Hello all:
I need to change out the spark plugs on my Maxima with OEM recommended NGK platinum plugs and had two questions:
1. gap: my spec is 0.039" to 0.043". The NGK plus come pregapped at 0.044" and they tell me there will be no performance difference regapping to 0.040 (not sure why they chose this value). Honestly I would rather not mess with the NGK gap if this is true because I have regapped plugs in the past and it can be challenging. However, if I take the midpoint of 0.041", isn't 0.044, or 0.003" difference, a bit excessive? I have read that spark plug gap increases with use so why start out with a higher gap in the first place. To further try and educate myself, I then conducted a Google search looking for data on engine performance/efficiency as a function of spark plug gap and turned up nothing. It will be interesting to measure the gap of the plugs I remove however I don't know of course the exact value they were set to at the Nissan factory and maybe they didn't regap the OEM NGK plugs! In other words, I don't know the original gap value.
2. torque: my spec is 14-22 ft lbs. Why is there such a large range? I'm going to buy a good torque wrench. Should I just go for the midpoint value of 18 ft lbs?
Thanks
Thanks
