more dumb questions!! infiniti Q50
by Robertslowpoke. 03/23/19 06:23 AM
VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
53 registered members (BobFout, 4WD, billt460, 77GrandPrix, avi1777, antik, 6 invisible), 770 guests, and 55 spiders.
Topics286,270
Posts4,905,654
Members67,589
Most Online2,967
Mar 10th, 2019
303 and Serpentine Belt on a 2006 Civic EX Coupe #4613771
12/25/17 11:39 AM
12/25/17 11:39 AM
MURICA
maverickfhs Offline OP
MURICA
So I am thinking to replace serpentine belt on my 8th Gen civic. Current one is looking good, but thinking ahead as a precautionary measure.
Came across this : https://www.youtube.com/watch?v=dRXkt6Dgi4k
Does 303 works and if so, have seen many videos about it, does anyone here has any experience with it?
Also, is procedure that simple and easy for my Civic ? https://www.youtube.com/watch?v=EoZJ82pvrts&t=31s
Feel free to advice or suggest anything else too, thank you and Merry Xmas smile
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: 303 and Serpentine Belt on a 2006 Civic EX Coupe [Re: maverickfhs] #4613776
12/25/17 11:55 AM
12/25/17 11:55 AM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
I seen that and thought "How Stupid Could You Be". To me that's like putting oil on your brake rotors to reduce wear.
Re: 303 and Serpentine Belt on a 2006 Civic EX Coupe [Re: maverickfhs] #4613780
12/25/17 11:58 AM
12/25/17 11:58 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I've seen that video and it got me thinking, then I circle back to having those belts go well over 100K miles with no treatment at all. I'm sure there are many others here with similar results, I just don't see any upside, only downside.
I think the best things you can do when replacing a serpentine belt is make sure the pulleys are clean, especially any pulley that has V-grooves in it. The main damper pulley on some engines collects dirt because it is low on the engine and can get junk tossed up from the tires in some instances. Over time it can get packed in there, that will shorten belt life in a big way if it isn't properly addressed. I make sure that is spotless. I also check the tensioner, and replace it when needed. Those two steps IMO will benefit a belt a lot more than a 303 treatment.
Merry Christmas!
God Bless Our Troops
Re: 303 and Serpentine Belt on a 2006 Civic EX Coupe [Re: maverickfhs] #4613785
12/25/17 12:01 PM
12/25/17 12:01 PM
MURICA
MURICA
Makes sense and I appreciate your feedback. Yes, these days belts last a LOOOOOOONG time. I'll drop this whole 303 thing.
Thank you.
Re: 303 and Serpentine Belt on a 2006 Civic EX Coupe [Re: maverickfhs] #4613788
12/25/17 12:03 PM
12/25/17 12:03 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Thank you.
Smart move!
Re: 303 and Serpentine Belt on a 2006 Civic EX Coupe [Re: maverickfhs] #4613789
12/25/17 12:04 PM
12/25/17 12:04 PM
USA
mk378 Offline
mk378  Offline
USA
Superficial side to side cracking like the guy shows in the video does NOT mean that the belt is bad. Belts that have cracks that go the long way and/or pieces of the ribs falling off should be replaced.
Re: 303 and Serpentine Belt on a 2006 Civic EX Coupe [Re: maverickfhs] #4613797
12/25/17 12:10 PM
12/25/17 12:10 PM
MURICA
MURICA
So is brownish color of the belt normal? No cracks or tears or any other visible signs of anything else. Thanks
Re: 303 and Serpentine Belt on a 2006 Civic EX Coupe [Re: maverickfhs] #4613804
12/25/17 12:18 PM
12/25/17 12:18 PM
Oakville, Ontario
Patman Offline
Global Moderator
Patman  Offline
Global Moderator
Oakville, Ontario
How many miles are on your Civic? I just had my serpentine belt changed by the dealer in the spring, it had about 135,000 miles on it at the time and it was in rough shape!! Shame on me for not doing it sooner!
2018 Corvette, 9k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 149k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,113k, GC 0w40 & Fram Ultra
Re: 303 and Serpentine Belt on a 2006 Civic EX Coupe [Re: maverickfhs] #4613810
12/25/17 12:29 PM
12/25/17 12:29 PM
MURICA
MURICA
It has 197K, but definitely has been replaced in the past. I bought it at 190K.
