more dumb questions!! infiniti Q50
by Robertslowpoke. 03/23/19 06:23 AM
VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
60 registered members (Astro14, AndyB, antik, aircooled, 10 invisible), 1,120 guests, and 52 spiders.
Topics286,271
Posts4,905,682
Members67,589
Most Online2,967
Mar 10th, 2019
Bleeding PS system #4570162
11/10/17 06:45 PM
11/10/17 06:45 PM
WI
HoosierJeeper Offline OP
WI
I've done a google search but I'm getting a variety of answers from people that I don't quite trust. Replaced the PS pump and cooler in my Liberty. Here's what I'm thinking of doing:
1. Fill reservoir to full line
2. Jack it up
3. Cycle the wheels near lock to lock 25 times
4. Check fluid level and refill if needed
5. Cycle wheels again 25 times
6. Start it and hope for the best?
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Bleeding PS system [Re: HoosierJeeper] #4570167
11/10/17 06:47 PM
11/10/17 06:47 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Put fluid in, idle the car and keep adding until at a safe stable level, shut off, jack the car up so the front wheels are off the ground, start the car again and have someone turn the wheel all the way in both directions back and forth as you keep an eye on the fluid. A few times is enough then take it for a drive and keep an eye on the fluid for the next couple days. It's what I do with my vehicles when needed.
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: Bleeding PS system [Re: HoosierJeeper] #4570171
11/10/17 06:49 PM
11/10/17 06:49 PM
ME
eljefino Online content
eljefino  Online Content
ME
Why jack it up? Nothing like a little load on things to burp the bubbles out.
Re: Bleeding PS system [Re: eljefino] #4570173
11/10/17 06:50 PM
11/10/17 06:50 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
You want as little stress on the system as possible for the initial burping.
Re: Bleeding PS system [Re: HoosierJeeper] #4570174
11/10/17 06:50 PM
11/10/17 06:50 PM
Michigan
jkasch Offline
jkasch  Offline
Michigan
When it quits making noise should be enough back and forth.
Re: Bleeding PS system [Re: StevieC] #4570175
11/10/17 06:52 PM
11/10/17 06:52 PM
ME
ME
Stress how? You can drive a PS system when it's dry as a failsafe just by man-handling it. There'll be enough residual fluid to lubricate stuff.
Re: Bleeding PS system [Re: HoosierJeeper] #4570186
11/10/17 07:00 PM
11/10/17 07:00 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Do that with a dry pump and see what happens... It's different when a belt snaps and the pump stops and you need to "Man Handle" it. Yes I have done this too.
Re: Bleeding PS system [Re: HoosierJeeper] #4570190
11/10/17 07:03 PM
11/10/17 07:03 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
Wheels off the ground makes it so much easier to bleed without the pump running, way easier on you. Usually within 3-5 locks manually gets most out, then Ill start it and go watch the level with some in hand to top it as it sucks it down. Quick road test, then recheck, and usually its pretty good.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Bleeding PS system [Re: HoosierJeeper] #4570284
11/10/17 08:53 PM
11/10/17 08:53 PM
MA
AandPDan Offline
AandPDan  Offline
MA
2. Jack it up
That's exactly how Mopar wants you to do it.
Re: Bleeding PS system [Re: StevieC] #4570296
11/10/17 09:08 PM
11/10/17 09:08 PM
ME
ME
It's not dry if you put fluid in... Not being a douche but look at all the cars with slow leaks that finally alert the driver by making moaning noises from the cavitation or whatever. Add fluid, drive on. drive
Re: Bleeding PS system [Re: HoosierJeeper] #4570301
11/10/17 09:22 PM
11/10/17 09:22 PM
MI
doitmyself Offline
doitmyself  Offline
MI
My 2014 Jeep factory service manual procedure is to apply vacuum at the power steering fluid reservoir for about 3 minutes. Repeat until the fluid level no longer drops. Refill to the proper mark. Then, start up the engine and do three lock-to-lock wheel turns. Here's an example: http://www.wkjeeps.com/TSB/tsb_wk_1900805.pdf
The method discussed by the rest of you seems to be the most prevalent on You Tube.
Re: Bleeding PS system [Re: HoosierJeeper] #4570321
11/10/17 10:02 PM
11/10/17 10:02 PM
WI
WI
I did what I outlined in my first post and then ran it for a minute, it sucked it down, refilled, fired it back up and it sucked more down, topped it up and let it run till the fluid level didn't drop again. Going to keep checking it.
Re: Bleeding PS system [Re: HoosierJeeper] #4570324
11/10/17 10:05 PM
11/10/17 10:05 PM
Arizona
JGmazda Offline
JGmazda  Offline
Arizona
I too was wondering how to do this. I've watched a few YouTube videos which show disconnecting the bottom reservoir hose and then cycling the steering back and forth until the old fluid stops.
Refill and replace.
Anything wrong with that?
Re: Bleeding PS system [Re: HoosierJeeper] #4570356
11/10/17 10:52 PM
11/10/17 10:52 PM
WI
WI
For just a fluid exchange? I wouldn't disconnect anything. Just get a turkey baster and suck out the reservoir, fill with new, run it for a few days or a week and repeat till it's clean. I don't know how much most PS systems take, but I think my Jeep probably takes about a quart or a little more.
Re: Bleeding PS system [Re: HoosierJeeper] #4570366
11/10/17 11:05 PM
11/10/17 11:05 PM
Arizona
JGmazda Offline
JGmazda  Offline
Arizona
This is what I usually do. However, I've viewed some conflicting procedures detailing "purging" etc. I like your idea of replacing the fluid every few days, however, does this method actually purge the older fluid?
