Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
Flow How: PourPoint warmer than CCV "0w" Temperature 0w20
by oil_film_movies. 03/25/19 05:31 PM
Oil filter material list?
by shibby6600. 03/25/19 04:49 PM
Insights on commission paying jobs?
by Pat in Speedway. 03/25/19 04:29 PM
Decode a vehicle VIN for production Month & Year?
by Ed_Flecko. 03/25/19 04:29 PM
Wix 51522 vs Fram XG9837
by RDY4WAR. 03/25/19 04:13 PM
Rural King: 20K Lumen LED Tripod Worklight $34.93
by skyactiv. 03/25/19 03:55 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
129 registered members (2010Civic, ARB1977, agpatel, ABerns, 77GrandPrix, 12 invisible), 2,022 guests, and 68 spiders.
Topics286,429
Posts4,908,089
Members67,622
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
Techron the best injector cleaner? #4531713
10/02/17 12:23 AM
10/02/17 12:23 AM
Oregon from England
MaDMaXX Offline OP
MaDMaXX  Offline OP
Oregon from England
I always keep a pack of Techron in the garage, occasionally using it, however my Wife's TSX is getting an occasionally reported misfire on cylinder 1 - injector checks out electrically, and nothing else is amiss.
This is the ODB2 system reporting this, the only thing i have also noticed it's a little sluggish pulling through the gears - so i'm thinking the injectors aren't so clean.
Anyway, i'm after what people consider the best over the counter cleaner i can get. I understand a regular use of weaker products is recommended, but what i really want, is a strong cleaner you aren't supposed to use that often.
BG 44k was suggested, but i'm trying to see what modern day suggestions people have on this subject?
Thanks.
___________
'04 350Z
'05 TSX
'02 F4i
'02 Ranger
Re: Techron the best injector cleaner? [Re: MaDMaXX] #4531719
10/02/17 12:30 AM
10/02/17 12:30 AM
Seattle
Superflop Offline
Superflop  Offline
Seattle
Redline SI1 or berrymans b12. Check your air filter and spark plugs.
2002 saab 9-5 2.3t wagon
2014 dodge grand caravan
Re: Techron the best injector cleaner? [Re: MaDMaXX] #4531722
10/02/17 12:40 AM
10/02/17 12:40 AM
NorCal
Seventh Offline
Seventh  Offline
NorCal
Maybe try swapping coils and plugs to different cylinders to see if the intermittent misfire follows.
Swap plugs between cyls 1 and 2, swap coils between cyls 1 and 3. If the misfire pops up on cylinders 2 it's the plug, if it comes back on 3 it's the coil.
If it keeps coming back to #1 swap the injectors, check fuel trims, smoke test for intake leaks, compression and leakdown test.
There isn't any fix in a can for a misfire
Re: Techron the best injector cleaner? [Re: MaDMaXX] #4531723
10/02/17 12:41 AM
10/02/17 12:41 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
I always us LM Jectron or Redline SI-1. One's solvent, one's PEA.
"Zed's dead baby, Zed's dead."
Re: Techron the best injector cleaner? [Re: MaDMaXX] #4531724
10/02/17 12:46 AM
10/02/17 12:46 AM
Oregon from England
MaDMaXX Offline OP
MaDMaXX  Offline OP
Oregon from England
Thanks for the troubleshooting tips.
Misfire code doesn't move with the COPs, plugs are new, air filter also new.
90% certain it's not an intake leak...\
Haven't moved injectors yet.
It's apparently reasonably common for there to be a problem with the injector, be it failed, or plugged up, for this code on the TSX, particularly if it's only the computer reporting it, i really need to move the injector for the next part of testing.
However, i'm still interested in the strongest fuel injector/system cleaner available these days?
Also, any reason not to double dose things like fuel treatments?
___________
'04 350Z
'05 TSX
'02 F4i
'02 Ranger
Re: Techron the best injector cleaner? [Re: MaDMaXX] #4531726
10/02/17 12:59 AM
10/02/17 12:59 AM
Seattle
Superflop Offline
Superflop  Offline
Seattle
Well for solvent type cleaners berrymans is quite strong and is also cheap. I have used jectron too but i come back to my old standby b12... its something like 3 dollars a bottle at walmart.
Re: Techron the best injector cleaner? [Re: MaDMaXX] #4531727
10/02/17 01:04 AM
10/02/17 01:04 AM
Oregon from England
MaDMaXX Offline OP
MaDMaXX  Offline OP
Oregon from England
Seems that people are saying the highest concentration of PEA works out as the best cleaner?
