2001 VW Beetle, radiator leaking from right tank/core seal when car sits for a week. Holds pressure fine when hot, but I ordered a new radiator. Bought a Mahle/Behr.
Radiator came in - header plates are galvanized steel, crimped to retain the plastic tanks, coolant tubes are 40 round aluminum tubes in a 2x20 arrangement, fins are 0.07mm thick stamped and slipped on the tubes. Tubes are RUBBER sealed to the header plates! Nothing is brazed.
I've never seen this construction before. I returned it for a Nissens, and that came in with the same construction.
I don't see a bar or plate that keeps the two header plates from blowing off.
How the heck is this radiator constructed? I've always had brazed aluminum cores, with crimp fingers on the plastic tanks, which is were they always leaked. I can't imagine having 80 rubber seals for the tubes plus the tank seals, to last as long.
Googling, I cannot find a cutaway or discussion of this construction style before. Anyone have a link?
