Soot loading from DI engines - Size of particles
by StevieC. 09/24/18 09:58 AM
New TV bad picture some channels
by raaizin. 09/24/18 09:35 AM
Crown Victoria HVAC repair
by emmett442. 09/24/18 08:44 AM
2007 Toyota Camry LE Alternator
by maverickfhs. 09/24/18 08:28 AM
AutoSense drying not drying
by Ifixyawata. 09/24/18 08:23 AM
Time for a new Generator... Wisdom desired!
by webfors. 09/24/18 06:36 AM
flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
TCam, OzFrog, Kursk, DMB, bcrossen
66060 Registered Users
76 registered members (Billbert, 2004tdigls, BAJA_05, Astro14, 13 invisible), 1,747 guests, and 39 spiders.
Topics290,935
Posts4,852,725
Members66,060
Most Online3,590
Jan 24th, 2017
High Mileage Change #4556049
10/27/17 09:17 AM
10/27/17 09:17 AM
TN
TXtoTN Offline OP
TXtoTN  Offline OP
TN
Hello Everyone,
I am new to posting on a site like this. I do have a question as I have read conflicting thoughts on this issue. I currently have 2008 Toyota Sequoia 5.7L. It has only seen oil changes using M1 or M1EP since we have had it. It currently has 90K miles on it with no leaks at all. I have been reading that I should have changed to M1 High Mileage around the 75k mark. Should I change to M1 High Mileage now? Will something happen to my engine seals if I make the change? Just to get some "high fives", I do my own oil changes on this car (it was fun finding out that I had to buy a special oil filter cap to get the housing off). I thank you all for your insight in this matter.
Thanks.
Re: High Mileage Change [Re: TXtoTN] #4556055
10/27/17 09:22 AM
10/27/17 09:22 AM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
It won't hurt but no reason to or not either. Use which ever is easier to find/cheaper IMO.
yup
Re: High Mileage Change [Re: TXtoTN] #4556065
10/27/17 09:29 AM
10/27/17 09:29 AM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
I though my 2002 was leak free up until a couple months ago when I was tracking down PS pump weepage. Then I saw some relatively "old looking" weepage coming out of the crank and lower timing chain cover. I'll be switching to HM oil in May. If you have absolutely zero leakage, there's no reason to switch to HM, regardless of mileage. Age of the seals is another issue which others could comment on.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: High Mileage Change [Re: TXtoTN] #4556068
10/27/17 09:31 AM
10/27/17 09:31 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Either way is fine but marketing does work well.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: High Mileage Change [Re: TXtoTN] #4556071
10/27/17 09:37 AM
10/27/17 09:37 AM
Indian Valley, Virginia
Sleepeyes Offline
Sleepeyes  Offline
For a different POV:
Switch to the HM oil. Better to prevent than try and put a band-aid on it once it starts leaking. I switched to HM at 75,000miles on my truck and now at 145k no leaks and no burning. I'm pretty happy with that considering I drive it like a race car.
2007 Ram 1500; 3.7l; 6spd; 2wd; Valvoline 0w-20 HM; M1 Filter
GF's 2003 VW Bug; 2.0l; auto; SuperTech 20w-50 w/~2qt of Warren 5w-30; Fram Filter
Re: High Mileage Change [Re: TXtoTN] #4556079
10/27/17 09:43 AM
10/27/17 09:43 AM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
High-mileage oils aren't like stop-leak that just gums up the system to stop leaks - the additives actually help the seals. So, that being said, there's no reason not to switch to a HM oil and it'll only do your engine good even though I don't consider 90K "high mileage" and the 75K number on oil bottles is just an arbitrary marketing statement. If it doesn't leak or use a lot there's no express purpose to use a HM formulation but it won't hurt anything. My Cruze has 106K and with regular Valvoline Synpower there's only the slightest accumulation of gunk around the valve cover and zero consumption so I'm in no hurry to move up to the Maxlife full syn.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 113K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 169K
'67 Suburban, 350, 331K
Re: High Mileage Change [Re: TXtoTN] #4556081
10/27/17 09:46 AM
10/27/17 09:46 AM
The Midwest
skyactiv Online content
skyactiv  Online Content
The Midwest
Don't use it unless its really needed.
