Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
The best in personal defense (Humor)
by StevieC. 01/15/19 11:10 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
96 registered members (4WD, 28oz, 53' Stude, 240_Ed, AandPDan, 10 invisible), 2,207 guests, and 33 spiders.
Topics296,643
Posts4,956,508
Members66,950
Most Online2,577
Jan 14th, 2019
Engine runs on the cool side? #4578989
11/19/17 01:48 PM
11/19/17 01:48 PM
Ohio-Pennsylvania
Crowder1980 Offline OP
Ohio-Pennsylvania
Long term lurker , first time poster. Howdy everybody, I have an old Toyota Camry with a 2.2 4cylinder engine , the entire car has been nothing short of phenomenal , going into another upper Midwest winter I've noticed it takes a really long time for the coolant temp needle to sit where it has for 10 years. If I drive around town stop and go it takes even longer, it seems most noticeable under 45 degrees F apx. This car has always seemed to run really cool even in 100 degree weather to where you can almost ready your hand on the exhaust manifold after summer driving with the a/c on, it has almost 200,000 miles and I've used Valvoline 5/w30 almost the entire 10 years I've had it....I'd assume the check engine light would have come on if there were a problem, am I just being paranoid?!
Re: Engine runs on the cool side? [Re: Crowder1980] #4578999
11/19/17 01:56 PM
11/19/17 01:56 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
Sounds like the thermostat is stuck open. Also, never touch the manifold while the car is running, theres no doubt in my mind that that will reach 400 degrees in no time.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI Fuchs 5/40 GT Pro XTL
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Engine runs on the cool side? [Re: Crowder1980] #4579013
11/19/17 02:05 PM
11/19/17 02:05 PM
Eleanor, West Virginia
thunderfog Offline
thunderfog  Offline
My 2016 4Runner is the same way in terms of warming up to full coolant temp in colder weather. Usually takes about 3-5 miles/5-7 minutes or so.
Pretty sure every comment going forward will be to not worry... you've got 200k on it doing what it's doing, so don't sweat it.
'16 4 Runner Kendall GT-1 FS 0w-20
'14 CX-5 GT AWD - QSUD 0w-20
'78 Evinrude 15HP - E/J TC-W3
Honda GCV160 - Pennzoil Ultra 10w-30
Re: Engine runs on the cool side? [Re: Crowder1980] #4579021
11/19/17 02:14 PM
11/19/17 02:14 PM
Ohio-Pennsylvania
Ohio-Pennsylvania
Thanks for the responses, this car asks for so little and has aged so slowly that I'm pretty in tune to how it runs, just out of curiosity can the engine computer pick up a bad thermostat? Thanks again!
2001 Camry
Re: Engine runs on the cool side? [Re: Crowder1980] #4579028
11/19/17 02:18 PM
11/19/17 02:18 PM
canada
hemitom Offline
hemitom  Offline
canada
Thermostat most likely stuck, or low on coolant.
2010 ford fusion.
2014 buick verano.
2012 mustang coupe.
Re: Engine runs on the cool side? [Re: Crowder1980] #4579032
11/19/17 02:20 PM
11/19/17 02:20 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Yes there will be a code for the engine not reaching operating temp.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Engine runs on the cool side? [Re: Crowder1980] #4579033
11/19/17 02:20 PM
11/19/17 02:20 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
I"d replace the thermostat, why drive around in a cold car?
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive236K miles
PPHM 5w30 x 2 Fram Ultra x 2
Currently under the influence of oil shocked2
Re: Engine runs on the cool side? [Re: Crowder1980] #4579051
11/19/17 02:33 PM
11/19/17 02:33 PM
Ohio-Pennsylvania
Ohio-Pennsylvania
I did have the radiator fluid changed, but that was like 2 years ago. Where I'm positive it was green they replaced with red fluid. (Same color as the attached fluid), but that was because the radiator hose dry cracked and leaked a lot out. It was done at a Toyota dealer , trying to find the receipt because I'm almost positive they replaced the thermostat, but like I said this was like 2 years ago.
2001 Camry
Re: Engine runs on the cool side? [Re: Crowder1980] #4579059
11/19/17 02:48 PM
11/19/17 02:48 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Quick and cheap is to block the radiator with a piece of cardboard. Running cool wastes fuel. That can lead to cat trouble. The trouble with thermostats is that they all fail eventually. Buy one that can only fail open as the present one seems to have done. The quality in t'stats is iffy. I would research before replacing. Before doing anything, check the coolant level just for grins.
Thick oil is better grin2
Re: Engine runs on the cool side? [Re: Crowder1980] #4579062
11/19/17 02:51 PM
11/19/17 02:51 PM
VW Fanboy Island
maxdustington Online content
maxdustington  Online Content
VW Fanboy Island
If you can view the temp with a scan tool that would be ideal. When my car had thermostat that was stuck open, it would usually sit at 72 Celsius during city commutes when the thermostat was supposed to open at 88C. You should be able to find what temperature your stock thermostat should open at in order to compare.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Engine runs on the cool side? [Re: Crowder1980] #4579064
11/19/17 02:51 PM
11/19/17 02:51 PM
WI
HoosierJeeper Offline
WI
Color of coolant doesn't mean much, anyone can get any dye added to it. It's possible that the new tstat could be bad again, new ones don't last as long as OEM ones a lot of times. The CEL would come on if it takes long enough to warm up, does it still get up to temp?
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Engine runs on the cool side? [Re: Crowder1980] #4579072
11/19/17 03:02 PM
11/19/17 03:02 PM
Fairfax, VA
TinyVoices Offline
TinyVoices  Offline
Fairfax, VA
I have owned several of these engines and have one now in my mr2. Stuck thermostats are not uncommon and I'd start there. It's a pretty simple repair.
2010 Mazda RX8 Sport - 37k miles - ????
2006 Toyota Matrix XR AWD (Wife) - 130k miles - Valvoline Max Life 5w30
Re: Engine runs on the cool side? [Re: Crowder1980] #4579076
11/19/17 03:04 PM
11/19/17 03:04 PM
Ohio-Pennsylvania
Ohio-Pennsylvania
It does get up to Temp as long as it's above like 2,000 RPM and 40 mph or so. Sitting at a stop light is when the needle seems to sit lower, it really isn't that cold, 45F or so, I seem to remember it doing this last winter but 90% of my driving was 70mph 5 minutes after starting the car, where as now I'm almost strictly stop and go. Turning the heater fan on high definitely drops the needle slightly. The fluid in the radiator is sitting where it always has, and no sign of leakage or odor. Cash strapped right now but I'm going to keep an eye on it.
2001 Camry
Re: Engine runs on the cool side? [Re: Crowder1980] #4579080
11/19/17 03:08 PM
11/19/17 03:08 PM
Fairfax, VA
TinyVoices Offline
TinyVoices  Offline
Fairfax, VA
Sounds like thermostat. I'd start there.
Re: Engine runs on the cool side? [Re: Crowder1980] #4579087
11/19/17 03:13 PM
11/19/17 03:13 PM
ME
eljefino Offline
eljefino  Offline
ME
The dealer most likely would not have done the thermostat when you went in for an emergency repair of a burst hose. Regardless it's broken now, eh?
Don't buy cheap.
