"synthetic" gear oil and LS additive?
by nthach
06/19/18 01:54 PM
Supertech wix ST8 5514 miles
by jakewells
06/19/18 01:38 PM
Review - Sonax Spray and Seal.
by PimTac
06/19/18 01:36 PM
Lets Get a True Group 4 Sticky going!
by KMJ1992
06/19/18 12:17 PM
Rotella 10W40
by jakewells
06/19/18 10:43 AM
Extend WiFi Range at the Laptop?
by clarkflower
06/19/18 10:40 AM
Silicone containing waxes
by mjoekingz28
06/19/18 09:44 AM
Matrix totaled
by circuitsmith
06/19/18 08:32 AM
Door rust problems
by Dave Sherman
06/19/18 07:51 AM
2016 Honda Civic problems
by dbias
06/19/18 07:39 AM
Royal purple 75-140 in a subaru rear
by 91camarosRS
06/19/18 07:32 AM
OCI. With short trips. Nissan 4 liter
by Gawardawg
06/19/18 06:52 AM
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
06/19/18 06:41 AM
Honda Accord Needs Shocks; Front, Back, or Both?
by tc1446
06/19/18 05:50 AM
How much oil does your oil filter hold?
by Snagglefoot
06/19/18 05:44 AM
better day
by mx5miata
06/19/18 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
06/19/18 05:17 AM
People Watching ....Airport style.
by ZZman
06/19/18 04:24 AM
Subaru's at play...
by OneEyeJack
06/19/18 03:50 AM
Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
96 registered (1JZ_E46, 28oz, 97f150, 2strokeNorthstar, 69Torino, 4WD, 9 invisible), 1717 Guests and 34 Spiders online.
65265 Members
67 Forums
285598 Topics
Page 1 of 2 1 2 >
#4593075 - 12/03/17 01:52 PM Charging...... Lithium-ion batteries (Li-ion)
Warstud Offline
Loc: MIchigan
When do you charge your devices that use Li-ion batteries?
#4593087 - 12/03/17 02:11 PM Re: Charging...... Lithium-ion batteries (Li-ion) [Re: Warstud]
JHZR2 Offline
Loc: New Jersey
Li-ion batteries get maximum cycle life when the batteries are kept in the narrowest state of charge range possible. That usually also means some middle of the road state of charge. Oxidation is more likely to occur at high state of charge, and some protective circuits won't allow charging if a battery discharges (use plus self discharge) too low.
It is important to fully discharge and fully charge from time to time, to help calibrate the algorithms and Management systems. Some batteries also balance cells, and that often needs a pack to be topped up.
I leave my tool batteries partially charged as much as possible. I don't let them go too low, but also don't let them go too high needlessly.
#4593100 - 12/03/17 02:23 PM Re: Charging...... Lithium-ion batteries (Li-ion) [Re: Warstud]
Kamele0N Offline
Loc: Slovenia
They are best when charging between 40-80%......you have to discharge them completely from time to time just to re-calibrate them.
For a long term storage......leave battery @40%
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD various 10w40
#4593104 - 12/03/17 02:26 PM Re: Charging...... Lithium-ion batteries (Li-ion) [Re: Warstud]
JC1 Offline
Loc: Oshawa, Ontario Canada
Depends on how many of them I have.
For my dewalt 20v tools, I have 7 different Li-ion batteries. I could let them run down before recharging. My oldest Dewalt 20V batteries are from 2011 and are working fine.
Other things like floor sweepers, I may top up the charge when I can tell it's running low.
I do believe that all these batteries should be run down from time to time before recharging.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Wix Filter
1997 Honda Civic CX 5w-30 PPPP/Mahle Filter
#4593141 - 12/03/17 03:06 PM Re: Charging...... Lithium-ion batteries (Li-ion) [Re: Warstud]
demarpaint Offline
Loc: NY
Can a new Li-ion battery be left as is for a long period of time w/o removing it from its original packaging and charging it?
God Bless Our Troops
#4593143 - 12/03/17 03:08 PM Re: Charging...... Lithium-ion batteries (Li-ion) [Re: Warstud]
dishdude Offline
Loc: Phoenix
How does cell phone fast charging impact longevity? I have an S7, it's crazy how fast it will charge if you turn that option on. I'm thinking it can't be good for battery health so I try not to use it.
2018 Challenger SRT
#4593162 - 12/03/17 03:37 PM Re: Charging...... Lithium-ion batteries (Li-ion) [Re: demarpaint]
Warstud Offline
Loc: MIchigan
I just un-packaged a new 18650 battery I had for my flashlight and put it on the charger and it showed it was very low. So I would say go ahead and charge it up.
#4593186 - 12/03/17 04:17 PM Re: Charging...... Lithium-ion batteries (Li-ion) [Re: dishdude]
raytseng Offline
Loc: CA
The reason why the fast charging on galaxy is fine is because the battery and electronics is natively 9v battery and not the 3.7/4.2 that matches the standard usb spec. If anything charging natively should be better as you don't need to use the extra circuitry to
step up the voltage.
If you want to maximize your battery wear,you are better off spending your effort to disconnect charging when you hit 80 to 90% rather than letting it go to 100%.
Edited by raytseng (12/03/17 04:17 PM)
#4593241 - 12/03/17 04:53 PM Re: Charging...... Lithium-ion batteries (Li-ion) [Re: Warstud]
raytseng Offline
Loc: CA
im actually wrong above. please ignore
#4593251 - 12/03/17 04:57 PM Re: Charging...... Lithium-ion batteries (Li-ion) [Re: Warstud]
demarpaint Offline
Loc: NY
I was looking to keep it as a back up, I have three of them, and only need two at the moment. Or is leaving it as new and unused bad for it?
#4593391 - 12/03/17 07:18 PM Re: Charging...... Lithium-ion batteries (Li-ion) [Re: demarpaint]
Warstud Offline
Loc: MIchigan
I doubt removing it from it's package will hurt anything. But put it on a charger and see what it says. What are the batteries for ? and what info does the charger give you...Volts or percentage charged.
#4593479 - 12/03/17 08:48 PM Re: Charging...... Lithium-ion batteries (Li-ion) [Re: demarpaint]
JHZR2 Offline
Loc: New Jersey
Depends upon how long is long. Regulations require them to be shipped around 30% charge. If you figure they lose 1-2% per month, go much beyond that and it may not be able to accept a charge any more.
#4593481 - 12/03/17 08:50 PM Re: Charging...... Lithium-ion batteries (Li-ion) [Re: demarpaint]
JHZR2 Offline
Loc: New Jersey
It's not bad for it really, but they will calendar age and lose capacity and power performance regardless of if it's used.
If you wanted to store it, I'd add a few percent SOC and store it in a refrigerator.
#4593608 - 12/04/17 12:25 AM Re: Charging...... Lithium-ion batteries (Li-ion) [Re: Warstud]
SubLGT Offline
Loc: Idaho
This blog article from a battery researcher at Argonne National Labs is worth reading:
http://thisweekinbatteries.blogspot.com/2016/11/tips-on-extending-battery-life-from.html
Quote:
Donít charge them too high
Donít swing them too wide
Keep the temperature low to extend their life.
Just to be clear: These rules are for Li-ion batteries; for phones, laptops, cars etc. Not for other kinds of batteries. And not for every Li-ion battery known either; but the most popular ones.
#4594216 - 12/04/17 05:18 PM Re: Charging...... Lithium-ion batteries (Li-ion) [Re: JHZR2]
demarpaint Offline
Loc: NY
Thanks, I might just rotate it in.
Page 1 of 2 1 2 >
