12:03 PM Re: 2005 GMC Diesel 2500 Truck- no start [Re: WyrTwister]
DNVDMAX Offline
Loc: Richmond, VA
First part of this video goes through the filter head rebuild. I hope this is all it is.
#4626886 - 01/07/18 12:10 PM Re: 2005 GMC Diesel 2500 Truck- no start [Re: WyrTwister]
DoubleWasp Offline
Only makes sense to go there if the engine will start on a full manual prime. If it won't, filter head is not the problem.
#4627315 - 01/07/18 06:44 PM Re: 2005 GMC Diesel 2500 Truck- no start [Re: WyrTwister]
WyrTwister Offline
Loc: Texas
I am passing all this along to my cousin .
Thanks , :-)
Wyr
God bless
#4628875 - 01/09/18 03:35 AM Re: 2005 GMC Diesel 2500 Truck- no start [Re: WyrTwister]
WyrTwister Offline
Loc: Texas
Received an email from my cousin . He said he charged the batteries for 4 hours & got it to start . Let it run for 5 minutes , shut it off & it restarted .
His brother recommended a local mechanic & the mechanic told him it sounded like the fuel pressure regulator or pressure sensor .
My cousin is going to try to drive the truck to the mechanic , tomorrow . With his brother following , in case it quits again .
So , we will see what we will see . Wish him luck .
Wyr
God bless
#4639943 - 01/19/18 01:16 PM Re: 2005 GMC Diesel 2500 Truck- no start [Re: WyrTwister]
WyrTwister Offline
Loc: Texas
A little update . I suppose the truck has been running since my last report .
On the warmer days , he changed oil / filter . Then took it to the mechanic . No codes & the mechanic did not fine any thing wrong / broken .
So , my cousin just called . He was taking the truck home . For now , he says the truck is running fine .
I feel for him . His situation , now is kind of like walking around with no belt . Your pants could drop to the ground at any time . :-(
Thanks for the information , :-)
Wyr
God bless
#4643806 - 01/23/18 08:48 AM Re: 2005 GMC Diesel 2500 Truck- no start [Re: WyrTwister]
WyrTwister Offline
Loc: Texas
Far as I know the truck is still running .
A complete novice here , but I was wondering , does this model truck have an electric fuel shut off solenoid ? If so , could it be partially sticking ?
I was also wondering about a fuel additive , to avoid / correct anything sticking ?
Thanks , :-)
Wyr
God bless
#4644527 - 01/23/18 10:10 PM Re: 2005 GMC Diesel 2500 Truck- no start [Re: WyrTwister]
clinebarger Offline
Loc: Fort Worth, Texas
Originally Posted By: WyrTwister
I was wondering , does this model truck have an electric fuel shut off solenoid ? If so , could it be partially sticking.
It does not, Common Rail Diesels do not need a fuel shut off solenoid.
2001 Chevy Camaro L92/4L80E
2010 Toyota Corolla 2ZR-FE/Auto
#4644547 - 01/23/18 11:01 PM Re: 2005 GMC Diesel 2500 Truck- no start [Re: WyrTwister]
WyrTwister Offline
Loc: Texas
Hmmmm . Interesting .
Is that because each injector is fired individually / electrically / electronically ?
Thanks , :-)
Wyr
God bless
Page 1 of 2 1 2 >
