The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
2015 Acura TLX 3.5L V6
by blackdiamond. 03/23/19 06:20 PM
Group 3 oil with best heat stability?
by LSXHitman. 03/23/19 05:24 PM
FixItDad28, RandomJoe, Sciascia, sosp197, peppercorn
67597 Registered Users
25 registered members (c502cid, dishdude, carlprop, csandste, Blkstanger, 3 invisible), 740 guests, and 56 spiders.
Topics286,320
Posts4,906,408
Members67,597
Most Online2,967
Mar 10th, 2019
Napa 1269 / Wix 51269 #4570398
11/10/17 11:47 PM
11/10/17 11:47 PM
Southeast
BlakeB Offline OP
BlakeB  Offline OP
Southeast
This filter was on my 2007 Tacoma (A750F) for about 4 years/20K miles. The Toyota WS was flushed via the cooler line at 58,825 in July 2013, spin-on (1269) was added around that time. The pan was drained and filled with Valvoline Maxlife ATF along with a spin-on filter change(1269) at 80,102 miles on 4/17/17. The debris on the top of the filter and inside the canister are from me cutting it open with an angle grinder and cutoff wheel. I also had a strong magnet on the outside of the canister, it caught a little metal, but really isn't necessary IMO. The filter is plumbed in after the radiator, but before the aux cooler. I have one more 1269 in my stash of filters, after that I'm thinking that I'll just use the same filter as I'm using on my engine, a Thailand made Toyota 90915-YZZD3. I have also considered an M1-209 or XG8A. Thoughts?
Re: Napa 1269 / Wix 51269 [Re: BlakeB] #4570713
11/11/17 11:05 AM
11/11/17 11:05 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Turn your grinder wheel so the sparks and crud flies out, not into the can.
That big of a filter should last the life of the vehicle.
Re: Napa 1269 / Wix 51269 [Re: BlakeB] #4572316
11/12/17 11:57 PM
11/12/17 11:57 PM
Southeast United States
TheLoneRanger Offline
Looks good. Remember though that transmissions don't have the black carbon that we're used to seeing with engine filters. Trans clutch material is near the color of the filter media, so there's probably more debris caught in the filter than what's apparent.
Still, I'll bet the filter would easily go 100K miles.
Some days you eat the bear, some days the bear eats you.....
Re: Napa 1269 / Wix 51269 [Re: TheLoneRanger] #4579848
11/20/17 09:41 AM
11/20/17 09:41 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
External transmission filters excite me...don't judge.
Re: Napa 1269 / Wix 51269 [Re: Kira] #4579981
11/20/17 12:09 PM
11/20/17 12:09 PM
Southeast
BlakeB Offline OP
BlakeB  Offline OP
Southeast
So what kind of filter are you running?
