Car Door Fabric Glue
by cb450sc. 12/18/18 08:57 PM
Canadian Uber
by StevieC. 12/18/18 08:13 PM
71141 / Lifeguard 5
by chefwong. 12/18/18 07:52 PM
Tested Positive for Flu
by john_pifer. 12/18/18 07:37 PM
Cooper RTX?
by 01rangerxl. 12/18/18 07:25 PM
IPhone SE or flip phone?
by 53' Stude. 12/18/18 05:49 PM
1993 K1500 hard cold start
by BrianF. 12/18/18 05:43 PM
Put my wife's dog down yesterday
by Stelth. 12/18/18 05:04 PM
ATF Filter oem vs aftermarket any differences?
by 97prizm. 12/18/18 03:50 PM
Depth-Fiberglass Filter Media.
by Al. 12/18/18 03:43 PM
O2 sensor B1S1 no voltage??
by David1. 12/18/18 03:43 PM
Brilliant payback for package thieves
by SirTanon. 12/18/18 01:22 PM
Calling all Ford Owners
by dogememe. 12/18/18 01:01 PM
2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Sportbiker, trollhattan, MuhThugga, wxo, dbierman
66718 Registered Users
104 registered members (antonmnster, andyd, 14Accent, ARB1977, -SyN-, 330indy, 11 invisible), 1,850 guests, and 37 spiders.
Topics295,239
Posts4,930,746
Members66,718
Most Online2,553
Oct 27th, 2018
Will Mobile1 Synthetic 5w30 hurt my VW mk7? #4593897
12/04/17 12:11 PM
12/04/17 12:11 PM
US
bossbrew Offline OP
bossbrew  Offline OP
US
Hi,
First post. I changed my oil yesterday, and then realized that the Mobile1 5w30 is not a VW 502 spec oil. Most of my driving is an easy commute, and I live near Santa Cruz, CA - so no extreme temps. Will this one wrong oil change hurt my car?
Thanks,
Dave
Re: Will Mobile1 Synthetic 5w30 hurt my VW mk7? [Re: bossbrew] #4593905
12/04/17 12:18 PM
12/04/17 12:18 PM
MD
onemig Offline
onemig  Offline
MD
IMHO, not at all. Just change the oil again using an oil with the appropriate spec.
2014 Subaru Forester XT Touring w/ Eyesight, 80K miles - Wife's
2017 GTI S DSG 4 Dr. HB, 5K miles - Mine
Re: Will Mobile1 Synthetic 5w30 hurt my VW mk7? [Re: bossbrew] #4593919
12/04/17 12:37 PM
12/04/17 12:37 PM
US
bossbrew Offline OP
bossbrew  Offline OP
US
Thanks onemig,
Do mean change it immediately, or switch at the next change?
Re: Will Mobile1 Synthetic 5w30 hurt my VW mk7? [Re: bossbrew] #4593921
12/04/17 12:42 PM
12/04/17 12:42 PM
PA,US
HemiHawk Offline
HemiHawk  Offline
PA,US
Are you still under warranty? I'd change it right away in the case. I highly doubt you'd have any issues especially not running the car real hard. But I wouldn't trust it out to the usual VW 10k interval.
2016 Nissan Frontier Pro4x
2017 VW GTI sport
1995 Mustang GTS
Re: Will Mobile1 Synthetic 5w30 hurt my VW mk7? [Re: bossbrew] #4593927
12/04/17 12:48 PM
12/04/17 12:48 PM
South Carolina
bmwtechguy Offline
bmwtechguy  Offline
South Carolina
Main difference is the HTHS rating of the oil. Oils formulated for German cars usually have a higher HTHS rating than oils formulated for domestics. The main reason is the higher speed limits those cars see in some places like Germany. Sustained high speed driving such as 100-120 mph will generate higher oil temps that require the higher HTHS rating that VW specs. Otherwise with normal 70-85 mph driving here in moderate temps, you should have no trouble with regular DEXOS 1 rated Mobil 1 5W-30 full synthetic. I would use this current oil without worries, maybe change a couple thousand miles sooner, though instead of waiting the whole duration. I have seen many BMWs run on the same regular M1 5W-30 for their entire 200,000 mile life here in the US without any issues, and it does not meet BMW LL-01 spec, but for normal everyday driving, seems to work just fine.
Re: Will Mobile1 Synthetic 5w30 hurt my VW mk7? [Re: bossbrew] #4593932
12/04/17 12:50 PM
12/04/17 12:50 PM
NE Ohio
knerml Offline
knerml  Offline
NE Ohio
Just change the oil at a shorter interval, say between 3K & 5K miles.
