Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
Diesel engines and emissions
by spasm3. 12/16/18 03:31 PM
Experiment time
by 53' Stude. 12/16/18 02:52 PM
2019 2.7L EB - Edge ST & Catch Can
by -SyN-. 12/16/18 02:51 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
70 registered members (A310, ABomb369, 1345, ammolab, 9 invisible), 1,521 guests, and 43 spiders.
Topics295,168
Posts4,929,063
Members66,700
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
Retreads from Tire Recappers #4573132
11/13/17 06:48 PM
11/13/17 06:48 PM
Kelowna, BC, Canada
A310 Online content OP
A310  Online Content OP
Kelowna, BC, Canada
Thought I'd give retreads a try on my sisters Truck and see how they hold up. Very impressed with the quality of casings they gave me and the highway tread is great in the snow. They mounted up great and used what a normal tire would use to balance them and run down the road nice and smooth. They use commercial compounds in the retread so they should last a long time and the best part is they were $94.00 USD. Here's a video of the tire if anyone is interested.
http://www.youtube.com/watch?v=ysPg2qKOUGQ
2009 Ford F-350 (Detroit 4-53T)
2000 Ford Excursion (Triton V10)
1993 Dodge D250 (Cummins 6BT)
Re: Retreads from Tire Recappers [Re: A310] #4573163
11/13/17 07:20 PM
11/13/17 07:20 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Commercial compounds? does that mean they are hard as rock and bad traction?
Re: Retreads from Tire Recappers [Re: A310] #4573172
11/13/17 07:27 PM
11/13/17 07:27 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
There are some retreads out there from a Midwest recapper who uses ground glass in the rubber for winter traction. They work great on ice and packed snow. There is variation among rubber compounds being used. Gotta check each one out, before doing business ...
Re: Retreads from Tire Recappers [Re: A310] #4573175
11/13/17 07:28 PM
11/13/17 07:28 PM
Utah
CKN Offline
CKN  Offline
Utah
Well....the most popular recapped off-road tires that get recommended here ( mentioned in the video) and other truck sites across the web get mixed reviews....at best.
Maybe your source will do better.
Re: Retreads from Tire Recappers [Re: BrocLuno] #4573212
11/13/17 07:58 PM
11/13/17 07:58 PM
New England
Jarlaxle Offline
Jarlaxle  Offline
New England
Those sound like Treadwright's Kedge Grip...they work exceptionally well. Treadwright is in Houston.
1979 Coupe de Ville, 542 stroker, winter storage frown
2011 Crown Vic P71, 5W-20 Super Tech, Super Tech
2011 Sportster 883, winter storage frown
Re: Retreads from Tire Recappers [Re: A310] #4573216
11/13/17 08:03 PM
11/13/17 08:03 PM
Canada
expat Offline
expat  Offline
Canada
I used to work in a retread plant in BC back in the 80's doing Hot caps (like you have) and Bandag.
I guess standards vari across the industry. But our plant did not give any consideration to quality or safety. Case in point: When buffing a tire (stripping the oil rubber off)
you will find rust spots where the tread was punctured part way. You are required to grind out the rust and fill the void with new rubber.
But sometimes you put too much time into a casing only to find it full of rust.
Discarding the tire would cost money, so we were told to put the casing aside until the buffer blades were worn out, then strip out the steel belts on those junk casings with the worn out blades. I hated doing this, it was quite dangerous, steel belt wire would fly everywhere!
After the belt was removed, a layer of Bandag tread gum was wrapped around the casing to make-up, then wraped with new rubber along with the others on the orbitread machine.
Now, if that were not bad enough, the extra rubber would need extra time to cure in the mould, but 'time is money' and the guy running the Hot line needed to work (literally) by seconds when switching moulds. So more often than not all tires were cured the same!
There were lots of other dodges too.
