The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
New (old) car inbound
by BeerCan. 09/20/18 02:42 PM
Ford AWD PTU fluid always black
by Raven. 09/20/18 02:34 PM
PC not charging
by sleepery. 09/20/18 01:53 PM
Can alternators make noise?
by Benzadmiral. 09/20/18 01:21 PM
Pr 1970 Superbirds For sale - Barn Find
by user52165. 09/20/18 12:32 PM
Fram Ultra Air Filters
by StevieC. 09/20/18 12:20 PM
Change oil filter or not. Very low miles
by Martin10. 09/20/18 11:37 AM
Toslink optical audio cable (plastic) experience
by ffhdriver. 09/20/18 11:30 AM
A woman I work with wants an affair with me!
by Drew99GT. 09/20/18 11:08 AM
ACEA A5/B5 REQUIREMENTS
by Kjmack. 09/20/18 10:56 AM
Carolina Reaper hot peppers
by gman2304. 09/20/18 09:54 AM
New Fram air filter?
by irv. 09/20/18 09:15 AM
Any golf cart experts?
by HawkeyeScott. 09/20/18 09:15 AM
EU Subaru 2.5 FB engine oil
by IMPALA08. 09/20/18 08:16 AM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
112 registered members (Ablebody, 4WD, 53' Stude, 08z06, 2002 Maxima SE, 8 invisible), 1,642 guests, and 52 spiders.
Topics290,728
Posts4,849,208
Members66,021
Most Online3,590
Jan 24th, 2017
Lube for Tool Cabinet Drawer Sliders? #4585488
11/26/17 12:52 PM
11/26/17 12:52 PM
Idaho
SubLGT Offline OP
SubLGT  Offline OP
Idaho
15-20 years ago, I put some "general purpose" grease on the drawer sliders (non ball bearing style) of some of my tool cabinets. Over that time span, the grease has either turned into glue or hardened into a solid, making it difficult to open and close the drawer. No such problems with those drawers where I used motor oil on the sliders.
I have no idea which lube type, a grease or oil, is better at preventing a groove being worn into the slider (non ball bearing).
What do you use?
Re: Lube for Tool Cabinet Drawer Sliders? [Re: SubLGT] #4585531
11/26/17 01:14 PM
11/26/17 01:14 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Lubriplate works very well.
Use a small stainless brush to clean the slides, then use a little acid brush to coat everything with lubriplate.
Re: Lube for Tool Cabinet Drawer Sliders? [Re: SubLGT] #4585611
11/26/17 02:22 PM
11/26/17 02:22 PM
NEUS
Bandito440 Online content
Bandito440  Online Content
NEUS
There are plenty of good options. I used Lubriplate’s food-grade stuff while maintaining equipment at a meat processing facility and butcher shop. They’ve got dozens of greases, so you’ll have to look through them to find something basic with good corrosion resistance. Their basic 100/105 may be best.
https://www.lubriplate.com/Products/Multi-Purpose-Greases
Most importantly, remove the old stuff with solvent, a scraper, or wire brush.
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
Re: Lube for Tool Cabinet Drawer Sliders? [Re: SubLGT] #4585645
11/26/17 02:53 PM
11/26/17 02:53 PM
Toronna
maxdustington Offline
Toronna
Friction slides = "Door Ease" wax pencil. It is used for lubricating doors and sliding windows. It actually helped one of my windows from freezing shut in the winter. I bought it for my toolbox though.
I bought a mint 1975 dated Proto (Waterloo) 27" stack in the beginning of 2015 I believe. I cleaned the slides completely with alcohol and q tips and then relubed with door ease as was suggested on the garage journal. It is still smooth although some of the slides were a little tweaked as I recall. My bottom drawer is probably as heavy as a DIYer would fill it and is fine. If you're leaving it in an unheated garage I might use grease for corrosion protection, but mine is indoors.
03 Jetta AWP/09A 200k kms
Edge 0W40 + Mann 719/30
Re: Lube for Tool Cabinet Drawer Sliders? [Re: Linctex] #4585656
11/26/17 03:03 PM
11/26/17 03:03 PM
Idaho
SubLGT Offline OP
SubLGT  Offline OP
Idaho
Originally Posted By: Linctex
Lubriplate works very well...
