Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
98 registered members (69Torino, AdditiveOCD, 2006dodge2500, ArrestMeRedZ, Astro14, alarmguy, 7 invisible), 2,012 guests, and 56 spiders.
Topics286,388
Posts4,907,391
Members67,614
Most Online2,967
Mar 10th, 2019
Cold weather P/S fluid in an older Ford?? #4625822
01/06/18 12:31 PM
01/06/18 12:31 PM
Cincinnati, OH, USA
bullwinkle Offline OP
Cincinnati, OH, USA
The power steering on the '03 MGM in my sig absolutely HATES below 0F weather, making noise for at least the first 5 miles when started in subzero temps. It was originally spec'ed for Dexron/Mercon in the P/S system-would there be any harm in using full syn Dex VI in it? Anybody tried it??
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Cold weather P/S fluid in an older Ford?? [Re: bullwinkle] #4625850
01/06/18 12:57 PM
01/06/18 12:57 PM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
I've had excellent luck with Maxlife ATF in my Taurus
I've had similar success in Windstar/Escort/Explorer
However, panther bodies seem to always have a certain sound to them (PS pump whine or diff whine)
I'd try the two line flush method with a gallon bottle of Maxlife and see where it gets you
Make sure to fully bleed it, there is a special adapter for the reservoir if you can't
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: Cold weather P/S fluid in an older Ford?? [Re: bullwinkle] #4625852
01/06/18 12:58 PM
01/06/18 12:58 PM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
Before that I would recommend doing the Turkey Baster trick to remove the old fluid ( 3 times) and try out Mercon V which is backwards compatible with Mercon. Im sure others are going to tell you other non OEM solutions as well.
SF
If you want the job done right......do it yourself.
Re: Cold weather P/S fluid in an older Ford?? [Re: bullwinkle] #4625874
01/06/18 01:13 PM
01/06/18 01:13 PM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
Add a bottle of this stuff; has fixed any and all power steering issues I've ever had.
Lubegard
Re: Cold weather P/S fluid in an older Ford?? [Re: bullwinkle] #4625885
01/06/18 01:21 PM
01/06/18 01:21 PM
UT
BHopkins Offline
BHopkins  Offline
UT
For cold weather applications where Dexron III ATF is recommended for p/s fluid, I would recommend either Mobil 1 ATF or Valvoline Maxlife ATF. I would advise against using Castrol Transmax Dex/Merc. Both Mobil 1 and Maxlife have very low pour points and viscosity at -40C. But the Castrol ATF fluid isn't suited well for cold weather.
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/68D5435223A1FD148025814500665523/$File/BPXE-ANM933.pdf
https://www.mobil.com/english-us/pas...-synthetic-atf
https://sharena21.springcm.com/Publi...0-ac162d889bd3
2013 Subaru Outback 2.5i - Idemitsu 0W-20 & Mobil 1 filter
2007 Mercedes SL550 - M1M 5W-40 & MB OEM filter
Re: Cold weather P/S fluid in an older Ford?? [Re: bullwinkle] #4626022
01/06/18 03:01 PM
01/06/18 03:01 PM
wi
dave123 Offline
dave123  Offline
wi
M1 ATF my Ford's hated cold loved the M1
Re: Cold weather P/S fluid in an older Ford?? [Re: dave123] #4626042
01/06/18 03:30 PM
01/06/18 03:30 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
+2 on the maxlife ATF.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Cold weather P/S fluid in an older Ford?? [Re: bullwinkle] #4626065
01/06/18 03:48 PM
01/06/18 03:48 PM
Pittsburgh PA
1maniac Offline
1maniac  Offline
Pittsburgh PA
I have had some good luck with both the M1 ATF and with LubeGard who makes a P/S fluid and P/S additive that work excellent in cold-noisy FORDs.
Re: Cold weather P/S fluid in an older Ford?? [Re: bullwinkle] #4628917
01/09/18 07:24 AM
01/09/18 07:24 AM
Cincinnati, OH, USA
Cincinnati, OH, USA
Well, after reading as much as I could find (including an interesting post from Molakule about it), I bit the bullet and flushed it with 2 quarts of ST Dexron VI. So far it seems better, now to wait for the bone chilling temps to come back and I'll know if it worked. Old fluid wasn't burnt, but not very red either.
Re: Cold weather P/S fluid in an older Ford?? [Re: bullwinkle] #4635835
01/15/18 03:23 PM
01/15/18 03:23 PM
Connecticut
Sam_Julier Offline
Sam_Julier  Offline
Connecticut
I run Mobil 1 ATF in the 240 wagon and Mercon V ATF and Power Steering fluid in the 240 sedan. Same pump and steering rack. Both have had many < 0 degree starts and a couple of < -15 degree starts in Stove VT. No squealing in either unit during start up. I can't tell any difference while driving either. The Mercon V is $21/gallon at the local Ford dealer. The Mobil 1 ATF almost twice that price. I'll be using the Mercon V in both cars shortly.
Sam
2013 Toyota Avalon Hybrid TGMO 0W20, 68k
1993 Volvo 245 T5 10W30, 153k
1993 Volvo 244 PP 10W30, 166k
Re: Cold weather P/S fluid in an older Ford?? [Re: bullwinkle] #4636194
01/15/18 10:06 PM
01/15/18 10:06 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
I've been using M1 ATF in my Ford PS pumps for nearly 30 years including my 1996 Merc GM and they always perform well in very cold temps. I just turkey baster the fluid every 10K engine OCI. In your case I would do several quick changes to help the process along.
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Cold weather P/S fluid in an older Ford?? [Re: bullwinkle] #4637737
01/17/18 02:23 PM
01/17/18 02:23 PM
Cincinnati, OH, USA
Cincinnati, OH, USA
Well, happy to report the Dex VI was a night & day difference over the Mercon, just pulled the return line out of the reservoir, plugged the hose fitting, aimed it into a 2 liter bottle, dumped 2 quarts of full syn ST Dex VI in & ran it through. Now it doesn't howl & screech the first 3-4 miles when it's 5F or below. I never thought about Mercon V, but I'm not sure it's necessarily a full synthetic.
Re: Cold weather P/S fluid in an older Ford?? [Re: bullwinkle] #4637892
01/17/18 05:28 PM
01/17/18 05:28 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
I'm glad it worked out. I'd suspect it would work well, but every company is a little different. The G37 calls for specifically Dexron-VI ATF as power steering fluid (or Nissan OEM ATF or PSF), but the Dexron-VI is listed all over the place. In the previous iteration, they called for the previous Dexron, and I highly doubt they redesigned the power steering pump for Dexron-VI for the subsequent model year.
Plain, simple Garak.
Re: Cold weather P/S fluid in an older Ford?? [Re: bullwinkle] #4642482
01/22/18 02:36 AM
01/22/18 02:36 AM
Dallas TX
MetalSlug Offline
MetalSlug  Offline
Dallas TX
I also use max life on all my ford power steering pump. Im pretty much use max life as Mercon V
NO FRAM OCOD " Orange Can Of DEATH �
03 SVT COBRA 10th anniversary Whipple 600whp M1 5w30 Wix 51372XP
01 Corvette ZO6 stock M1 5w30 / M1-107A
2016 NISSAN TITAN dealer OC daily drive
