Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
Oil weight and FM
by Brian553. 01/22/19 01:07 PM
New Bridgestone Blizzak WS90
by SubLGT. 01/22/19 12:59 PM
Southwest Airlines slides off runway
by JustN89. 01/22/19 12:55 PM
phenolic caliper pistons
by bionictony. 01/22/19 12:31 PM
SS snowblower auger to scraper gap?
by dwcopple. 01/22/19 11:47 AM
PP HM 10W-30 at Walmart for $15
by 28oz. 01/22/19 11:30 AM
2012 Camry ATF change- now or later?
by TmanP. 01/22/19 11:20 AM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
113 registered members (53' Stude, 28oz, 2003f7, 69GTX, 16 invisible), 2,047 guests, and 35 spiders.
Topics296,988
Posts4,963,069
Members67,013
Most Online2,821
Jan 21st, 2019
Best Way to Orient a Fumoto Valve #4617938
12/29/17 04:33 PM
12/29/17 04:33 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Just got 4 Fumoto's for Christmas. Is there a best way to orient the lever? Or does it matter?
'98 LEX LS400 280K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: Best Way to Orient a Fumoto Valve [Re: Gebo] #4617950
12/29/17 04:45 PM
12/29/17 04:45 PM
Ceciltucky Maryland
Oldtom Offline
Oldtom  Offline
Ceciltucky Maryland
I always put the lever facing up. Less likely to get snagged by something or damaged by road debris.
Re: Best Way to Orient a Fumoto Valve [Re: Gebo] #4617951
12/29/17 04:46 PM
12/29/17 04:46 PM
Outer Banks, NC
NormanBuntz Offline
NormanBuntz  Offline
Outer Banks, NC
Sometimes you don't have a choice because of how it tightens up to the oil pan. If you have one of the swivel or adjustable ones, I'd say position it where you can reach it, but not where it can snag on something while you're driving. Be sure to use the black safety clip that they make.
2017 Honda Odyssey SE, 17K
2013 Honda Accord LX, 58K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: Best Way to Orient a Fumoto Valve [Re: Gebo] #4617965
12/29/17 04:55 PM
12/29/17 04:55 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
MIne is facing down. What I'm asking is as I am tightening it up, where should I try and have the silver lever end up. I was thinking to have it sort of behind the valve if you are looking at it from the front of the car. In other words, you wouldn't see the silver lever if you were looking at the valve from the front of the car.
'98 LEX LS400 280K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
Re: Best Way to Orient a Fumoto Valve [Re: Gebo] #4618049
12/29/17 06:01 PM
12/29/17 06:01 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Unless you got the new fancy model, you tighten it and it is what it is.
The new fancy model should be positioned so the opening lever is well protected.
2015 Ford F250 w/Powerstroke
Re: Best Way to Orient a Fumoto Valve [Re: Oldtom] #4618058
12/29/17 06:11 PM
12/29/17 06:11 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
I used the blue washer and an aluminum crush washer on the two installed. Had to try it a few different positions when starting the thread to get it positioned right. I didn't want the lever getting snagged.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Best Way to Orient a Fumoto Valve [Re: JC1] #4618103
12/29/17 06:57 PM
12/29/17 06:57 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Drain pugs never get snagged!
2004 Corolla 128335
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74615
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Best Way to Orient a Fumoto Valve [Re: JohnnyJohnson] #4618106
12/29/17 06:59 PM
12/29/17 06:59 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
But I'm running synthetic. I can probably go 33-36 miles with no oil crazy
'98 LEX LS400 280K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
Re: Best Way to Orient a Fumoto Valve [Re: Gebo] #4618887
12/30/17 02:21 PM
12/30/17 02:21 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
Well away from the engine.
Re: Best Way to Orient a Fumoto Valve [Re: Gebo] #4618949
12/30/17 03:59 PM
12/30/17 03:59 PM
E. Tennessee
WhizkidTN Offline
WhizkidTN  Offline
E. Tennessee
Merry Christmas! I've always positioned them to give me maximum protection of the lever. I've run them on a total of 4 cars thus far with excellent results over many miles.
His: '12 Kia Optima SX - 2.0L GDI Twin-Scroll Turbo [Tuned] (77K)
>EDGE 0W-40, Fram XG9688
Her's: '14 Nissan Rogue SL AWD - 2.5L NA (77K)
>EDGE 0W-20, Fram XG6607