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W30 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport 2.0T Castrol Edge 5W40 & OEM/Mann W811/80 Filter
Re: Will Mobile1 Synthetic 5w30 hurt my VW mk7? [Re: bmwtechguy] #4593935
12/04/17 12:51 PM
12/04/17 12:51 PM
US
bossbrew Offline OP
bossbrew  Offline OP
US
This is what I was found out after some research. Thanks for confirming, and I'll definitely change early.
Dave
Originally Posted By: bmwtechguy
Main difference is the HTHS rating of the oil. Oils formulated for German cars usually have a higher HTHS rating than oils formulated for domestics. The main reason is the higher speed limits those cars see in some places like Germany. Sustained high speed driving such as 100-120 mph will generate higher oil temps that require a higher HTHS rating that VW specs. Otherwise with normal 70-85 mph driving here in moderate temps, you should have no trouble with regular DEXOS 1 rated Mobil 1 5W-30 full synthetic. I would use this current oil without worries, maybe change a couple thousand miles sooner, though instead of waiting the whole duration.
Re: Will Mobile1 Synthetic 5w30 hurt my VW mk7? [Re: bossbrew] #4593970
12/04/17 01:22 PM
12/04/17 01:22 PM
MD
onemig Offline
onemig  Offline
MD
Bossbrew,
Like HemiHawk said, yes, change it immediately since you are still under warranty, like today after work. LOL
Re: Will Mobile1 Synthetic 5w30 hurt my VW mk7? [Re: bossbrew] #4593974
12/04/17 01:28 PM
12/04/17 01:28 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Mobile 1?!
Must be an imposter. It's likely too late.
What engine? The 5 pot or the 4 turbo? was ther a 2L NA motor too?
Then I realized ?!... wacha smoking over there in LA LA land?
2014 Nissan Rogue S CVT, OC#10 47272mi-QSUD10W30+5w20 Toughguard Filter; '17 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Will Mobile1 Synthetic 5w30 hurt my VW mk7? [Re: bossbrew] #4594023
12/04/17 01:59 PM
12/04/17 01:59 PM
US
bossbrew Offline OP
bossbrew  Offline OP
US
Well, it started out just fine... grin
Re: Will Mobile1 Synthetic 5w30 hurt my VW mk7? [Re: bossbrew] #4594035
12/04/17 02:08 PM
12/04/17 02:08 PM
PA,US
HemiHawk Offline
HemiHawk  Offline
PA,US
The other thing you could do... suck the 5w30 out using a fluid extractor, and keep it for yard equipment if you have any. The exactor could help if you change using that method in the future.
2017 VW GTI sport
1995 Mustang GTS
Re: Will Mobile1 Synthetic 5w30 hurt my VW mk7? [Re: bossbrew] #4594124
12/04/17 03:19 PM
12/04/17 03:19 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
The oil will work better if you leave the "e" off of Mobile (lol).
I'd be willing to bet that one could use Mobil 1 5w-30 in any modern engine even if it's not the correct spec and it would not actually damage the engine under normal (non-track or heavy towing) use.
If one were traveling cross country and discovered that their oil was a quart or two low, one could top off with Mobil 1 5w-30 and there would be no practical way to prove there would be any damage or increased wear (again, excluding track or heavy towing use). Mobil 1 5w-30 may or may not be the best engine oil on the market but it's fair to say it could be considered a universal oil or in the case of topping off, a universal donor.
Now, let the flames begin...........
Re: Will Mobile1 Synthetic 5w30 hurt my VW mk7? [Re: bossbrew] #4594165
12/04/17 03:55 PM
12/04/17 03:55 PM
US
bossbrew Offline OP
bossbrew  Offline OP
US
No flames here, but I knew that "Mobile" looked wrong...I shoulda checked.
Re: Will Mobile1 Synthetic 5w30 hurt my VW mk7? [Re: bossbrew] #4594946
12/05/17 12:26 PM
12/05/17 12:26 PM
California
nthach Online content
nthach  Online Content
California
You should be OK, it's less than "optimal" for a German engine as ACEA specs put more weight on HTHS and NOACK than the more CAFE-focused API/ILSAC specs, because Autobahn. The Germans do allow for API-spec oil for topping off and in emergencies. Ideally, change your oil when it's convenient to VW-approved oil - no need to do it right away. Highway 1 and 17 aren't exactly the Autobahn either.
The GM dexos standards are solid benchmarks IMO.