I see Redline and 3M make one with a high percentage of it. Why would i choose a solvent type cleaner?
Again, let's say i want a stronger mix, can i shove two bottles of Chevron in and get a stronger cleaning effect?
___________
'04 350Z
'05 TSX
'02 F4i
'02 Ranger
Re: Techron the best injector cleaner? [Re: MaDMaXX] #4531731
10/02/17 01:16 AM
10/02/17 01:16 AM
Texas (south)
FermeLaPorte Offline
Texas (south)
I used Chemtool Regane. Works well in my car. I've used Techron. Also works great on my car. I did not notice any change with Lucas, tough. .
My two cents.
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Techron the best injector cleaner? [Re: MaDMaXX] #4531734
10/02/17 01:19 AM
10/02/17 01:19 AM
NorCal
Seventh Offline
Seventh  Offline
NorCal
Check fuel pressure? Low pressure/clogged filter could explain your sluggish performance.
I personally know one of the engineers at chevron, and what I can tell you is the techron additives pass the "no harm" tests required for BMW, who slaps their label on techron bottles.
The no harm test includes using the additive at 16x the recommended dosage, as well as pouring it straight into the crank case. Techron additive passed all tests.
My engineer buddy said when they did the no harm test using the other additive you mentioned on an old gm v6 engine (can't remember which one) with a painted steel oil pan, it peeled the paint off the inside of the pan in one big sheet and immediately plugged the oil pick up.
So I guess that one is "stronger."
He also told me the techron works over time, the longer it's in the tank the better, and that the hotter you can get your engine the better it will clean things up. The complete fuel system cleaner is a much better product than the injector cleaner. Per the label, it is safe to double dose.
Re: Techron the best injector cleaner? [Re: Superflop] #4531772
10/02/17 05:36 AM
10/02/17 05:36 AM
Oshawa, Ontario Canada
JC1 Online content
JC1  Online Content
+1 on the berrymans.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Techron the best injector cleaner? [Re: MaDMaXX] #4531791
10/02/17 06:13 AM
10/02/17 06:13 AM
NY
DdDd Offline
DdDd  Offline
NY
Nothing is going to clean your fuel system more violently than E85. I've run it plenty of times on older vehicles and any hesitation/misfire is gone within a tank. A 50/50 blend with regular pump gas works well.
People will argue against but any later model car with EFI will tolerate it quite well. Not going to do any damage with occasional use.
Re: Techron the best injector cleaner? [Re: DdDd] #4531807
10/02/17 06:41 AM
10/02/17 06:41 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
DdDd: Isn't "regular pump gas" also E85? Isn't darn near ALL GAS E10 or E15?
Re: Techron the best injector cleaner? [Re: MaDMaXX] #4531848
10/02/17 08:09 AM
10/02/17 08:09 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Gumout has a "new" brew called Multi-System tune-Up. But most of the components have been around for years. The MSDS suggests its part Seafoam, part Techron/PEA. At quick glance, the bottle looks like Seafoam. That signature white can. Maybe its some sort of arrangement to share chemicals. I've been using it full time primarily in my 26hp tractor and snowblower with good results taming a wavering idle, cleaning the carbs during use. And I like the IPA for moisture, I no longer drain the tank at the end of the season. IPA is probably why people love Seafoam so much, the IPA does seem to temporarily boost the HP, small engines seems stronger and smoother. In a auto engine? I'm a little gun shy about any additives because I recently had to replace the expensive catalyst on my non oil burning Escalade which was exposed to most of the ones mentioned above. Learning about my ride, its easy enough to just take things apart and clean them, rather than ingest additives. But.. i am tempted to use them for gas tank/pump issues
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Re: Techron the best injector cleaner? [Re: MaDMaXX] #4531874
10/02/17 09:11 AM
10/02/17 09:11 AM
New York
pbm Online content
pbm  Online Content
New York
I would try the Gumout Complete....it's about $8 (or maybe $9) at WM and claims to treat up to 34 gallons of gasoline....so it must have a good amount of PEA....and should work very well in a smaller sized gas tank.
'Journalism is Dead'
Re: Techron the best injector cleaner? [Re: MaDMaXX] #4531877
10/02/17 09:12 AM
10/02/17 09:12 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Guaranteed to Pass, gumout or techron. Id run a bottle per tank and repeat 2 more times. I doubt it will fix the problem but it wont hurt the car anyways.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Page 1 of 4 1 2 3 4
