Originally Posted By: andyd
I generally buy carb cleaner to use on the OPE only. It is more versatile than ether.
+1
Look for carb cleaner that has "hydrocarbon propellant" listed on the label, which is propane. You can use it on ANY engine... OPE, car, truck, boat, gas, or diesel. If an engine won't fire using carb cleaner, it won't start, and you have a problem that isn't fuel related (unless the engine is flooded).