What happens to it over a 20 year time span in an uninsulated garage? Does it harden or become very sticky? I can't remember exactly what greases I tried in the past, but it might have included white grease and chassis grease.
Re: Lube for Tool Cabinet Drawer Sliders? [Re: SubLGT] #4585962
11/26/17 07:09 PM
11/26/17 07:09 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Anything will solidify up over time. Frankly I'm more surprised at the fact that a thin coat of oil was still there/functional (or was it?).
Id use just the thinnest coating of grease after flushing out a bit with Wd-40. That's one of the functions I think wd-40 is best for. Even if you decide to use a heavy oil (or a 00 grease is actually what I'd look to use), I'd still flush out the old oil residue.
Re: Lube for Tool Cabinet Drawer Sliders? [Re: SubLGT] #4586069
11/26/17 08:49 PM
11/26/17 08:49 PM
Lakeside CA
another Todd Offline
Lakeside CA
light weight oil. Any grease risks getting sticky over time.
2015 Ford F250 Diesel Crew Cab FX4
2017 Ford Escape 2.0
2002 GMC Yukon
2015 Hyundai Accent
2008 Yamaha Rhino 700 FI
Re: Lube for Tool Cabinet Drawer Sliders? [Re: SubLGT] #4586286
11/27/17 06:56 AM
11/27/17 06:56 AM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
Another vote for general purpose oil. I use CRC brand in a spray can available at the hardware store.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Lube for Tool Cabinet Drawer Sliders? [Re: SubLGT] #4586430
11/27/17 10:33 AM
11/27/17 10:33 AM
Texas
4WD Online confused
4WD  Online Confused
Texas
0w16
Re: Lube for Tool Cabinet Drawer Sliders? [Re: another Todd] #4586553
11/27/17 01:28 PM
11/27/17 01:28 PM
Idaho
SubLGT Offline OP
SubLGT  Offline OP
Idaho
I came across this little bit of info, about grease aging:
Quote:
During an extended operating period, the oil content of the grease slowly dissipates through creep, evaporation and oxidation. As the grease dries, it stiffens and darkens with its loss of the ability to lubricate.
To obtain extended operating periods, an oxidation inhibitor is essential in premium and multipurpose greases, along with their usual rust inhibitor. The common antiwear and extreme pressure additives in these greases greatly reduce the oxidation life and correspondingly require more frequent relubrication in ball and roller bearing service.
http://www.machinerylubrication.com/Read/970/best-grease-reliability
Re: Lube for Tool Cabinet Drawer Sliders? [Re: SubLGT] #4587190
11/28/17 06:13 AM
11/28/17 06:13 AM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
Go ahead and use the grease like you have in the past. Only take a few minutes every couple of months to add a few drops of oil to the tracks. That will help keep the grease from drying out. I always use a combination of grease with a bit of oil on things like auto pistol slides and bolt lugs. It helps keep the lubricant where it needs to be, because it helps improve it's flow. But it doesn't make it so runny that it won't stay where it's put. The best of both worlds, so to speak.
Re: Lube for Tool Cabinet Drawer Sliders? [Re: 4WD] #4587831
11/28/17 06:17 PM
11/28/17 06:17 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
Originally Posted By: 4WD
0w16
LOL
I nominate this the new BITOG punchline. Use it everywhere possible!
Various musings: http://hangfire.net
Re: Lube for Tool Cabinet Drawer Sliders? [Re: HangFire] #4587972
11/28/17 08:08 PM
11/28/17 08:08 PM
Texas
4WD Online confused
4WD  Online Confused
Texas
Exactly ~ then it becomes cheaper than 3 in 1 oil for hinges, wheelbarrow etc …
Re: Lube for Tool Cabinet Drawer Sliders? [Re: SubLGT] #4592565
12/03/17 12:46 AM
12/03/17 12:46 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
The same phenomena must by the nature of the contents, occur also to an oil... oils to will creep, evaporate, and oxidize, and they also have AW and EP adds in them...
