Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
47 registered members (BlakeB, Big O Dave, andyd, Chris142, Blkstanger, carviewsonic, 7 invisible), 1,095 guests, and 37 spiders.
Topics290,743
Posts4,849,414
Members66,033
Most Online3,590
Jan 24th, 2017
2001 Honda Civic Lx? #4576216
11/16/17 04:27 PM
11/16/17 04:27 PM
Royal Oak MI.
mrjlube Offline OP
mrjlube  Offline OP
Royal Oak MI.
Hi guys,my 2001 civic lx has 170,000 miles and is running great but has started leaking oil. Oil pan is wet and oil is leaking behind the timing belt cover. Mechanic suggests starting with the oil pan $200 to do it. I got a feeling a seal under that timing cover is bad.... dont know what to start with. Car has only seen quaker state green bottle 5w20 all its life. Is high mileage worth a try. Im confused and dont want to get ripped off. I thank you for any advice you may have!
2017 Ford Escape ...ValvolineSynthetic 5w20
2009 kymco xciting 500...amsoil scooter oil...10w40
2001 Honda civic 5 speed 1.7.....Valvoline Maxlife 5w30
Re: 2001 Honda Civic Lx? [Re: mrjlube] #4576220
11/16/17 04:34 PM
11/16/17 04:34 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Back in 2008 you started a thread with this post so you are familiar with HM oils:
I have had 2 escorts go over 200,000 miles on maxlife 5w30 and am thinking of changing my 2002 focus over to it. My focus has 87,000 miles and has been on motorcraft since new. my plan is to keep this car until it dies. My ? is will it hurt to use maxlife in a car with no leaks? What is your opinion on the stuff?
Thank you all so much for your time. Have a great weekend cheers
Depends on how bad the leak is and if you want to or can spend the money to fix it. If the leak(s) are real bad the best solution is to fix it with a new seal. If it's weeping then HM is worth a shot.
Re: 2001 Honda Civic Lx? [Re: mrjlube] #4576239
11/16/17 04:53 PM
11/16/17 04:53 PM
Roswell GA
eagle23 Offline
eagle23  Offline
Roswell GA
My daughter's 2001 Civic had similar symptoms which I mistook, maybe like your mechanic, for a leaking oil pan gasket. I changed that out, but it still leaked, with the wet area still on the oil pan.
On one of the Civic websites, there was a discussion where several owners also thought the pan gasket was bad but after changing it, it still leaked oil.
Someone there suggested (doing this from memory, so my apologies) there is an O-ring on an oil line that is the more likely culprit. The O-ring isn't expensive but seemed to be a PITA to correct; a few hours if I recall correctly, and in about the area you suspect. I tried a few high mileage oils to no avail. For O-rings, my understanding is high mileage oils aren't that effective.
Given her car had about the same miles as yours but she was planning to trade it, we agreed buying oil at $3-4/qt. was a lot easier. That said, if you plan to keep the car a while, as a Civic with 170k is about mid-life, you may want to get that fixed just to eliminate the annoyance. The oil loss was not bad, maybe a quart in 2000-2500 miles.
Your diagnosis sounds more like what's going on vs. the oil pan gasket. IDK if you have to remove the oil pan to do the O-ring, but if you do the pan gasket would be replaced anyway. Maybe see what your mechanic wants to do that.
Re: 2001 Honda Civic Lx? [Re: mrjlube] #4576444
11/16/17 08:24 PM
11/16/17 08:24 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Camshaft oil seals are notorious for leaking on Honda engines. So is the oil cooler O-ring (If equipped)
2001 Chevy Camaro L92/4L80E
2010 Toyota Corolla 2ZR-FE/Auto
Re: 2001 Honda Civic Lx? [Re: mrjlube] #4576479
11/16/17 08:49 PM
11/16/17 08:49 PM
USA
slacktide_bitog Offline
USA
Since it has a timing belt that needs to be changed on a periodic interval, you can always replace it at that time (along with the timing belt and water pump). And if the timing belt is due to be changed anyway...
Re: 2001 Honda Civic Lx? [Re: clinebarger] #4576483
11/16/17 08:51 PM
11/16/17 08:51 PM
Orlando, FL
Mr Nice Offline
Mr Nice  Offline
Orlando, FL
Yep. But luckily it's a very easy fix.
OT: I inherited a 2005 Civic with less than 30K miles, these D17 engines are easy to work on.
Re: 2001 Honda Civic Lx? [Re: mrjlube] #4580797
11/21/17 09:24 AM
11/21/17 09:24 AM
stl
MarkM66 Offline
MarkM66  Offline
stl
My 01 civic started leaking from the box the PCV screws into. Look there too. It's removable, but I believe the intake needs to be removed to do so. I fixed mine once when I did the head gasket at 200k, now at 315k miles, it started again...
Re: 2001 Honda Civic Lx? [Re: mrjlube] #4580811
11/21/17 09:37 AM
11/21/17 09:37 AM
USA
mk378 Offline
mk378  Offline
USA
Oil on the bottom of the engine everyone wants to say oil pan gasket, but it usually ran down from somewhere else. The crank and cam seals are suspect-- would have to remove crank pulley and timing covers to check.
If the car is automatic, the transmission will be well into it's "borrowed time" stage of life. Honda has never had a good automatic but the 2001 one was one of the worst.
Re: 2001 Honda Civic Lx? [Re: mrjlube] #4591031
12/01/17 02:19 PM
12/01/17 02:19 PM
Freehold, nj
iluvhonda Offline
iluvhonda  Offline
Freehold, nj
Had a 02 Civic same engine. Turned out camshaft scored a nice area for the seal to always weep. This was on the belt side.
'99 Prelude 264k Penn Plat Euro 5w-30/Honda A01
'17 Civic Hatch EX 5dr Penn Plat 0W-20 15k Honda A02
