Originally Posted By: SirTanon
You're trolling, right? Add water to gasoline in order to 'remove' the ethanol? You realize that that's not at all how that works, right?
Seems legit. Adding water causes separation. Ethinol and water attract to each other. Drain the separation into a container. Leaving pure gas.
