Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
not sure what spark plugs to buy now
by MrTruckDriver. 03/19/19 11:33 AM
Tires on a Lease Return
by clarkflower. 03/19/19 11:25 AM
Auto-Rx now available on Amazon
by LarryD. 03/19/19 11:14 AM
Best place to advertise used car for sale?
by Ed_Flecko. 03/19/19 10:51 AM
A little help with a 2010 Santa Fe
by nicholas. 03/19/19 10:50 AM
Lawn Mower Battery - What's Up with That?
by Astro_Guy. 03/19/19 10:34 AM
This makes me sick
by SLO_Town. 03/19/19 10:32 AM
Slanderous Fram Orange Can Review
by doitmyself. 03/19/19 08:39 AM
MRV of PP EURO 0W40 an anomaly?
by 21Rouge. 03/19/19 08:39 AM
The Beater is Even Uglier Now!
by Delta. 03/19/19 08:28 AM
Oil viscosities at 200 to 225 F
by Snagglefoot. 03/19/19 07:35 AM
What would you do...
by Bailes1992. 03/19/19 05:28 AM
'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
jmd, alexislaborda, tbann, LisaMC, chops
67556 Registered Users
106 registered members (28oz, 2010Civic, AdditiveOCD, 53' Stude, 12 invisible), 2,182 guests, and 57 spiders.
Topics286,068
Posts4,901,960
Members67,556
Most Online2,967
Mar 10th, 2019
Coolant leak - happy new year to me! #4620406
01/01/18 10:43 AM
01/01/18 10:43 AM
California
VeryNoisyPoet Offline OP
California
Low coolant warning light this morning when I started the car. Found a nice little puddle under right front corner:
Took off splash tray to see fresh green drops on bottom of radiator:
Discovered the top radiator hose decided last night was the night to begin weeping. Sealant there is mechanical reinforcement for oil cooler hose fitting.
Now it's 5 F / - 15 C outside and I get to figure out why, how, and how to make it stop leaking. Happy new year! LOL crzy shrug
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Coolant leak - happy new year to me! [Re: VeryNoisyPoet] #4620438
01/01/18 11:13 AM
01/01/18 11:13 AM
Toronto, Canada
George7941 Offline
George7941  Offline
Toronto, Canada
You are limited in what can be done in this very cold weather. Working with rubber components in cold weather is difficult.
First step is to further tighten the existing clamp. Next step would be to add an extra clamp. Hopefully this can nurse the car along for a month or two till you get some warmer weather and then you can change out the hose if necessary.
Shrink clamps are very good at preventing cold leaks. Trav, the Bitog guru on all things automotive, is a big proponent of using Hylomar to prevent rad hose leaks.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Coolant leak - happy new year to me! [Re: VeryNoisyPoet] #4620455
01/01/18 11:24 AM
01/01/18 11:24 AM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
I feel your pain man. Doing any car stuff in the bitter cold blows. I replaced a cracked coolant reservoir for my SIL last night. I had to keep taking my gloves off to pick up bolts and it sucked. The joys of winter...
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Coolant leak - happy new year to me! [Re: VeryNoisyPoet] #4620470
01/01/18 11:34 AM
01/01/18 11:34 AM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
Did you smear sealer all over there?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Coolant leak - happy new year to me! [Re: Chris142] #4620485
01/01/18 11:48 AM
01/01/18 11:48 AM
California
California
Yes. After I replaced the cooler hoses, I noticed the oil cooler line fittings had a tendency to work loose as the hoses vibrated . Never leaked either oil or coolant, but I found noticed it when replacing the headlight on that side. Putting sealer around the fittings like that held them in place so I don't need to worry about rechecking them. Top one is super easy to check and tighten, but bottom one requires jacking up car and removing splash guard so I don't want to do that more than I have to.
"Use yah blinkah!"
Re: Coolant leak - happy new year to me! [Re: VeryNoisyPoet] #4620486
01/01/18 11:48 AM
01/01/18 11:48 AM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
If it's just the clamp leaking, and it's a worm gear clamp, and the hose is still intact (might not be if you've cranked on the clamp trying to get the leak to stop, you should buy a constant tension screw clamp. Napa and Oreilly have them in stock. Problem solved.
