Can't get Unifi AP V2 to work on TDS...
by WhizkidTN
06/20/18 07:34 AM
Need mini grease gun
by Duffyjr
06/20/18 07:02 AM
Mazda 6 O2 sensor - CA emission
by Chester11
06/20/18 06:57 AM
Brake Bleeder
by supton
06/20/18 06:56 AM
As close to blowing out as you can get
by wwillson
06/20/18 06:04 AM
changing tranny filter
by Dennisistheman
06/20/18 06:04 AM
From small things...
by Silk
06/20/18 05:57 AM
Anyone signing up for the Space Force
by Shannow
06/20/18 03:58 AM
Pennzoil Platinum at Walmart
by TheLawnRanger
06/19/18 11:21 PM
Mopar OEM and Fram Ultra Oil filters, '18 Jeep JL
by IndyFan
06/19/18 10:45 PM
What’s the odds..
by Eric Smith
06/19/18 09:51 PM
Who can relate?
by Reddy45
06/19/18 09:43 PM
No more oil changes
by goodtimes
06/19/18 09:19 PM
Separating toddlers from their parents?
by fdcg27
06/19/18 08:50 PM
gm 8.6 truetrac
by Spitter
06/19/18 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
06/19/18 08:34 PM
Rockauto 5% off
by Spitter
06/19/18 08:32 PM
fumoto oil valve
by Santo
06/19/18 08:19 PM
Grand solar minimum...
by ridgerunner
06/19/18 07:57 PM
Pentofrost coolant $10 Autozone
by PD001
06/19/18 07:49 PM
Theraven, battleman13, Shassis, Santo, aligoodn
65276 Registered Users
99 registered (andyd, 2004tdigls, 2009Edge, aquariuscsm, 14ecocruze, 12 invisible), 1270 Guests and 41 Spiders online.
65276 Members
67 Forums
285637 Topics
#4562600 - 11/02/17 10:51 PM 2013 Jeep Wrangler | PP Euro L 5w30 | 4,326 miles
davison0976 Offline
Loc: NJ, USA
Was hoping for a little better, but this isn't bad. TBN has held up well which was my concern for ACEA C3 oil on US gasoline containing more Sulfur than diesel fuel. The Jeep is driven mostly in town averaging about 30mph speeds. One way commute is 7 miles. 30 mile highway runs during weekends.
Incidentally, manual says it's ok to use 5w30 ACEA C3 in the Jeep. You kind of have to read between the lines because they say "SAE 5W-30 engine oil approved to Fiat 9.55535-S1 or Fiat 9.55535-S3 may be used when SAE 5W-20 engine oil meeting MS- 6395 is not available." What you'll find is that 9.55535-S1 are ACEA C2 oils and 9.55535-S3 are ACEA C3 oils.
#4562669 - 11/03/17 04:32 AM Re: 2013 Jeep Wrangler | PP Euro L 5w30 | 4,326 miles [Re: davison0976]
demarpaint Offline
Loc: NY
I landed on 5W30 with my 2016 Rubicon as well. I read between the lines too. I went with PU. From what I've been told they shed copper from the oil cooler for a long time. I'm about another 6-8 months away from a UOA.
God Bless Our Troops
#4562671 - 11/03/17 04:41 AM Re: 2013 Jeep Wrangler | PP Euro L 5w30 | 4,326 miles [Re: davison0976]
dlundblad Online   happy
Loc: Indiana
5w30 in my brother's Pentastar too. Not a C3 though. Just Synpower 5w30.
I think it was placed strategically on the next page?
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4562746 - 11/03/17 07:14 AM Re: 2013 Jeep Wrangler | PP Euro L 5w30 | 4,326 miles [Re: davison0976]
SR5 Offline
Loc: Down Under
You did 4300 miles and the TBN was 3.6 which looks good to me given it's a mid-SAPS C3 oil. The iron wear at 12 ppm is fine.
The C3 oils are high HTHS (3.5 cP or above) and typically have KV100 of about 12 cSt for a 30 grade, yours ended up with a finishing KV100 of 10.7 cSt which is bang-on for an ILSAC 30 grade. That's what I like about Euro 30 grades, they finish up where most start.
Yeah, lots of these engines show high copper, it seems fairly normal for them. All up looks like a fine report to me, I recon you could probably go 6000 miles.
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
#4566504 - 11/07/17 07:05 AM Re: 2013 Jeep Wrangler | PP Euro L 5w30 | 4,326 miles [Re: davison0976]
davison0976 Offline
Loc: NJ, USA
Does anyone know if valve guides in Pentastar engine are made of copper alloy? Perhaps that's the reason these engines show copper on a higher side?
#4567169 - 11/07/17 07:37 PM Re: 2013 Jeep Wrangler | PP Euro L 5w30 | 4,326 miles [Re: davison0976]
FlyNavyP3 Offline
Loc: Jacksonville, FL
The valve guides are not copper, they're cast iron or powdered metal, the copper is from the oil cooler.
Luke
#4569017 - 11/09/17 02:59 PM Re: 2013 Jeep Wrangler | PP Euro L 5w30 | 4,326 miles [Re: davison0976]
bigt61 Offline
Loc: Virginia
Great #'s. What were the other oils used? You changed the FF at 104 miles?
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#4569339 - 11/09/17 10:09 PM Re: 2013 Jeep Wrangler | PP Euro L 5w30 | 4,326 miles [Re: bigt61]
davison0976 Offline
Loc: NJ, USA
I probably wouldn't read too much into the earlier results and wouldn't take those as an oil performance indication given the engine was new.
No, FF I changed at 684 miles right after break-in period which is mentioned in the manual. At 104 miles I simply took a sample to see how much wear a brand new engine has to begin with. All this data tells me that UOAs before 30,000 miles are probably meaningless.
#4569936 - 11/10/17 01:14 PM Re: 2013 Jeep Wrangler | PP Euro L 5w30 | 4,326 miles [Re: davison0976]
bigt61 Offline
Loc: Virginia
Thanks for the response - the numbers are consistent overall despite the wide variance in oil brands and type. Engine is still breaking in after 40k. Very good post.
70 Camaro 5.7L 59k
