1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
30 registered members (billt460, citationxeleven, anndel, c502cid, Ag76, 3 invisible), 952 guests, and 31 spiders.
Topics296,903
Posts4,961,304
Members66,997
Most Online2,688
Jan 19th, 2019
Gear Oil for Spool #4607710
12/18/17 09:17 PM
12/18/17 09:17 PM
South Carolina
eyeofthetiger Offline OP
South Carolina
Let's say a standard GM 8.5" 10-bolt rear end normally takes 80W-90 GL-5 gear oil. Should I consider something different if I take out the silly spider gears and put in a mini-spool? Maybe it doesn't make a lick of difference. Probably not. You can tell me to use something fancy, but then I might not be able to afford tires.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: Gear Oil for Spool [Re: eyeofthetiger] #4607719
12/18/17 09:40 PM
12/18/17 09:40 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
The 80w90 is what you want for the ring and pinon. I have a detroit locker in my ford and its quite a neusance. It clangs and bangs and eats tires.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Gear Oil for Spool [Re: eyeofthetiger] #4607720
12/18/17 09:40 PM
12/18/17 09:40 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
OK, this gets a bit tricky. What are you trying to accomplish in the end?
One approach is to use the B-O-P 8.6 w/o the C-Clips as a small drag car rear end. Spools readily available, and a bunch stronger than the Chevy version smile Still an 10-Bolt. Many rears will swap over directly, housing and all.
Or, go to Redline Explosion Proof and it'll live for a while. But you may still spit out an axle when a clip goes frown
Re: Gear Oil for Spool [Re: BrocLuno] #4607734
12/18/17 10:01 PM
12/18/17 10:01 PM
South Carolina
South Carolina
I had one of those Powertrax lockers in another truck. It was fine, but this time I figure I can do without the clanging and banging. Just straight tire eating. A mini spool is cheaper, too.
It's not exactly a race truck. The 4.3 might put down 120 HP on a good day. It is more of a utilitarian thing. I do some work out in the woods, and I never ever want to get stuck out there. Sure, it's 4WD, but more is better. Zero cares about handling on pavement or tire wear. It needs to pull trees up muddy hills.
Would it be crazy to install a 3-point hitch and drag a box blade with this truck?
So, Redline Explosion Proof is the gear oil I should use.
Re: Gear Oil for Spool [Re: eyeofthetiger] #4608146
12/19/17 11:15 AM
12/19/17 11:15 AM
BrocLuno Offline
BrocLuno  Offline
For your application, just use the OEM recommended lube. Redline is overkill. You are taking care of the ring/pinion/bearings.
You are not hitting it with a trans-brake launch at 5,000 laugh
Re: Gear Oil for Spool [Re: eyeofthetiger] #4608245
12/19/17 12:30 PM
12/19/17 12:30 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Sounds like a fun truck. Reminds me of my Chevy LUV 4WD when living in the mountains of Montana. It was a VERY capable off-road truck.
Re: Gear Oil for Spool [Re: BrocLuno] #4608503
12/19/17 05:02 PM
12/19/17 05:02 PM
South Carolina
South Carolina
I could try hitting the rev limiter in neutral and slamming it into drive ... shocked
Just by chance, the front differential happens to have Redline 75W-90. It was all I had on hand when I some minor linkage repairs and deleted the electronic axle lock. Maybe I should put Redline in the back just so everything matches.
Re: Gear Oil for Spool [Re: eyeofthetiger] #4613349
12/24/17 07:22 PM
12/24/17 07:22 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Why take out the lock?
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