Re: Coolant leak - happy new year to me! [Re: VeryNoisyPoet] #4620654
01/01/18 02:47 PM
01/01/18 02:47 PM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
Good luck sorting it out, if hose is intact then a screw clamp would be a good option but make sure hose is warm and you are tightening it with normal force(but not overly tightening).
During this cold. anything rubber/bolt related is a royal pain.
Plus, everything hurts like a ....
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Coolant leak - happy new year to me! [Re: VeryNoisyPoet] #4620663
01/01/18 02:58 PM
01/01/18 02:58 PM
San Antonio, TX
das_peikko Online content
das_peikko  Online Content
San Antonio, TX
You need a constant tension spring clamp and a set of Mayhew 28680 pliers.
Re: Coolant leak - happy new year to me! [Re: VeryNoisyPoet] #4620665
01/01/18 02:59 PM
01/01/18 02:59 PM
East Mountains, NM
4wheeldog Offline
4wheeldog  Offline
East Mountains, NM
Given the temperature, it is possible the leak is caused by something shrinking.
If it were me, I would fill the radiator and reservoir, run it until warm and recheck for the leak.
Just sayin'.
Re: Coolant leak - happy new year to me! [Re: VeryNoisyPoet] #4620799
01/01/18 04:55 PM
01/01/18 04:55 PM
ME
eljefino Offline
eljefino  Offline
ME
Agree, run it until warm so stuff will be less brittle before you do "whatever".
Re: Coolant leak - happy new year to me! [Re: VeryNoisyPoet] #4620858
01/01/18 05:49 PM
01/01/18 05:49 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Yes, drive to the auto parts store for more coolant and maybe another clamp. Cranking on cold, brittle ABS plastic with steel tools is fraught with potential fail. Maintaining coolant levels is all you need to do with this until the weather gets warmer
Thick oil is better grin2
Re: Coolant leak - happy new year to me! [Re: VeryNoisyPoet] #4620882
01/01/18 06:13 PM
01/01/18 06:13 PM
California
California
Hose is only 4 years old and still feels flexible even at these freezing temps. It was still really leaking with zero pressure. Took the hose off and figured out why. Hose clamp was a little tired looking, and there's a design / manufacturing flaw in this (presumably) aftermarket radiator. Look at the ridge left over from the plastic molding process. There's one on top and underneath, and they run all the way along the hose nipple. Suddenly there's a leak path if the hose and clamp loosen, shrink, or shift even a little. I'm more surprised it didn't leak worse/sooner!
I painstakingly shaved the ridges down with 400 grit sandpaper until I can't feel them there anymore. Hopefully that gives a smooth surface to help the hose seal. I'm warming up inside now, then I'm headed back out there to fill it up and see if it holds water.
"Use yah blinkah!"
Re: Coolant leak - happy new year to me! [Re: VeryNoisyPoet] #4621096
01/01/18 08:51 PM
01/01/18 08:51 PM
ME
eljefino Offline
eljefino  Offline
ME
Nice find! RTV is your friend if you don't get this sorted.
Re: Coolant leak - happy new year to me! [Re: VeryNoisyPoet] #4621155
01/01/18 09:42 PM
01/01/18 09:42 PM
California
California
Got the hose secured again. The OEM Volvo clamp has seen better days, but the econo-pack screw clamps do not inspire confidence either, so I used both. A hairdryer worked great to warm hose and nipple to 90F / 32C to soften things up before tightening the clamps. It held water without any signs of leaking for about two hours now, so I'm confident I have a temporary repair that won't lose the better part of a quart overnight like it did before.
Since it is now 3F / -16C outside and I like to keep my fingers unfrozen, I'm done for the night. I'll take it for a test drive tomorrow if I don't see any signs of leakage after all that time.
"Use yah blinkah!"
Re: Coolant leak - happy new year to me! [Re: eljefino] #4621169
01/01/18 09:52 PM
01/01/18 09:52 PM
Toronto, Canada
George7941 Offline
George7941  Offline
Toronto, Canada
I had a bad experience with RTV on a rad hose. This was on a Ford 4.9 "Big Six" engine where the thermostat housing end onto which the top rad hose slides on has no barb. There is only friction retaining the hose on. RTV made it slippery and the hose slid off when the pressure built up to the rated 15 psi in the cooling system. I put the hose back on after wiping the RTV off and did not have any further issues.
1987 BMW R80 - sold
2015 Honda CBR300R
