Employer Exit Interview.
by JustinH
10 minutes 59 seconds ago
Ceratec vs. Archoil 9100
by Phishin
14 minutes 35 seconds ago
Acclaim radiator ?
by urrlord
16 minutes 49 seconds ago
Understanding Idle Control Circuit
by artbuc
Today at 07:59 AM
Annual drain on Mobil1 5w20 high mileage?
by ryan2022
Today at 07:36 AM
Best Oil For Late Model Toyota V6 Engines ?
by ChrisD46
Today at 06:58 AM
Ford 4.6L Durability?
by Auae85
Yesterday at 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
Yesterday at 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
Yesterday at 10:01 PM
Fireworks Stores
by Warstud
Yesterday at 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
Yesterday at 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
Yesterday at 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
Yesterday at 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
Yesterday at 08:49 PM
My FIL in hospice
by fdcg27
Yesterday at 08:41 PM
Spraying Polyurethane
by Texican
Yesterday at 08:37 PM
Dehumidifier icing
by Kestas
Diesel lube in Petrol Engine
by Ducked
Yesterday at 07:46 PM
New key programming cost
by 92saturnsl2
Yesterday at 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
Yesterday at 07:09 PM
ronw1309, Suth31, yamahaboy125, Turboholic, TrpNY
65284 Registered Users
88 registered (aquariuscsm, Alex_V, 2004tdigls, ARCOgraphite, andyd, A310, 10 invisible), 1401 Guests and 39 Spiders online.
65284 Members
67 Forums
285691 Topics
Page 1 of 2 1 2 >
#4602543 - 12/13/17 12:06 PM Ok to drive with bad flex pipe?
boostedtsiawd Offline
Loc: ILL
My car is making noise from the exhaust and noticed the flex pipe broke off a bit from where it was welded is it ok to drive like this? Will it cause damage to anything if i dont get it replaced asap?
Edited by boostedtsiawd (12/13/17 12:08 PM)
#4602545 - 12/13/17 12:13 PM Re: Ok to drive with bad flex pipe? [Re: boostedtsiawd]
fenixguy Offline
Loc: NC
If it's not dragging on the ground then drive it to an exhaust shop or someone who can fix it. If it's dragging, try to tie it up with a coat hanger or something.
'16 Frontier SV 4x4-PP/Nissan OEM
'08 CR-V EX AWD-Valvoline Syn MaxLife/Fram TG
'01 Civic EX-Valvoline Syn MaxLife/Fram UG
'00 Civic LX-PYB/Fram UG
#4602551 - 12/13/17 12:20 PM Re: Ok to drive with bad flex pipe? [Re: fenixguy]
Kira Offline
Loc: Champlain/Hudson Valley
+1
.....and do it in a timely manner as hot exhaust can start a fire depending on what's near the leak.
No biggie. Just get the darn thing fixed. That means "flex joint replaced" in your case.
Get a good one. There are real cheap ones out there.
#4602565 - 12/13/17 12:45 PM Re: Ok to drive with bad flex pipe? [Re: boostedtsiawd]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
Whatever you do, don't go to sleep in that car. Not saying you do, but some people are road warriors, some people do it on their lunch break, etc.
But don't, or you might not wake up.
Othwise, it'll just be an annoyance for the most part.
I'd recommend replacing the entire downpipe. Holds up better than a repair in the long run.
#4602594 - 12/13/17 01:48 PM Re: Ok to drive with bad flex pipe? [Re: boostedtsiawd]
OneEyeJack Offline
Loc: S California
It's no problem at all unless you breathe while inside the car. Just hold your breath and don't allow passengers. If you take a breath while inside the car with the engine running, look in the mirror. That "S" on your forehead is for STUPID. If your cheeks are rosy red, that's carbon monoxide poisoning and you're dead. If it hasn't happened yet, keep trying. A few more times should get it. Instead of fixing the car get an O2 bottle with a regulator, tubing, and a mask. You can wear it all the time your driving or play carbon monoxide roulette and only put it on when your cheeks start to turn red or you start to pass out, have vision problems or start hitting other cars. Set the O2 flow at about 6-10 liters per minute and let us know what happens if you can.
If in doubt check with bbhero. See if he agrees with my assessment.
#4602675 - 12/13/17 03:18 PM Re: Ok to drive with bad flex pipe? [Re: boostedtsiawd]
Miller88 Offline
Loc: Onondaga County
The exhaust falls off of my jeep about once a month ... I just drive with the window down when it happens
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
#4602709 - 12/13/17 03:46 PM Re: Ok to drive with bad flex pipe? [Re: OneEyeJack]
kschachn Offline
Loc: Upper Midwest
I wonder if the brand of gasoline would make a difference.
1994 BMW 530i, 227K
1996 Honda Accord, 262K
1999 Toyota Sienna, 394K
2000 Toyota ECHO, 267K
#4602711 - 12/13/17 03:49 PM Re: Ok to drive with bad flex pipe? [Re: boostedtsiawd]
SatinSilver Offline
Loc: OH
Try some Amsoil 0w20 in there and report back. Thank you.
#4602754 - 12/13/17 04:56 PM Re: Ok to drive with bad flex pipe? [Re: boostedtsiawd]
andyd Online   content
Loc: Marshfield , MA
Some states Loud exhaust gets a ticket.
Thick oil is better grin2
#4602759 - 12/13/17 05:03 PM Re: Ok to drive with bad flex pipe? [Re: andyd]
Crispysea Offline
Loc: TN USA
Not here. I hear the rice rockets until the wee hours of the morning. They’re running straight pipes, most of them. It sounds like a logging camp.
#4602851 - 12/13/17 07:04 PM Re: Ok to drive with bad flex pipe? [Re: boostedtsiawd]
Loc: ILL
So the only thing is the noise i have to worry about right?
#4602859 - 12/13/17 07:09 PM Re: Ok to drive with bad flex pipe? [Re: boostedtsiawd]
eljefino Offline
Loc: ME
and carbon monoxide, ya moron.
If you only drive highway speed it'll get sucked under your floor pan. Slow down and it'll waft up the engine compartment to your cowl air intake.
So yeah get it fixed. You can hacksaw the old one off and put a new one in with muffler clamps for $30.
#4602864 - 12/13/17 07:13 PM Re: Ok to drive with bad flex pipe? [Re: boostedtsiawd]
kschachn Offline
Loc: Upper Midwest
This post proves you're a troll, the majority of the people who took the time to respond in a serious fashion told you it was dangerous.
As if we needed this thread in addition to your gasoline one to determine that.
1994 BMW 530i, 227K
#4602987 - 12/13/17 09:11 PM Re: Ok to drive with bad flex pipe? [Re: boostedtsiawd]
StevieC Offline
Loc: Ontario, Canada
Turn up the radio... When the radio can't over power the noise from a car problem then its time to see a mechanic. grin2
Edited by StevieC (12/13/17 09:11 PM)
'15 Dodge Journey - 90,000 KM's - SSO 5w20
'06 Hyundai Santa Fe - 535,000km - SSO 0w30 (R.I.P)
#4602988 - 12/13/17 09:12 PM Re: Ok to drive with bad flex pipe? [Re: kschachn]
OneEyeJack Offline
Loc: S California
Nope.
On a serious note, even the guy above with the Jeep should be aware that even a little carbon monoxide poisoning destroys brain cells in a way that makes the repair difficult and the effects don't go away quickly even when the source is completely removed.
Carbon monoxide hooks up in your blood much better than O2 and takes a while to unhook and therein lies the problem.
Page 1 of 2 1 2 >
