VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
29 registered members (Burks21, 4WD, A1O, antik, billt460, 5 invisible), 513 guests, and 54 spiders.
Topics286,267
Posts4,905,521
Members67,589
Most Online2,967
Mar 10th, 2019
0W20 Oil Can I use this? #4570595
11/11/17 09:00 AM
11/11/17 09:00 AM
Bucks County, PA
Hot_Ajax Offline OP
Hot_Ajax  Offline OP
Bucks County, PA
My Tacoma calls for 5W30. The truck was manufactured before 0W20 was even thought of. Is this a safe switch or stick with what Toyota says to use? Thanks in advance.
Re: 0W20 Oil Can I use this? [Re: Hot_Ajax] #4570598
11/11/17 09:04 AM
11/11/17 09:04 AM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
I would use either a 5w30 or 0w30.
Re: 0W20 Oil Can I use this? [Re: Hot_Ajax] #4570602
11/11/17 09:14 AM
11/11/17 09:14 AM
Florida
Artem Offline
Artem  Offline
Florida
I second a 0w30 if your wet dream is to have a 0w bottle of oil in the garage.
Even if the truck was supposedly back spec'd for 0w20, WHY would you use it? Better fuel economy? duh
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: 0W20 Oil Can I use this? [Re: Hot_Ajax] #4570605
11/11/17 09:20 AM
11/11/17 09:20 AM
North TX
RTexasF Offline
RTexasF  Offline
North TX
Why change? There's no advantage other than during extremely cold starts....if even then.
Re: 0W20 Oil Can I use this? [Re: Hot_Ajax] #4570628
11/11/17 09:42 AM
11/11/17 09:42 AM
Michigan
ZZman Offline
ZZman  Offline
Michigan
You could but why? A 5w-30 will work perfectly in your climate. The 0w oils are more for super cold climates and to increase very slightly fuel economy and less emissions a little on warm up.
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram TG
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: 0W20 Oil Can I use this? [Re: ZZman] #4570642
11/11/17 10:02 AM
11/11/17 10:02 AM
Florida
Artem Offline
Artem  Offline
Florida
Originally Posted By: ZZman
0w oils are to increase very slightly fuel economy.
Got Proof? I say a pump calculated 0.2mpg increase isn't enough to consider the 0w oil as a sucesss. The 0w is for cold flow, not fuel economy. I wish people would stop repeating this nonsense. The number AFTER the W is what effects fuel economy, after both the engine and oil are up to operating temp.
Re: 0W20 Oil Can I use this? [Re: Hot_Ajax] #4570705
11/11/17 10:58 AM
11/11/17 10:58 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have lot of 0W-20.....
that I mix with 15W-40 before I pour into an engine grin
Re: 0W20 Oil Can I use this? [Re: Hot_Ajax] #4570710
11/11/17 11:03 AM
11/11/17 11:03 AM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
OP I used 0w20 in my truck with 240k miles on it, it is a 5vz fe v6 and it preformed just fine. Low end torque seemed better and so was idle.
I also run 0w20 in my mini van with the 3.3 v6 that pushes more horsepower than my truck. It preforms amazing in this engine. 282k miles and counting
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: 0W20 Oil Can I use this? [Re: Hot_Ajax] #4570720
11/11/17 11:12 AM
11/11/17 11:12 AM
PimTac Offline
PimTac  Offline
On another thread, it was mentioned that PP dexos g2 was on the thin end of a 30wt for their 5W30. With all the certs it has I would look into running that rather than using the 0w.
Cannot see signatures any longer so it doesn’t matter.
Re: 0W20 Oil Can I use this? [Re: Hot_Ajax] #4570825
11/11/17 01:10 PM
11/11/17 01:10 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
I'd keep using the 5w-30 but if you have some of the 0w-20 and you want to use it up. I would just mix a quart of it into your next OCI. Especially if its going to be winter time.
2004 Corolla 130017
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 0W20 Oil Can I use this? [Re: Hot_Ajax] #4570835
11/11/17 01:28 PM
11/11/17 01:28 PM
New England
NibbanaBanana Offline
New England
0W-20.......... Dinosaur wizz.
1993 Ford E350 5.8L, 68K
2002 Ford E150 4.2L, 85K
2006 Chevy Aveo 1.6L 215K
2013 Kia Reo 1.4L, 101K
7500 OCI, M1 5-30 winter, M1 10-30 summer
Re: 0W20 Oil Can I use this? [Re: Artem] #4570942
11/11/17 03:27 PM
11/11/17 03:27 PM
HondaBroMike Offline
Thank you, okay.
Re: 0W20 Oil Can I use this? [Re: TheKracken] #4570944
11/11/17 03:28 PM
11/11/17 03:28 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
Originally Posted By: TheKracken
OP I used 0w20 in my truck with 240k miles on it... Low end torque seemed better
Did that make sense when you typed it?
Re: 0W20 Oil Can I use this? [Re: Hot_Ajax] #4570955
11/11/17 03:48 PM
11/11/17 03:48 PM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
I wish people would drop the nonsense you need 0W20 for cold weather.
I lived in Pennsylvania mountains for 35 years and seen a multitude of starts on straight 30 and 40 wt and 10w30s and 10w40s.
These oils, contrary to popular belief do not solidafy at 32 degrees.
It's about cafe, nothing else.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: 0W20 Oil Can I use this? [Re: Hot_Ajax] #4570967
11/11/17 04:03 PM
11/11/17 04:03 PM
Michigan
ZZman Offline
ZZman  Offline
Michigan
True at 32 degrees but in Michigan we often get near zero.