Re: 303 and Serpentine Belt on a 2006 Civic EX Coupe [Re: maverickfhs] #4613817
12/25/17 12:41 PM
12/25/17 12:41 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Belt companies recomend replacement @90k
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 303 and Serpentine Belt on a 2006 Civic EX Coupe [Re: maverickfhs] #4613864
12/25/17 01:44 PM
12/25/17 01:44 PM
Toronto
dgunay Offline
dgunay  Offline
Toronto
Mine still has factory serpentine belt, at 75k and 8 year-old car, it looks fine. I always keep a spare belt in trunk though.
2009 Acura CSX - PUP 0w20 / Fram XG7317 / Maxlife ATF
2018 Kawasaki Z650 - Motul 4T 5100 10w40 / OEM Oil Filter
Re: 303 and Serpentine Belt on a 2006 Civic EX Coupe [Re: maverickfhs] #4613873
12/25/17 02:00 PM
12/25/17 02:00 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
When belts wear they lose material or crack. 303 isn't going to help anything but maybe (and that's a strong maybe), make the surface more supple. That's not even considering what contamination of the belt surfaces would do in terms of grip on the pulleys, which could affect operation of belt-driven accessories and create noise. Honda didn't put it on for a reason so keep it off, this is some shade-tree "injineering" alright.
I have the same gen Civic, your R18 engine came with an EPDM belt as stock, not the usual neoprene. EPDM doesn't tend to crack, instead the material is lost between the ribs. This causes the belt to shift slightly, slip or lose grip. It's a better failure mode than cracks and chunks of ribs falling off and EPDM doesn't dry rot as much either. Overall a much longer lasting belt. To accurately measure wear on these types of belts you need a gauge, sight is not good enough.
Gates will send you a free belt gauge. Advance auto parts had a promotion a while back too where they gave out free Dayco belt gauges. On this page click the link that says to request a free gauge. I got mine from them and it works great.
http://www.gates.com/products/automotive/tools-and-sales-aids/belt-wear-diagnosis/belt-wear-gauge
I recommend measuring first, because it's free and tells you definitively whether you need to replace or not. You may find it's not worn enough at all and avoid the headache of doing the job.
If you do the job here are some tips:
1. Make sure you compress the hydraulic tensioner slowly, if you go too fast you can snap off the part the wrench or tensioner tool is pushing on and then you're really screwed and will have to replace the whole tensioner.
2. They had a TSB where they changed the belt routing for the 2006 models and beyond due to buzzing caused by the belt routing, TSB 06-059. Whether you already had it done or not, make sure you get the new part number with the longer belt and route it according to the new layout on the TSB.
3. They also had a TSB where 09-007 where the old routing of the belt also put extra pressure on the tensioner pivot bolt which could break it. You may want to replace that bolt like the TSB recommends while you have the belt off, definitely use the new longer belt and routing to put less pressure on the new bolt.
On the smooth side? Yes. Mine has been brown since the day I bought it, although I imagine this has more to do with their OE belt supplier than anything and not a metric for wear.
2015 Civic LX Coupe
Re: 303 and Serpentine Belt on a 2006 Civic EX Coupe [Re: maverickfhs] #4613880
12/25/17 02:14 PM
12/25/17 02:14 PM
MURICA
MURICA
Thanks NoNameJoe, I appreciate your valuable advice and input. I actually already have that tool and it does show that belt is good.
Although, I must say I am not an expert at using it wink
Yes, Honda didn't put anything on it and 303 seems to be a snake oil, being utilized for so many different things!
I have heard many of these EPDM hoses can last life of the car or for a long time.
Yeah, I have read on many forums and websites to very very slowly and gently push on 17mm tensioner, since it's hydraulic and can be easily damaged if rushed...
Thanks again for your help. Guess, I'll hold on to the belt for now.
Re: 303 and Serpentine Belt on a 2006 Civic EX Coupe [Re: maverickfhs] #4613896
12/25/17 02:40 PM
12/25/17 02:40 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Watch his other videos where he uses ATF and a heat gun to restore black plastic. And spray paint to restore leather seats. Insane!
