power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Joey Logano and the 2019 Mustang
by Malo83. 12/13/18 02:40 PM
BMW LL01FE Spec
by The Critic. 12/13/18 02:03 PM
I Tried and Failed to Not Buy a New Car
by badtlc. 12/13/18 01:49 PM
OEM Brand Coolant by Rocochem
by NumbersGuy. 12/13/18 01:15 PM
lordcheeto, WondrousBread, slickoo9, turntable_life, Poles19
66670 Registered Users
99 registered members (andyd, alcyon, ad244, Astro_Guy, AdditiveOCD, 97K15004WD, 11 invisible), 1,756 guests, and 39 spiders.
Topics295,042
Posts4,926,555
Members66,670
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
Stop changing oil in oil burning engine? #4557902
10/28/17 10:02 PM
10/28/17 10:02 PM
Venezuela, South America
Emanuel Offline OP
Emanuel  Offline OP
Would you stop changing oil in a engine that burns 1 qt of oil every thousand miles if you wanted that engine to last as much as possible?
Re: Stop changing oil in oil burning engine? [Re: Emanuel] #4557903
10/28/17 10:05 PM
10/28/17 10:05 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
I did this with a car that burned 1qt every 1k. I would change filter every 5k and then a full oil change at 10k. Realistically it could have gone more like 20k without a change.
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: Stop changing oil in oil burning engine? [Re: Emanuel] #4557918
10/28/17 10:32 PM
10/28/17 10:32 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have had engines that burned more than 1 quart per 1000 miles,
and it makes no sense at all to change the oil anymore at that point.
I have had several that ONLY got USED motor oil added.
No sense in spending money on new oil....
Re: Stop changing oil in oil burning engine? [Re: Emanuel] #4557919
10/28/17 10:36 PM
10/28/17 10:36 PM
Omaha, NE USA
fisher83 Offline
fisher83  Offline
Omaha, NE USA
Thatís more or less what we have done with my grandmotherís Prizm. It has burned excessive amounts of oil from about 70k miles on. It has around 160k now. We do one oil and filter change a year which is usually about 8- 9,000 miles. Super Tech 5w30 or whatever mix and match partial quarts I find in the garage and a cheap filter. It burns through the oil fast enough that we could probably get away with just a filter change.
2015 Toyota RAV4 Limited 41k
2016 Nissan Frontier Pro-4x 18k
Re: Stop changing oil in oil burning engine? [Re: fisher83] #4557943
10/28/17 11:09 PM
10/28/17 11:09 PM
MN
14Accent Offline
14Accent  Offline
MN
Was just going to say this about my old Corolla. The early 1zz engines ate oil so fast it wasn't worth it to change. My 99 Corolla was about 1qt per 1k and all I did was change the filter every 5k. It pretty much got an oil change every 5k anyways based on that consumption.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Stop changing oil in oil burning engine? [Re: Emanuel] #4557946
10/28/17 11:16 PM
10/28/17 11:16 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Use a Fram Ultra or equiv (not sure what you can get out there) and go 10k miles or more. The new oil additions will keep the detergency up and engine clean.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Stop changing oil in oil burning engine? [Re: Emanuel] #4557956
10/28/17 11:42 PM
10/28/17 11:42 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
What about those cars I see on the freeway that are burning so much oil that it looks like a blue fog has rolled in in the middle of August? I mean they literally block your view if you get in the thick of it. How much oil are they burning?
Re: Stop changing oil in oil burning engine? [Re: Emanuel] #4557961
10/28/17 11:48 PM
10/28/17 11:48 PM
Canada
Run Offline
Run  Offline
Canada
I would do filter changes every 6 months. Keep topping it up. Not much sense in draining the sump.
03 Neon 2.0 - VSP 5W-30 Pentius XL
Re: Stop changing oil in oil burning engine? [Re: Emanuel] #4557982
10/29/17 12:49 AM
10/29/17 12:49 AM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
If it's a piece of junk, definitely. Otherwise, go to extended OCIs like 10k +.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: Stop changing oil in oil burning engine? [Re: Emanuel] #4558025
10/29/17 04:24 AM
10/29/17 04:24 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Depending on how much you care about the car, if you plan on fixing it, et. consider changing the filter once or twice a year. Base the filter change on the filter you buy and the miles you drive.
God Bless Our Troops
Re: Stop changing oil in oil burning engine? [Re: Emanuel] #4558026
10/29/17 04:28 AM
10/29/17 04:28 AM
Orlando, FL
Mr Nice Offline
Mr Nice  Offline
Orlando, FL
Just keep topping off the oil.
Re: Stop changing oil in oil burning engine? [Re: Emanuel] #4558035
10/29/17 04:58 AM
10/29/17 04:58 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
I purchased a nice used Suzuki Swift 1.3L that I later discovered consumed a lot of oil. I switched to a higher viscosity synthetic and it nearly solved the problem. At the time, I used the highest viscosity flavor of Castrol Syntec I could find, which was a something w-50, then migrated over to M1, 15W-50. Problem solved.
Re: Stop changing oil in oil burning engine? [Re: Emanuel] #4558059
10/29/17 05:45 AM
10/29/17 05:45 AM
Ky
CaspianM Offline
CaspianM  Offline
Ky
It depends how much it consumes! you can calculate it. If it goes thru entire sump in 5k miles or so no need to change. But as soon as you find out it starts using oil I would change the oil brand and type(HM?) until I find the one that is used less and stick to it by topping it off.
14 Dodge Durango
15 Yamaha FZ09
13 Lexus CT200h(M1 0W-20)
15 Yamaha Bolt (FF)
08 Suzuki B-King M1(4T)
10 Xterra SE
06 VTX-1300C
05 Honda 919
Re: Stop changing oil in oil burning engine? [Re: Emanuel] #4558078
10/29/17 06:38 AM
10/29/17 06:38 AM
ME
eljefino Offline
eljefino  Offline
ME
There's junk in the bottom of the sump that'd be nice to drain annually.
Re: Stop changing oil in oil burning engine? [Re: Emanuel] #4558135
10/29/17 07:50 AM
10/29/17 07:50 AM
Emanuel Offline OP
Emanuel  Offline OP
I really care about the car, I care about it a lot, but based on the consumption I am replacing the 3.7 qts oil capacity every 4000 miles. My plan is to do 3k filter change intervals and drain the sump every 6k miles.
Page 1 of 3 1 2 3