Me: 13' VW GTI 3 door 6 speed manual
Re: High Mileage Change [Re: Sleepeyes] #4556126
10/27/17 10:25 AM
10/27/17 10:25 AM
NC
fenixguy Offline
fenixguy  Offline
NC
+1 You can use high mileage oil from day one in a brand new car and it won't hurt a thing.
'16 Frontier SV 4x4-PP/Nissan OEM
'08 CR-V EX AWD-Valvoline Syn MaxLife/Fram TG
'01 Civic EX-Valvoline Syn MaxLife/Fram UG
'00 Civic LX-PYB/Fram UG
Re: High Mileage Change [Re: TXtoTN] #4556394
10/27/17 03:39 PM
10/27/17 03:39 PM
London, England
bigjl Offline
bigjl  Offline
London, England
I would use it personally.
Prevention is often better than cure.
16 S350d LWB 25k Mobil Super 3000 XE 5w30
17 Smart ForFour Auto 6.5k Mobil 1 0w40 FS
Re: High Mileage Change [Re: skyactiv] #4556397
10/27/17 03:43 PM
10/27/17 03:43 PM
London, England
bigjl Offline
bigjl  Offline
London, England
Not sure i really agree with that video.
Is he saying that HM Oil will make the seals bigger than they were originally designed to be?
Just because something is on YouTube doesn't automatically mean its factual
Re: High Mileage Change [Re: TXtoTN] #4556411
10/27/17 04:09 PM
10/27/17 04:09 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Absolutely fine for use in any vehicle. Almost all current HM oils hold current certifications/approvals. That Pat Goss video is a little dated.
'18 KIA Sportage LX AWD 2.4L: MSS 10w30
'13 Hyundai Santa Fe Sport 2.0T: EDGE 5w30
Re: High Mileage Change [Re: TXtoTN] #4556463
10/27/17 05:47 PM
10/27/17 05:47 PM
southwest Mo.
wtd Offline
wtd  Offline
southwest Mo.
I used Pennzoil HM in my 98 chevy K3500 with the 7.4L to try and stop a couple of leaks that were actually dripping and it stopped the drips so I'm a believer in them. I also wouldn't hesitate to use a HM oil in a vehicle that doesn't leak.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: High Mileage Change [Re: wemay] #4556473
10/27/17 05:59 PM
10/27/17 05:59 PM
Sleepeyes Offline
Sleepeyes  Offline
That and most chain stores price them the same as their non-HM counterparts. Valvoline 0w20 FS HM costs the exact same as Valvoline 0w20 FS. I have noticed that usually sales don't apply to HM but it isn't a hard fast rule. Even then it is a difference of a couple of bucks (and if that is going to make or break you then you have much bigger issues...).
Re: High Mileage Change [Re: TXtoTN] #4556566
10/27/17 07:11 PM
10/27/17 07:11 PM
Michigan
ZZman Offline
ZZman  Offline
Michigan
HM oils are not only good for leaks, but they often have a stronger additive package.
2003 Mercury Grand Marquis. Rotella T6 Multi-Vehicle oil
2008 Sebring Hardtop convertible. Rotella T6 Multi-Vehicle oil
2006 Kawasaki Vulcan 900 LT. Amsoil Metric 10w-40
Re: High Mileage Change [Re: Sleepeyes] #4556593
10/27/17 07:22 PM
10/27/17 07:22 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
I notice that Walmart has this one on Rollback.
https://www.walmart.com/ip/Mobil-1-5W-30-High-Mileage-Full-Synthetic-Motor-Oil-5-qt/17018131
I picked up a couple of these last spring.
2004 Corolla 124831
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
