Planes, smoke, pyrotechnics and lasers
by Shannow. 03/26/19 08:55 AM
Rust paint that works? Canada
by nobb. 03/26/19 07:19 AM
Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
bgm6881, machv5, freewayken, JustMatt, DCDMan
67626 Registered Users
88 registered members (aquariuscsm, AdditiveOCD, 2015_PSD, 209paulc, 64bawagon, Alfred_B, 10 invisible), 1,629 guests, and 66 spiders.
Topics286,445
Posts4,908,419
Members67,626
Most Online2,967
Mar 10th, 2019
Have you used WD-40 as engine oil? #4619847
12/31/17 04:26 PM
12/31/17 04:26 PM
S California
OneEyeJack Offline OP
S California
Re: Have you used WD-40 as engine oil? [Re: OneEyeJack] #4619852
12/31/17 04:32 PM
12/31/17 04:32 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Nope, won’t use it as such EVER smile
Re: Have you used WD-40 as engine oil? [Re: OneEyeJack] #4619855
12/31/17 04:37 PM
12/31/17 04:37 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Yup, bought by the gallon to flush hidden water out of engines after flooding. Drain original oil,filter and all the water you can get; fill engine with WD-40 and run 5 minutes at modest high idle (say 1,500 RPM). Drain resultant oil/water mix. Refill with regular oil and cruise on. Works every time smile
Re: Have you used WD-40 as engine oil? [Re: OneEyeJack] #4619863
12/31/17 04:48 PM
12/31/17 04:48 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Many un-informed users think it'a a good lubricant/penetrant. W D stands for Water Dispersant and is used to prevent rust and corrosion.
Re: Have you used WD-40 as engine oil? [Re: OneEyeJack] #4619885
12/31/17 05:05 PM
12/31/17 05:05 PM
Michigan
ZZman Offline
ZZman  Offline
Michigan
Nada
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram TG
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: Have you used WD-40 as engine oil? [Re: OneEyeJack] #4619887
12/31/17 05:07 PM
12/31/17 05:07 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
This guy does the craziest stuff!
Re: Have you used WD-40 as engine oil? [Re: OneEyeJack] #4619894
12/31/17 05:13 PM
12/31/17 05:13 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
That stuff is SO thin.... I'm really surprised that engine lasted
Re: Have you used WD-40 as engine oil? [Re: OneEyeJack] #4619913
12/31/17 05:29 PM
12/31/17 05:29 PM
NC
Matagonka Offline
Matagonka  Offline
NC
Why would you? Are we out of oil?
2018 Mazda 3 Touring HB 2.5
Re: Have you used WD-40 as engine oil? [Re: OneEyeJack] #4620009
12/31/17 07:15 PM
12/31/17 07:15 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
I tried to treat the carburetor on my 2 stroke 2.5 HP outboard for my sailboat with WD-40 and I sprayed a lot on it because I wanted to be sure to get it in the small idle air hole of the carb. I pulled the rope and the engine started and ran for several seconds on WD-40.
I would not use WD-40 as an engine oil because from what I learned from that experience is is combustible.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Have you used WD-40 as engine oil? [Re: OneEyeJack] #4620016
12/31/17 07:27 PM
12/31/17 07:27 PM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
No and would never....
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Have you used WD-40 as engine oil? [Re: OneEyeJack] #4620020
12/31/17 07:29 PM
12/31/17 07:29 PM
Australia
uart Offline
uart  Offline
Australia
I was told that my car needed an xW40 oil, so I thought WD40 was exactly what I should be using. Are you guys now telling me that I've been doing the wrong thing? wink
Re: Have you used WD-40 as engine oil? [Re: JimPghPA] #4620052
12/31/17 08:00 PM
12/31/17 08:00 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
I have used it for engine start on IDI diesels because ether is a bit aggressive and it nearly kills them.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Have you used WD-40 as engine oil? [Re: Warstud] #4620072
12/31/17 08:27 PM
12/31/17 08:27 PM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
And a ton of other uses.
https://www.rd.com/home/cleaning-organizing/13-amazing-uses-for-wd-40/
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: Have you used WD-40 as engine oil? [Re: OneEyeJack] #4620097
12/31/17 09:17 PM
12/31/17 09:17 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Yeah, once, with a new engine. Made it out of the driveway!
Just kidding. Sort of.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Have you used WD-40 as engine oil? [Re: Linctex] #4620161
12/31/17 11:17 PM
12/31/17 11:17 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Originally Posted By: Linctex
This guy does the stupidest stuff!
Fixed that for ya.
