Is 0W weight oil the perfect oil?
by Baas95. 09/19/18 08:01 AM
2014 Durango ZF8 transmission fluid recommendation
by MoparMan12. 09/19/18 06:45 AM
Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
86 registered members (2004tdigls, 16HC, A310, ABomb369, 4WD, 8 invisible), 1,446 guests, and 40 spiders.
Topics290,629
Posts4,847,702
Members66,011
Most Online3,590
Jan 24th, 2017
Page 1 of 4 1 2 3 4
PAO properties compared to GTL? (Pennz PUP) #4622877
01/03/18 04:33 PM
01/03/18 04:33 PM
Waco, TX
Linctex Offline OP
Linctex  Offline OP
Waco, TX
I sure do learn a lot from y'all - - I love the technical discussions.
I'm curious:
After this thread (Mobil 1 AnnProt primarily 0w-20 based thread)
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4622850/
I would like to know:
How does primarily PAO-based 0W-20 or 5w-20 (Mobil 1 EP or AP?) oil properties compared to GTL? (Pennz P.U.P. 0W-20 or 5w-20)
There's a lot to consider....HTHS, NOACK, etc. etc.....
I know it's impossible to determine anti-wear additive recipes, etc. etc. etc....
I'm not really concerned about "everyday, light-duty commuter work".
I wonder how they would do in "extreme/severe duty" (very high piston ring temps, for example)
Any thoughts?
Re: PAO properties compared to GTL? (Pennz PUP) [Re: Linctex] #4622905
01/03/18 05:03 PM
01/03/18 05:03 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
I think the GTL compares very well to PAO, but no finished oil formulation today contains ONLY PAO or GTL or Group III, or Group II.
I wish people would understand this and get off this "one base oil" only mentality.
Reading is fundamental; understanding is not a given ability.
Re: PAO properties compared to GTL? (Pennz PUP) [Re: Linctex] #4622937
01/03/18 05:43 PM
01/03/18 05:43 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
I'm to dumb to play a 2 base stringed instrument smirk
OTOH - it seems to be an uphill battle to get folks to see that ALL oils short of jet engine lubes are a blend that includes dino. The "Synthetic" guys just don't get that they have a significant percentage of dino as a carrier for the add pak coffee
Re: PAO properties compared to GTL? (Pennz PUP) [Re: BrocLuno] #4622957
01/03/18 06:10 PM
01/03/18 06:10 PM
Jupiter, Florida
Cujet Online content
Cujet  Online Content
Jupiter, Florida
And yet conventional oil continues to result in stuck piston rings, clogged oil ring drain holes, coked turbo and oil lines, along with the associated varnish and sludge.
The quality synthetics avoid all of this.
Re: PAO properties compared to GTL? (Pennz PUP) [Re: Linctex] #4622980
01/03/18 06:32 PM
01/03/18 06:32 PM
new jersey
hemitruck Offline
hemitruck  Offline
new jersey
I thought the base was a highly refined Dino base as compared to reg conventional!.
Re: PAO properties compared to GTL? (Pennz PUP) [Re: MolaKule] #4623005
01/03/18 06:58 PM
01/03/18 06:58 PM
Waco, TX
Linctex Offline OP
Linctex  Offline OP
Waco, TX
I really wasn't trying to insinuate this...
I did use the word "based" hoping no one would assume I referring to 100% make-up.
I'm curious to know which properties are comparable/similar between the two,
...and which properties seem to be opposite of each other (if that's even possible)
Re: PAO properties compared to GTL? (Pennz PUP) [Re: MolaKule] #4623007
01/03/18 07:01 PM
01/03/18 07:01 PM
Waco, TX
Linctex Offline OP
Linctex  Offline OP
Waco, TX
I think for the sake of a scientific discussion,
I'd like to know some of the "deeper" characteristics & parameters of each type of blending stock...
...rather than all the other "relatively generic" info that gets parroted repeatedly through the threads.
Re: PAO properties compared to GTL? (Pennz PUP) [Re: Linctex] #4623075
01/03/18 08:19 PM
01/03/18 08:19 PM
Texas, Mentone for work, Galve...
Bryanccfshr Offline
Bryanccfshr  Offline
This article goes into a little comparison.
http://www.infineuminsight.com/insight/sep-2014/uncertainty-ahead-for-base-stocks
An Intersting point, the automotive demand for low viscosity basestock is straining the supply chain of PAO. GTL production at the time of publication was not high enough to close that gap.
GTL seems to have similar but more controlled NOACK volatility over PAO
GTL and grp III+ Seem to outperform PAO in viscosity index while
PAO has an advantage in pour point.
