Post your euro cars high mileage
by Serge. 09/23/18 09:08 AM
Post your cars high mileage
by Serge. 09/23/18 09:01 AM
Post your latest mileage achievement
by Snagglefoot. 09/23/18 08:23 AM
Field repair by the Mississippi!
by Number_35. 09/23/18 08:18 AM
F150 5.0 Lost power
by hatt. 09/23/18 08:15 AM
Mobil @ Bomgaars sale
by Duffyjr. 09/23/18 04:45 AM
More California BS!
by dogememe. 09/23/18 04:04 AM
Optimum No Rinse Wash and Wax or Shine?
by anndel. 09/23/18 03:44 AM
Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
78 registered members (08z06, 2004tdigls, 77GrandPrix, 2015_PSD, advocate, 2013ecof150, 4 invisible), 1,607 guests, and 36 spiders.
Topics290,876
Posts4,851,733
Members66,047
Most Online3,590
Jan 24th, 2017
Slow acceleration - carb versus engine? #4624934
01/05/18 02:05 PM
01/05/18 02:05 PM
CA
ArtDecoWorld Offline OP
CA
I went to look at a 1980 Tercel the other day. Having had them before, this one felt slower to accelerate/less power.
One can't start pulling things apart when looking at a vehicle. So, is there a way to help differentiate whether something like this is more likely to be a carb/fuel issue, or a worn engine?
Thanks
Re: Slow acceleration - carb versus engine? [Re: ArtDecoWorld] #4624943
01/05/18 02:15 PM
01/05/18 02:15 PM
Soviet State of Washington
PimTac Online content
PimTac  Online Content
A compression test will give you an idea of what shape the engine is in. How many miles on this car?
Could be fuel, valves, so many things. Itís a 38 year old vehicle.
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
Re: Slow acceleration - carb versus engine? [Re: PimTac] #4624945
01/05/18 02:16 PM
01/05/18 02:16 PM
CA
CA
True. But no way I can do that at this guy's house. Miles are 162k.
Re: Slow acceleration - carb versus engine? [Re: ArtDecoWorld] #4624955
01/05/18 02:25 PM
01/05/18 02:25 PM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
1980s cars in general were slow to accelerate. I've owned a few. I swear the econoboxes did not need an accelerator, just an on/off switch.
The bane of most cars from the 80s was the vacuuum lines. They would get old and brittle, allowing for vacuum leaks. The car would run somewhat sick.
Re: Slow acceleration - carb versus engine? [Re: ArtDecoWorld] #4624959
01/05/18 02:33 PM
01/05/18 02:33 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
As mentioned could be lots of things. My 1st thought is timing or a stretched throttle cable.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Slow acceleration - carb versus engine? [Re: ArtDecoWorld] #4624976
01/05/18 02:47 PM
01/05/18 02:47 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Compression test takes 10 min. Should be easy to do at the guys house.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Slow acceleration - carb versus engine? [Re: ArtDecoWorld] #4625105
01/05/18 04:39 PM
01/05/18 04:39 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
At this age anything can be wrong, along with the other things mentioned in the thread look at the vacuum advance on the distributor. At 37 years old (if original) its very likely the rubber diaphragm has failed.
IIRC this one has a few hoses going to it.
Re: Slow acceleration - carb versus engine? [Re: ArtDecoWorld] #4625150
01/05/18 05:31 PM
01/05/18 05:31 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Id check for rust underneath. Is it burning oil when running? Any leaks? Any reason you are considering a 1980 Tercel?!
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Slow acceleration - carb versus engine? [Re: ArtDecoWorld] #4625159
01/05/18 05:37 PM
01/05/18 05:37 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
80's "smog motors" suffered from:
1) low compression ratios,
2) small head ports,
3) very lazy cam timing,
4) lazy ignition timing, and
5) lean mixtures.
Welcome the 90's when cars actually started to have some performance along with economy.
