Thanks for the help guys. Just to clear things up a bit on the crank puller. From my research I did today it appears the early versions of this crankset didn’t have the self extracting feature. That came later. This one needs the puller from what I can tell.
I’ll put this MT501 bottom bracket in next week when it arrives along with the tools and I’ll update as to what the problem is, if it’s worn out bearings or cracked or whatever I find. If/when I have to replace the bottom bracket again I’ll upgrade it to something better.
Everything will get cleaned up very good and lubed during reassembly. I’ll likely take all the suspensions components apart and lube the pivot points.
