Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
26 registered members (BlakeB, Billbert, ArrestMeRedZ, CleverUserName, Astro14, ctechbob, 1 invisible), 731 guests, and 41 spiders.
Topics290,867
Posts4,851,572
Members66,044
Most Online3,590
Jan 24th, 2017
ariens L3???? #4605885
12/16/17 11:55 PM
12/16/17 11:55 PM
IL
Don_B Offline OP
Don_B  Offline OP
IL
Just [censored] is this mystery oil? The auger gearbox has it cast right into the housing (cast iron housing) is there a good substitute or equivalent product?
This is a 831010 48". 2 stage attachment for my old gt series machine
I just bought this blower and currently have it in pieces as it was stored in a barn that caught fire, had it sandblasted and powder coated so now reassembly can begin.
I had to take the gearbox apart for seal replacement as they were ruined in the fire. So now to figure out what I can fill the gearbox with
I hate when manufacturers spec their own lubricants and don't want you to know what the product really is
I don't care about political correctness in particularly searching for oil in a bottle that has an aliens sticker on it
Can't I just use 80-w-90?
78 Plymouth Fury 2 door
80 Plymouth Volare (project)
97 Wrangler 4.0/5 speed
92&96 318 Dakotas
Re: ariens L3???? [Re: Don_B] #4605887
12/17/17 12:00 AM
12/17/17 12:00 AM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
I'd run any cheap gear oil.
AS LONG AS there are no yellow metals inside.
Re: ariens L3???? [Re: Don_B] #4605890
12/17/17 12:02 AM
12/17/17 12:02 AM
Waco, TX
Waco, TX
Re: ariens L3???? [Re: Linctex] #4605891
12/17/17 12:03 AM
12/17/17 12:03 AM
Waco, TX
Waco, TX
Originally Posted By: Linctex
"It's a proprietary synthetic 75W-140 GL5 MT1 with a special EP formulation."
Re: ariens L3???? [Re: Don_B] #4605892
12/17/17 12:09 AM
12/17/17 12:09 AM
IL
Don_B Offline OP
Don_B  Offline OP
IL
It has a steel worm gear and a brass driven gear
92&96 318 Dakotas
Re: ariens L3???? [Re: Don_B] #4605927
12/17/17 01:48 AM
12/17/17 01:48 AM
North of you Idaho
KneeGrinder Offline
KneeGrinder  Offline
North of you Idaho
I would strongly suggest that you use the correct fluid with the cost of replacement parts for anything nowdays. If it is a real gear box, maybe gear oil. But if its a hydrostat type drive, I would not chance using the wrong fluid.
08 Tribeca 82k PUP 5w30 wix
06 Accord Hybrid 131k PUP 5w20 wix
02 Chevy k3500 97k Delvac 1 esp 5w40 wix
00 F350 133k Delvac 1300 15w40 wix
Re: ariens L3???? [Re: Don_B] #4606014
12/17/17 09:10 AM
12/17/17 09:10 AM
IL
Don_B Offline OP
Don_B  Offline OP
IL
Yes regular gearbox, not hydro, part of issue is nobody sells ariens within 40 miles and I do not go anywhere near either of them, would have to take time off from work to be able to make a special trip just to get it. I came here looking to see what the correct lubricant is without having to buy a bottle of it from them, I am sure that other applications use this same stuff, the oil companies aren't gonna mix up some compound just specifically for them. There are other machines out there that use a steel worm gear supported by tapered roller bearings driving a brass gear on a steel sleeve that's supported by bronze/ brass bushings, so there has to be a more commonly available lubricant that will work. This unit is about 30years old, so it isn't like it has warranty left on it that I will void if I don't use "their" stuff. I just want the machine to live after all of the work, time and money that I am putting into it to bring it back to life.
92&96 318 Dakotas
Re: ariens L3???? [Re: Don_B] #4606036
12/17/17 09:30 AM
12/17/17 09:30 AM
Waco, TX
Waco, TX
Yeah, you have put a lot of work into this machine.
I posted the links to the info,. You should be able to search it out from here.
Re: ariens L3???? [Re: Don_B] #4606039
12/17/17 09:33 AM
12/17/17 09:33 AM
Waco, TX
Waco, TX
Order it. Everybody mail orders everything now-a-days.
We are back to the Catalog mail order days of the early 20th Century, LOL!
WRONG. Special oils are spec's all the time.
Besides, it isn't oil companies, they just supply base stocks.
Blenders, like Valvoline - don't make oil, they blend it.
They'll blend whatever to any manufacturer's spec and put a special label on it.
YES - - - it happens all the time.
Re: ariens L3???? [Re: Don_B] #4606238
12/17/17 02:22 PM
12/17/17 02:22 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
Since you state it is a worm gear drive you will want a oil for Hypoid/worm gear drives. That means a GL5 or a GL4+ oil. I would contact Ariens and try to order and get the corect stuff. Ed
CX5 Touring 2.5L :-)
Re: ariens L3???? [Re: Don_B] #4606248
12/17/17 02:32 PM
12/17/17 02:32 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Re: ariens L3???? [Re: Rand] #4606655
12/17/17 09:25 PM
12/17/17 09:25 PM
IL
Don_B Offline OP
Don_B  Offline OP
IL
Originally Posted By: Rand
I actually tried a google search before I asked here and in probably 100X that 3.5 seconds I came up empty. Story of my life.
92&96 318 Dakotas
