Best additive in oil to clean sludge?
by ffgb
06/21/18 02:19 PM
Who is a Dirt Track regular?
by thooks
06/21/18 01:39 PM
eco plug oil plug video is restricted
by edwardh1
06/21/18 01:27 PM
Political comments
by ridgerunner
06/21/18 01:23 PM
My Ford orange turned pink
by BeerCan
06/21/18 12:45 PM
Any plants/garden experts?
by maverickfhs
06/21/18 12:43 PM
Internet Sales Tax O.K.ed by Supreme Court
by doitmyself
06/21/18 12:23 PM
Brake fluid for a '03 Volvo S60
by earthworm
06/21/18 11:22 AM
Oil Weight Change - Mid Production Cycle
by PolarisX
06/21/18 11:20 AM
Kia ATF - OEM, Eneos, Maxlife - TDS - DIFFERENT!
by Spddm0n
06/21/18 11:19 AM
Dillon Precision Is Simply The Best!
by 2015_PSD
06/21/18 11:17 AM
First OCI - 156k miles Prius
by Greg L
06/21/18 11:11 AM
Brake Squeal on Rear Discs
by BlitzPuppet
06/21/18 11:10 AM
Coolant leak.
by LeakySeals
06/21/18 11:05 AM
Looking for a Home Depot coupon 10% off?
by GravelRoad
06/21/18 10:59 AM
Which is more important for low wear HTHS or ZDDP?
by Building3
06/21/18 10:40 AM
Valvoline DuraBlend 80W-90
by dogememe
06/21/18 10:34 AM
Lifter Tick
by Delta
06/21/18 10:28 AM
I Got Locked Up Today
by Zee09
06/21/18 10:24 AM
GM new 2.7 turbo pick up motor
by ZZman
06/21/18 09:45 AM
wil892, Spddm0n, ronw1309, Suth31, yamahaboy125
65286 Registered Users
97 registered (Ag76, 14ecocruze, 28oz, 4WD, 853okg, 2015_PSD, 8 invisible), 1586 Guests and 44 Spiders online.
65286 Members
67 Forums
285715 Topics
Page 1 of 2 1 2 >
#4558974 - 10/30/17 06:48 AM Piston Soak
StevieC Offline
Loc: Ontario, Canada
Has anyone done a piston soak with straight gasoline? (Pics of this?)
It's a solvent by nature and a runny liquid and I'm sure it would release carbon and gunk from the piston tops and rings?
Just a thought...
'15 Dodge Journey - 90,000 KM's - SSO 5w20
'06 Hyundai Santa Fe - 535,000km - SSO 0w30 (R.I.P)
#4558986 - 10/30/17 07:00 AM Re: Piston Soak [Re: StevieC]
LaCocina27 Offline
Loc: America
That's an interesting idea...
#4558988 - 10/30/17 07:06 AM Re: Piston Soak [Re: StevieC]
StevieC Offline
I know it would wash the cylinder walls but in general it might be a better soak for engines and we could over come the washed cylinder walls after the treatment using some like Napa type oil in the cylinders after like Seafoam or Lucas or whatever until natural lubrication is restored by the oiling system in the engine.
Edited by StevieC (10/30/17 07:07 AM)
#4559014 - 10/30/17 07:34 AM Re: Piston Soak [Re: StevieC]
LaCocina27 Offline
Loc: America
StevieC, what I like about your idea is that since the soak is getting blasted out of the open spark plug holes anyways, it may not do any harm. I've piston-soaked with other fluids, even a mix of, so I'm asking what other adverse affects plain gasoline could have.
Piston soaks are best done with warmed chemical on a hot engine, so that wouldn't bode well for gasoline, unless perhaps it was left in until the engine was cold.
Any other opinions on this?
#4559023 - 10/30/17 07:40 AM Re: Piston Soak [Re: StevieC]
StevieC Offline
As engines have "clear flood" modes where depressing the accelerator to the floor while cranking causes the ECU to turn off the injectors while cranking I can't see how excessive gas would cause a problem other than washing the walls and rings of lubrication which can be remedied as I described above if really concerned sort of thing. What I'm getting at is this excessive fuel in the cylinders could exist under real world conditions. Albeit not a lake of fuel but enough to wash the walls if the engine was flooded.
You could run the engine until it's warm, let it cool slightly and then fill the cylinders with fuel and put the spark plugs back in to stop evaporation. Then take them back out and crank over to rid the cylinder of excess fuel that is left.
The more I talk about this the more I think this might be a good idea for carbon. I just wish I had a carbon-upped engine to test it on but I don't at the moment. I do have a boroscope so I could record before/after pics.
Edited by StevieC (10/30/17 07:41 AM)
#4559031 - 10/30/17 07:51 AM Re: Piston Soak [Re: LaCocina27]
Kira Offline
Loc: Champlain/Hudson Valley
This is a pretty basic operation.
It's less wasteful to soak with a crankcase full of old, ready-to-change oil (since you'll be contaminating it).
Pick a solvent and send it down the spark plug holes.
Wait.
Crank the engine to move it a bit. If I was doing it I'd put a socket on the crank pulley bolt and move the engine 5 degrees each way repeatedly.
Maybe denatured alcohol or lacquer thinner would work well.
What "adverse effects"?
Your engine will relube itself.
After a soak, I'd start the engine for 10 seconds then drain the old, now-contaminated oil and change the oil and filter. Done
#4559035 - 10/30/17 07:54 AM Re: Piston Soak [Re: StevieC]
StevieC Offline
And run a UOA on the old oil and watch the heads spin. LOL
#4559060 - 10/30/17 08:27 AM Re: Piston Soak [Re: StevieC]
Artem Offline
Loc: Florida
Seems there isn't a really healthy way of going about it with before / after sparkling results and before / after UOA showing no increased engine wear as a result.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart.
#4559080 - 10/30/17 08:56 AM Re: Piston Soak [Re: StevieC]
LaCocina27 Offline
Loc: America
I would guinea-pig that!
#4559085 - 10/30/17 08:59 AM Re: Piston Soak [Re: StevieC]
StevieC Offline
Do you have a Boroscope to take pictures/video before/after to share here?
#4559100 - 10/30/17 09:21 AM Re: Piston Soak [Re: StevieC]
LaCocina27 Offline
Loc: America
I do not. frown
#4559104 - 10/30/17 09:26 AM Re: Piston Soak [Re: StevieC]
WyrTwister Offline
Loc: Texas
Why not mix Seafoam or just some engine oil with the gas ? Or even 2 cycle oil ?
Hope I am never in need of such a treatment .
I agree , do this right before you change oil / filter .
Best of luck , :-)
Wyr
God bless
#4559113 - 10/30/17 09:40 AM Re: Piston Soak [Re: LaCocina27]
StevieC Offline
I do not. frown
Darn, no way to measure the results... frown
#4559115 - 10/30/17 09:40 AM Re: Piston Soak [Re: WyrTwister]
StevieC Offline
Best of luck , :-)
Ihink that might take away from the solvent action IMO.
#4559172 - 10/30/17 10:28 AM Re: Piston Soak [Re: StevieC]
LaCocina27 Offline
Loc: America
I do not. frown
I don't think the seat-of-the-pants test is total bunk.
Though, the smoke show could also be problematic!
Page 1 of 2 1 2 >