In a fully formulated oil this is all a bunch of hokey, the whole is greater than the sum of individual parts.
2018 Trd Pro 4Runner M1 0w40
2018 Tacoma off-road Castrol 5w30 Magnatec
Re: PAO properties compared to GTL? (Pennz PUP) [Re: Bryanccfshr] #4623150
01/03/18 09:57 PM
01/03/18 09:57 PM
USA
Sylvatica Offline
Sylvatica  Offline
USA
Originally Posted By: Bryanccfshr
Interesting article, thanks.
Re: PAO properties compared to GTL? (Pennz PUP) [Re: Bryanccfshr] #4623155
01/03/18 10:08 PM
01/03/18 10:08 PM
Waco, TX
Linctex Offline OP
Linctex  Offline OP
Waco, TX
An interesting point, the automotive demand for low viscosity basestock is straining the supply chain of PAO.
.....and it's been several years now. I just first heard of GTL for the first time maybe 2 years ago.
Hypothetical:
Let's say you are a chemical engineer and a CLS. (R.I.P. George)
You get hired by say..... Ashland oil, and your new job is to develop a synthetic oil product
that will be marketed as a peer against Pennz Ultra Platinum and Mobil 1 Extended Performance
(I chose these two as they seem to be exceedingly popular. Sorry Castrol fans).
You can choose any basestocks and additives you wish to choose - - Including PAO and GTL.
Here's the hard answer - they are both so good, what would you choose to blend with, and why?
Re: PAO properties compared to GTL? (Pennz PUP) [Re: Linctex] #4623157
01/03/18 10:12 PM
01/03/18 10:12 PM
BrocLuno Offline
BrocLuno  Offline
With the supposed test being Ashland - I think we have the answer in Synpower laugh
Re: PAO properties compared to GTL? (Pennz PUP) [Re: Cujet] #4623167
01/03/18 10:18 PM
01/03/18 10:18 PM
BrocLuno Offline
BrocLuno  Offline
See here's the problem I have with that premise. We have coked turbos - really with correctly configured drains? How about all the millions of OTR trucks with turbos running cherry red on good old dino HDEO with OCI at 20,000 miles ... Clogged oil ring drains, seems to be related to some makes and to a world of Jiffy Lube oil changes. Are you sure that would have happened on a premium dino, or just bulk oil ...
There are obviously good dinos (Delo, Delvac, etc.) and bad dinos. There are good synthetics and I'm sure there are bad ones too. Up to the operator to buy the appropriate oil. Just the synthetic is not going to protect anyone ...
Re: PAO properties compared to GTL? (Pennz PUP) [Re: BrocLuno] #4623191
01/03/18 10:39 PM
01/03/18 10:39 PM
Waco, TX
Linctex Offline OP
Linctex  Offline OP
Waco, TX
It's just the first name that popped in my head wink
Re: PAO properties compared to GTL? (Pennz PUP) [Re: Linctex] #4623232
01/03/18 11:10 PM
01/03/18 11:10 PM
Bryanccfshr Offline
Bryanccfshr  Offline
Hypothetical:
You left budget out of the question. Competitive pricing for a performance standard is the name of the game. A developer can always over engineer a product a machine or a building for the targeted performance target.
Being able to meet the performance target in a budget range is more financially rewarding than developing the best possible oil ever. Itís easy to develo0 the best ever, not many people are willing to pay for the cost differential in the final,
Product that would be marginally different (most likely unmeasurable or noticeable tothe consumer) than a more cost competitive product.
If my career was on the line I would design a product to compete on production cost as well as performance.
The best possible product is probably out there..but does it provide a material difference to performance that you would be willing to pay for?
For most applicationsm I would bet people would say no. And most those who would agree to pay more for absolute best, donít actually require it but have personal reasons.
Re: PAO properties compared to GTL? (Pennz PUP) [Re: Linctex] #4623234
01/03/18 11:14 PM
01/03/18 11:14 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
Hypothetical:
Ashland no longer has any ownership interest in petroleum refining and lubricating oils.
Marathon purchased Ashland's interest in the Marathon Ashland JV last decade. Marathon Petroleum sold the former Ashland St. Paul Park refinery, which is now owned by Andeavor after passing through a few owners. Marathon Petroleum still owns the former Ashland refineries at Catlettsburg, KY & Canton, OH. Only these 3 Ashland refineries were still operating in 1998 when the Marathon Ashland JV was formed; Ashland had 8 refineries at one point in time prior to that.
Ashland spun Valvoline off as a wholly seperate entity a few years ago.
Ashland specified Ashland wished to focus on less capital intensive businesses.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Page 1 of 4 1 2 3 4
