It's AMSOILŪ, not Amsoil
by Rat407
06/25/18 06:39 AM
VW Passat 2007
by madRiver
06/25/18 06:18 AM
Review: CVJ Remanufactured CV Axles
by The Critic
06/25/18 03:40 AM
Towing without 85w140?
by OilFilters
06/25/18 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
06/24/18 09:10 PM
SAE 90 v 85/140
by Knuckle078
06/24/18 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
06/24/18 08:45 PM
Schaeffer's oil reviews on Amazon
by zfasts03
06/24/18 07:41 PM
Decent MP3 player
by Ed_T
06/24/18 07:08 PM
Letgo
by Donald
06/24/18 06:52 PM
Tire buying advice
by supton
06/24/18 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
06/24/18 06:21 PM
No older cars in New York State?
by Oldtom
06/24/18 06:19 PM
2009 Taurus strut mount noise
by terry274
06/24/18 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
06/24/18 03:36 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
96 registered (2002 Maxima SE, BeerCan, andyd, alcyon, 1foxracing, 16 invisible), 1362 Guests and 61 Spiders online.
65319 Members
67 Forums
285959 Topics
#4538835 - 10/10/17 08:43 AM Kohler 26hp bent starter shaft
syndydog Offline
Loc: Laurel Springs, NC
I have a Craftsman with a 26hp Kohler engine. Over the last few years I have gone through about 6 starters. While starting if for any reason the engine kicks back or locks up the shaft bends. In 2015 a member "Oldesel" posted how he replaced the 25hp Part# 32 098 04 like mine with a Kohler 27hp Part# 25 089 09 which has a cast support at the bendix end. My problem is this, my gear is 10 teeth. When I look up the starter he used it says it is 9 teeth. It also looks like the Kohler 27hp Part# 25 089 09 is now (Kohler 27hp Part# 25 098 09) unless his post had a typo. Has anyone gone through this and upgraded to the stronger starter? I also found a starter (KH-25-098-09-S) which looks like it may work but some sellers list it as 9 teeth and some list it as 10 teeth.
2016 Toyota Sequoia, John Deere 3032E, Craftsman GT5000, Case 580SE backhoe.
#4543172 - 10/14/17 12:53 PM Re: Kohler 26hp bent starter shaft [Re: syndydog]
ragtoplvr Offline
Loc: missouri
My thought is I would add a push button by the ignition switch that kept the ignition off until the engine was cranking at full speed. This prevents kickback. Then I would release the push button and if it did not start apply choke. A good battery is always a good thing. Some of the cheap low cost batteries have very little lead in them. Get the good one.
Rod
Edited by ragtoplvr (10/14/17 12:55 PM)
#4543713 - 10/15/17 03:32 AM Re: Kohler 26hp bent starter shaft [Re: syndydog]
cudavid Offline
Loc: RI
Problem is likely to excessive valve clearance, making valve timing off, reset lash and try
U will need to pull specifications
#4546943 - 10/18/17 08:34 AM Re: Kohler 26hp bent starter shaft [Re: syndydog]
syndydog Offline
This all started to happen with less than 50 hours on the engine. I do have to pull the choke and as soon as it starts release it and it usually works 99.9% of the time. It's just that once so often that it jams. The started shaft is weak at less than 1/2 inch in machined areas. I did find one with 10 teeth that has a full cast housing and bushing support at the shaft end. However I not 100% convinced it will fit, still checking.
