Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
45 registered members (bfleeman, CB900F2, Boomer, AndyB, 94astro, BenZahel, 6 invisible), 1,085 guests, and 40 spiders.
Topics295,094
Posts4,927,699
Members66,684
Most Online2,553
Oct 27th, 2018
BG product and services? #4614061
12/25/17 05:04 PM
12/25/17 05:04 PM
Florida
lawnguy Offline OP
lawnguy  Offline OP
Florida
BG offers a whole lot of maint. related products/services. I am someone who is not one to do the maint. on my truck myself. I have a local mechanic who does when needed. Out of all the servcies that are offered which are better to have done with their BG products,and machines? I ask because I want to have the same maint. done but have it cost less than the BG service itself,and also have a better job done if it's better for a mechanic to do it by hand,etc. Hopefully this all makes sense?
Re: BG product and services? [Re: lawnguy] #4614235
12/25/17 09:12 PM
12/25/17 09:12 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Out of all the snake oil companies, BG seems to be the most legit I guess you could say.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: BG product and services? [Re: lawnguy] #4614313
12/26/17 12:35 AM
12/26/17 12:35 AM
Rio Rancho, NM
Pajero Offline
Pajero  Offline
Rio Rancho, NM
Befriend a govt representative from BG who doesn't work on commission. He/she will give you a discount. BG makes quality products. I used to buy BG 44K and MOA by the case. But with newer, oil specs you don't need MOA. 44K is great for the fuel. Let google be your friend.
Respectfully,
Pajero!
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 133,xxx
Fram Ultra/ Snorkel with Pre-filter
K-9-Co-pilot
Re: BG product and services? [Re: bdcardinal] #4614323
12/26/17 01:11 AM
12/26/17 01:11 AM
CA
The Critic Offline
The Critic  Offline
CA
That is a good way of putting it.
BG EPR is pretty good. Their 44K is good, but so are Redline SI-1, Techron Concentrate Plus or Amsoil PI for a fraction of the cost. Some of their machines are quite good as well (I.e. their brake flush machine).
2011 Toyota Prius - 178k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 133K - Mobil 1 EP HM 5W-30
Re: BG product and services? [Re: The Critic] #4614378
12/26/17 06:40 AM
12/26/17 06:40 AM
Florida
lawnguy Offline OP
lawnguy  Offline OP
Florida
Is the redline product better than seafoam,or berry man b12 chem fuel?
Re: BG product and services? [Re: bdcardinal] #4614383
12/26/17 06:45 AM
12/26/17 06:45 AM
VA
Gebo Offline
Gebo  Offline
VA
My sentiments as well. I'm using Schaeffer for now.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: BG product and services? [Re: lawnguy] #4614638
12/26/17 11:50 AM
12/26/17 11:50 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Remove the Seafoam from the list, you might as well take a whiz in it and have the same effect. Chemtool B12 and Redline are both very good at doing different jobs.
For varnish deposits in injectors and carbs nothing beats the high solvent properties of B12, a splash in the tank at every fill on small engines with carbs will keep them in nice condition, you will never have a problems requiring removal and cleaning.
Redline and a couple of other PEA based cleaners work better on hard deposits commonly found in injectors but does not do very well with varnish. In my experience a 2 prong approach to cleaning is best, one tank with a high dose of Redline (full bottle) and the next tank a full bottle or even 2 of B12 will provide the best results.
Its not unheard of when running a full bottle of Redline to get an O2 code, it will clear on its own eventually or you can do it manually. If you were to compare the O2 before and after (I have along with a 30K fuel injector cleanliness test on the machine) you will see it is much cleaner after.
Redline does not advertise this benefit but its real. One out of a 2005 GMC 6.0 was black as the ace of spades and after a full bottle in a full tank it was ash grey and noticeably cleaner. Techron total fuel system cleaner seems to do this, others may also, the first few cold starts in cold weather when the fuel is very rich produced a putrid smell at the exhaust that got less over a short time.
This smell is what motivated me to pull an O2 before and after, I cant say if it has any cleaning effect on the cat also but its possible.
