It's AMSOILŪ, not Amsoil
by Rat407
06/25/18 06:39 AM
VW Passat 2007
by madRiver
06/25/18 06:18 AM
Review: CVJ Remanufactured CV Axles
by The Critic
06/25/18 03:40 AM
Towing without 85w140?
by OilFilters
06/25/18 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
06/24/18 09:10 PM
SAE 90 v 85/140
by Knuckle078
06/24/18 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
06/24/18 08:45 PM
Schaeffer's oil reviews on Amazon
by zfasts03
06/24/18 07:41 PM
Decent MP3 player
by Ed_T
06/24/18 07:08 PM
Letgo
by Donald
06/24/18 06:52 PM
Tire buying advice
by supton
06/24/18 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
06/24/18 06:21 PM
No older cars in New York State?
by Oldtom
06/24/18 06:19 PM
2009 Taurus strut mount noise
by terry274
06/24/18 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
06/24/18 03:36 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
72 registered (2009Edge, 2015_PSD, 63Marauder, badtlc, 10 invisible), 1187 Guests and 36 Spiders online.
65319 Members
67 Forums
285956 Topics
#4560278 - 10/31/17 02:22 PM Is this a failing thermostat?
HawkeyeScott Offline
Loc: El Oeste
2008 Suburban with 5.3 GM motor in it. Just in the last few days it's been very slow to warm up and doesn't
ever get to the 210-degree mark on the temperature gauge, where it normally runs. It's been running about 195 to 205.
Any experience I've ever had with a car not coming up to temp was fixed by a new thermostat. But before I tear into it, I wanted to check here and see if anyone had any other ideas what is causing these symptoms.
Also, I've used Stant thermostats before with good success. Any other suggestions or brands to stay away from, assuming it is a thermostat issue?
Thanks a lot.
#4560285 - 10/31/17 02:30 PM Re: Is this a failing thermostat? [Re: HawkeyeScott]
Kuato Offline
Loc: Colorado
If it is running normally during warmup then I agree - thermostat is sticking in the open position.
Thick vs Thin test: 15k / 43k miles complete
#4560301 - 10/31/17 02:56 PM Re: Is this a failing thermostat? [Re: HawkeyeScott]
DGXR Offline
Loc: California
Just curious, how easy can you see the difference between 205F (current normal) and 210F (previous normal) on the temp gauge?
1995 Corvette base LT1 6-speed
2006 Tacoma 2.7 2wd access cab
#4560304 - 10/31/17 02:57 PM Re: Is this a failing thermostat? [Re: HawkeyeScott]
StevieC Offline
Loc: Ontario, Canada
Most newer vehicles run around 200 - 212F. Older will run anywhere between 195-200F. (There are exceptions)
It's possible that the thermostat is starting to stick open and about to fail.
I had this problem on my Santa Fe. It would be 195 all the time and then one fall it was 188F and shortly thereafter it failed open and wouldn't go past 100F.
'15 Dodge Journey - 90,000 KM's - SSO 5w20
'06 Hyundai Santa Fe - 535,000km - SSO 0w30 (R.I.P)
#4560320 - 10/31/17 03:12 PM Re: Is this a failing thermostat? [Re: HawkeyeScott]
28oz Offline
Loc: Utah, USA
I've used several brands with success. However, my rule of thumb is the harder a part is to replace, the more likely I will use an OEM part. However, it's a thermostat. OEM ones usually don't cost that much anyways.
1990 Nissan 300zx - Castrol Edge Euro 0W-40
2004 Nissan Quest - Pennzoil Platinum Euro 0W-40
2003 Ford Excursion 7.3 PSD - Mobil 1 TDT 5w-40
#4560325 - 10/31/17 03:17 PM Re: Is this a failing thermostat? [Re: DGXR]
Loc: El Oeste
The needle usually sits right on the '210' marking on the gauge. Now it sits to the left hand side of it.
#4560331 - 10/31/17 03:23 PM Re: Is this a failing thermostat? [Re: HawkeyeScott]
EdwardC Offline
Loc: Chicago, IL
You might be able to tell if it's getting stuck open by looking down the radiator cap right after you start the car from cold, there shouldn't be any coolant flow since the thermostat should be closed.
#4560346 - 10/31/17 03:56 PM Re: Is this a failing thermostat? [Re: HawkeyeScott]
emmett442 Offline
Loc: Wisconsin
The PCM monitors thermostat performance almost every time you start your car cold. It checks to see that the coolant is reaching the target temp within a required amount of time. If not, P0128 sets.
If you aren't getting a CEL, I wouldn't worry about it.
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
#4560376 - 10/31/17 04:31 PM Re: Is this a failing thermostat? [Re: HawkeyeScott]
dlundblad Offline
Loc: Indiana
Can you hook a live data reading code reader up?
I bought my truck with what I knew was a stuck open thermostat. No big deal. It went up halfway between the 100*F and the 210*F and stopped. I replaced it with a NAPA (US made part and only t stat locally with a lifetime warranty) and it went up to the 210*F and dropped down to just above the halfway mark.
I was left scratching my head, but the heat felt hotter. Hooked my code reader up and she was at 192*F. The thermostat opens at 195*F.
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4560648 - 10/31/17 08:39 PM Re: Is this a failing thermostat? [Re: HawkeyeScott]
Nick1994 Offline
Loc: Phoenix, AZ
Yeah I'd replace it.
Just not with a Stant.
My grandparent's Trailblazer had a stuck open thermostat. My mechanic replaced it with a Stant and it began to run hot. Replaced again and it still ran hot. Replaced with an OEM thermostat and it helped a lot. It had a bad fan clutch, but the Stant made it run warmer. This was because the opening of the Stant was smaller than the OEM thermostat, held side by side you could clearly see it, we also used a micrometer, I don't remember the measurements but it was somewhere around 15% smaller.
OEM only for me from here on out.
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4560829 - 11/01/17 03:26 AM Re: Is this a failing thermostat? [Re: HawkeyeScott]
Lubener Offline
Loc: N.Ohio
When in question just change it. Less than 10 dollars and 15 minutes to change, it's not worth worrying over.They deteriorate over time. I would go with OEM but if you use a Stant, go with their "superstat" only.
Edited by Lubener (11/01/17 03:27 AM)
The "thinking" man's friend.
