I have 2 Briggs lawnmowers that are stored in a shed. The mowers often sit for 2 or 3 weeks between uses. I use stabilized E0 gas which is kept in Eagle safety cans. Even with all these precautions, I generally have to use a shot of starting ether to get the mower started. I have some back problems and pulling on the starter can be painful. After about 6 pulls I get frustrated and sore and reach for the ether. New spark plugs have not helped.
I wonder if the volatiles are evaporating from the gas in the carb? The mowers run perfect once they start.
Thanks in advance for any advice.
