Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
113 registered members (209paulc, 2015_PSD, 40w8, 4WD, 2009Edge, 11 invisible), 1,626 guests, and 47 spiders.
Topics296,753
Posts4,958,245
Members66,964
Most Online2,577
Jan 14th, 2019
FL-22 Antifreeze? #4555062
10/26/17 10:52 AM
10/26/17 10:52 AM
Connecticut
Mar57 Offline OP
Mar57  Offline OP
Connecticut
Mazda Miata owner's manual calls for FL-22 antifreeze. I've looked in the usual places, Autozone etc. but can't find it. Finally found it on Amazon at $36.00 per gallon. Can also get it at the local Mazda dealer but the cost will probably be higher. Is there anything special about FL-22 or can I use a common brand like Prestone or other? What do you guys recommend?
Re: FL-22 Antifreeze? [Re: Mar57] #4555084
10/26/17 11:18 AM
10/26/17 11:18 AM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
FL-22 is $24.99/gal from the dealer.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: FL-22 Antifreeze? [Re: Mar57] #4555094
10/26/17 11:28 AM
10/26/17 11:28 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
There's a "universal import" antifreeze someone keeps mentioning,
but since I don't have any Japanese vehicles I forget what it's called.
Re: FL-22 Antifreeze? [Re: Mar57] #4555128
10/26/17 11:56 AM
10/26/17 11:56 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
FL22 is an Asian PHOAT AF which comes as a 55/45 premix. Most of the Asian AF premixes come as 50/50, other than that, it has the same chemical profile as the other Asian AFs. No silicates, borates, amines or nitrites. And it's a Long Life AF.
If you can't get FL22 at the quoted ~$25/gallon, you should take a look at PepBoys OEM brand 'concentrate' and make your own 50/50 mix with distilled water. Comes in green tint to match the oem AF. If you have a store nearby and they stock it, it's currently $14.90/gallon. Can check the stores online. Or, go to PepBoys at ebay linked, currently $17.67/gallon delivered.
https://www.ebay.com/itm/OEM-Concentrate...=item25cef6f756
'I' would not use Prestone Universal because 2eha used as an inhibitor. Asian vehicles don't use or recommend using 2eha.
Re: FL-22 Antifreeze? [Re: Mar57] #4555195
10/26/17 12:52 PM
10/26/17 12:52 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
I wonder who thought it would be a great idea to deviate from 50/50 that has worked for 80 yrs?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: FL-22 Antifreeze? [Re: Mar57] #4555211
10/26/17 01:24 PM
10/26/17 01:24 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
The real question I ask is how can they expect me to maintain the proper mix if you canít get all the leftovers out of the block and I flush with water?
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: FL-22 Antifreeze? [Re: Mar57] #4555247
10/26/17 02:23 PM
10/26/17 02:23 PM
Pennsylvania
Reggaemon Offline
Reggaemon  Offline
Pennsylvania
Ford Motorcraft VC-10-A2 is the same as FL-22.
Re: FL-22 Antifreeze? [Re: Mar57] #4555288
10/26/17 03:02 PM
10/26/17 03:02 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
I see Motorcraft AF part numbers numbers being used more often here now. I know it as Motorcraft Specialty Green, and it does come as a concentrate. However, though it's been awhile last time I priced it at a couple area Ford dealers it was ~$34 a gallon. I realize that it's a concentrate, but still pricey.
If you're referring to your 2016 Mazda 6, looks like it has a non pressurized recovery tank. Pep Boys OEM 'concentrate' would work for that. Do some distilled flushes till clear, then using your cooling system capacity, add half capacity (for 50/50) with AF and top with distilled. Can make a 50/50 premix for recovery tank after. In non pressurized tank system I've never not been able to get at least 50% AF into system and top with distilled.
Now if you're wanting to use FL22, after distilled flushes you've got to do d&f's with it until an AF tester shows correct concentration. Or, find the block drain(s) open them and then fill with AF. That's why with premixes many folks just do simple radiator d&fs on shorter intervals. You shouldn't need to worry about it for awhile though.
Re: FL-22 Antifreeze? [Re: Sayjac] #4555476
10/26/17 05:43 PM
10/26/17 05:43 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
The plan was to use FL22 but I am not going to do drain and fills and lose good expensive coolant so I will probably use the motorcraft stuff. Valvoline also told me I could use their dexcool bit I cannot bring myself to use it since its associated with GM.
Re: FL-22 Antifreeze? [Re: E150GT] #4555535
10/26/17 06:30 PM
10/26/17 06:30 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
^^^^True, it is a wasteful process. That's said I was left little choice once when a Honda dealer used original green with a head gasket job. I went back and told them I wasn't pleased and they gave me a jug of Type2 premix, I bought another and did precisely that. As mentioned block drains another option, but depending on where they are that may not be practicable either.
Specialty Green an option.
As for DexCool, I'd pass on that idea. Uses 2eha as a main inhibitor, something the ALL the Asian AF's avoid. One other option is Peak Global Lifetime full strength sold at NAPA. Long Life OAT AF with no 2eha. Been running it in place of Toyota Red or SLL pink for ~3+ years now on older Tacoma. Working fine, original radiator.
Re: FL-22 Antifreeze? [Re: Chris142] #4556617
10/27/17 06:38 PM
10/27/17 06:38 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
My Saab didn't come with 50/50.
Re: FL-22 Antifreeze? [Re: Mar57] #4558697
10/29/17 06:28 PM
10/29/17 06:28 PM
Canuck living in California
KrisZ Online content
KrisZ  Online Content
Mazda, as well as other, perhaps all Japanese automakers only require one radiator drain and fill as part of their maintenance schedule. That is why they only stock premixed coolant and that is why the factory fill is twice as long as changes afterwards. If you plan on using FL-22 there is no need for multiple drain and fills.
2015 Dodge Grand Caravan-30k miles.
2007 Ford Focus ZX3-110k miles
2006 Mazda 3-168k miles
