S ST2008 Joined Jul 18, 2016 Messages 162 Location Canada Nov 5, 2017 #1 Hi Which grease doesn't dry and it's plastic and rubber compatible?
2strokeNorthstar Joined Jul 19, 2017 Messages 3,060 Location Southwest CA, USA Nov 5, 2017 #2 plumbers grease for low temp. Sway bar bushings etc.
S ST2008 Thread starter Joined Jul 18, 2016 Messages 162 Location Canada Nov 5, 2017 #3 Originally Posted By: 2strokeNorthstar plumbers grease for low temp. Sway bar bushings etc. Thanks for the reply. Can you suggest some brands? I need this grease for electronic equipment and plastic gears.
andyd Joined Sep 25, 2004 Messages 9,882 Location Marshfield , MA Nov 5, 2017 #5 Sil Glyde in envelopes
C CR94 Joined Mar 20, 2016 Messages 3,880 Location Western S.C. Nov 5, 2017 #6 Silicone grease of any brand.
S ST2008 Thread starter Joined Jul 18, 2016 Messages 162 Location Canada Nov 5, 2017 #7 Not sure why but, it's hard to find the silicone grease in Canada.
E EdwardC Joined Nov 14, 2013 Messages 2,160 Location Chicago, IL Nov 5, 2017 #8 Try search for dielectric grease at the auto parts store, should work as well as silicone grease.
D Ducked Joined Oct 25, 2012 Messages 4,823 Location Taiwan Nov 5, 2017 #9 Originally Posted By: ST2008 Not sure why but, it's hard to find the silicone grease in Canada. Only readily available rubber-compatible grease in Taiwan is ear-wax. And there isn't very much of that.
D Ducked Joined Oct 25, 2012 Messages 4,823 Location Taiwan Nov 5, 2017 #10 What about CV joint boots? They don't seem to have silicon grease in them. Is that planned obsolescence?
H hiflo Joined Jul 7, 2015 Messages 22 Location mississippi Nov 12, 2017 #11 liquid wrench dielectric anti-seize grease is silicone based # L803 low's has it in the lawn mower section
buck91 Joined Apr 17, 2012 Messages 3,552 Location West Michigan Nov 14, 2017 #12 Triflow "synthetic" grease or Super Lube Multi Purpose Grease.