They all look good when they come out of the mould and get the sidewalls painted. ;-)
Re: Retreads from Tire Recappers [Re: A310] #4573221
11/13/17 08:10 PM
11/13/17 08:10 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
A310, the new shop is looking good. Hopefully those tires hold up well for you on the Dodge, I've run a half dozen sets of the Treadwright tires with only one bad one that was promptly replaced. Sorry to hear that your 6.4 in your F350 gave up on you spewing water everywhere. I don't blame you for not bothering to fix it since the engine is coming out anyway.
Speaking of new engine for the F350, I saw that your 4-53T didn't really want to start for you, did you ever get that sorted?
Best of luck with all your projects!
For an oil related thread, will you be retaining the frantz and amsoil bypass systems on the 4-53T?
Luke
Re: Retreads from Tire Recappers [Re: A310] #4573222
11/13/17 08:10 PM
11/13/17 08:10 PM
Coastal South Carolina
edwardh1 Offline
edwardh1  Offline
i see a lot of them, on the side of the road.
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Retreads from Tire Recappers [Re: expat] #4573275
11/13/17 08:55 PM
11/13/17 08:55 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
how does steel belts incased in rubber rust?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Retreads from Tire Recappers [Re: Rand] #4573278
11/13/17 09:00 PM
11/13/17 09:00 PM
Kelowna, BC, Canada
Kelowna, BC, Canada
No, these have great traction on snow and hard packed snow. I drove them pulling a trailer for 2 days in heavy snow and they were great. My sister has 800 miles on them now and loves them.
Re: Retreads from Tire Recappers [Re: edwardh1] #4573281
11/13/17 09:02 PM
11/13/17 09:02 PM
Kelowna, BC, Canada
Kelowna, BC, Canada
This is true, but if you look closely they may be virgin tires and not retreads.
Re: Retreads from Tire Recappers [Re: A310] #4573289
11/13/17 09:14 PM
11/13/17 09:14 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
This has been my experience that a large number are virgin casings and Chinese made bias ply shipping container intermodal trailer tires. Most caps shed due to under inflation before anything else, heat kills everything equally.
Luke
Re: Retreads from Tire Recappers [Re: FlyNavyP3] #4573296
11/13/17 09:17 PM
11/13/17 09:17 PM
Kelowna, BC, Canada
Kelowna, BC, Canada
Thanks Luke, I've bought 6 TreadWrights and pick them up this Thursday. I bought the Wardens with heavy Kedge for the mountain roads here and am really interested in how they perform. Yes my 6.4 decided to need a front cover just while I was painting my new shop, so I put an old 2000 ford excursion on the road while I swap engines in my F350. Four of the new TreadWrights are going on the excursion as it has worn out tires on it at the moment. The failed start was a bad starter solenoid, which I'll get to when I do the swap. I did manage to start is later, but did not record the start. It take 4-5 start cycles before it started, and really doesn't like cold starts. To address this I'll be installing a block heater, ether cold start and a Webasto heater. With that sort of redundancy I can depend on it in any weather anywhere in winter. I'll be keeping the Amsoil and Frantz bypass system, but will be running Delo 100 Sae 40. I'll be starting the swap in January, so very excited to get it on the road.
Re: Retreads from Tire Recappers [Re: A310] #4573307
11/13/17 09:33 PM
11/13/17 09:33 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
All the ones that I've found are complete treads, with steel wires intact.
I would love to find just the tread, no belts, as cutting the rubber off the belts to make flipflops is an absolute pain.
Re: Retreads from Tire Recappers [Re: edwardh1] #4573325
11/13/17 09:51 PM
11/13/17 09:51 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
This! My buddy had a business and he ran retreads on his fleet for two years and he said he lost at least one tire on each of his trucks he got rid of them all. He said his time and the safety of his employees and equipment much out weighed getting by cheap. Which he said wasn't cheap because when he switched over to better tires he saved money in the long run and made deliveries on time.
2004 Corolla 126884
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Page 1 of 3 1 2 3
