48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
120 registered members (2K2AcuraTL, amblerman, 64bawagon, 97f150, 28oz, 12 invisible), 1,977 guests, and 42 spiders.
Topics295,214
Posts4,930,165
Members66,716
Most Online2,553
Oct 27th, 2018
Any BBQ/Grilling experts? :) #4570839
11/11/17 12:32 PM
11/11/17 12:32 PM
VA
maverickfhs Offline OP
VA
Question for experts, for an outdoor charcoal grill. Do you leave charcoal in the grill after you are done and also how do you kill fire?
Also, can moisture cause any issue with charcoal? Don't want to be struggling lighting it up if I have to use grill after 3-4 months gap.
Thanks for all the tips and help.
2006 Civic EX 202K/AT
2006 Acura TSX 180K/AT
Re: Any BBQ/Grilling experts? :) [Re: maverickfhs] #4570849
11/11/17 12:40 PM
11/11/17 12:40 PM
wi
dave123 Offline
dave123  Offline
wi
Kill fire lid on vents closed clean out day or two later not big deal just get ash out. Clean grill grate ever time after use. Get yourself a Weber chimney best investment you will ever make store charcoal in dry place shouldn't have a issue.
Re: Any BBQ/Grilling experts? :) [Re: maverickfhs] #4570867
11/11/17 12:53 PM
11/11/17 12:53 PM
Salt Lake City, UT
Wasatch1 Offline
Wasatch1  Offline
Salt Lake City, UT
I use a Weber kettle and shut all the vents to stop the fire. Whatever coals I have left I just knock the ash off and use next time. However if you're only grilling every 4 months I'd just let them burn out and use new. Mold tends to form more on the grease coated areas. I leave all the vents om my grill open to prevent this.
2012 Nissan Frontier V6 CC.
PP 5W-30, FRAM XG7317
Re: Any BBQ/Grilling experts? :) [Re: maverickfhs] #4570872
11/11/17 12:56 PM
11/11/17 12:56 PM
Nebraska
BJD78 Offline
BJD78  Offline
Nebraska
I do not consider myself an expert, but I have grilled at least 3-4 times per month since retiring from military back in 2013. I have a big 435 sq inch Thermos Charcoal grill and when I cook a couple of slabs of ribs for 4-5 hours I have a lot of ashes. I just close the lid and let it burn out, then save the ashes as my wife mixes it in with soil and compost and puts it on our garden. Only use the plain charcoal not the "match light" type and never use charcoal starter fuel. I use a chimney starter which I made out of an old metal 5 gallon pail Keep unused charcoal in a water tight tote as moisture can and will make it difficult to start. Charcoal does has a tendency to absorb moisture especially if ambient air is humid, so best kept in a water proof container or store it in a large garbage bag.
2010 Forester:122K
2009 Sonata :189K
2010 Tucson:55K
OCI 5K using the cheapest dino oil I can buy,usually NAPA or TSC Travelers oil.
Re: Any BBQ/Grilling experts? :) [Re: Wasatch1] #4570878
11/11/17 01:02 PM
11/11/17 01:02 PM
Cali
Malo83 Offline
Malo83  Offline
Cali
I have three Weber kettles and one 55 gal smoker, after grilling or smoking i leave the lid open so that coals finish burning out to ash, easy to clean out ashes, this also burns off all the residue on the grates, come back later and run a grate cleaner across the grates, no sticky food left. cheers
Re: Any BBQ/Grilling experts? :) [Re: maverickfhs] #4570954
11/11/17 02:48 PM
11/11/17 02:48 PM
CA
raytseng Offline
raytseng  Offline
CA
If youre grilling like you said one time every 3 months why are you saving like 5 lumps of half burned coals, just open up and burn it out.
agree with getting a chimney starter
if the issue is you aren't sure how much fire you need because youre cooking for just a few people, use the weber mini chimney which can get a smaller amount of briquettes going fast that you have coals for a second cook in 10min.
final tip also getting the weber cubes to start your chimney a lot faster than the trad. newspaper or sticks or and papertowel and oil.
it is only like 3.99 for a lot of cubes and you dont have the paper ash if you use the traditional paper.
if you're grilling everyday maybe you graduate past the cubes, but i highly suggest you just spend the $3.99 for 1 box until you get the hang of it (store in a ziplock bag).
Re: Any BBQ/Grilling experts? :) [Re: maverickfhs] #4571355
11/11/17 10:03 PM
11/11/17 10:03 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
Moisture has a much larger effect on charcoal briquets than lump charcoal.
I've found a product I like even better than the Weber starter cubes with a chimney starter. The BBQ Wood Flavors brand starter cubes put out lots more flame per cube.
https://www.bbqwf.com/speciality-products/
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Any BBQ/Grilling experts? :) [Re: Wasatch1] #4571762
11/12/17 12:08 PM
11/12/17 12:08 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
I do the same to stop the fire and to reuse left over larger coals. Every so often I just dump the fine dust out on the roses.
Ive never seen mold/mildew, but I really only use mine as a base to smoke planked salmon. While I love a charcoal grill, a gas grill just makes most things easier, if the charcoal and heat profile isnt going to do a lot for the flavor.
I always start my charcoal with an electric heater. Works great every time. I have a bag od charcoal that is years old, no issues. I re-use the bigger bricquettes/lumps, no issues. I do always add new in there when lighting though...
Once I have the charcoal started, I always add a handful or two of pre-soaked smoking wood chips.
Re: Any BBQ/Grilling experts? :) [Re: maverickfhs] #4572964
11/13/17 03:22 PM
11/13/17 03:22 PM
VA
VA
Thanks guys, very helpful advice and input. Going to jot down all the advice thumbsup
