Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
23 registered members (Char Baby, avi1777, billt460, Aero540T, ctechbob, 2 invisible), 531 guests, and 59 spiders.
Topics286,171
Posts4,903,558
Members67,572
Most Online2,967
Mar 10th, 2019
Power steering belt snapped #4530765
10/01/17 12:43 AM
10/01/17 12:43 AM
Australia
Spetz Offline OP
Spetz  Offline OP
Australia
Hi guys,
For simplicity's sake I'll give everything in bullet points.
Car:
- 2001 Mitsubishi Mirage coupe
- 6A12 MIVEC engine from an FTO
- OEM FTO PS cooler is fitted BUT it is obstructed by the front bar and has no airflow basically
Symptoms/Problem:
- Power steering fluid sprayed everywhere from reservoir
- PS pump sounded like a supercharger (quite loud)
- Black dust like debris around where PS pump is
- Brand new Gates PS belt snapped
Conditions during issue
- Car was on a race track and was revved to 8,000rpm repeatedly
- Belt snapped 45 mins in (end of 3rd 15 minute session)
- Fluid was new dextron III
- Pump had been making supercharger noise for a long time
- The pump spins freely by hand after the belt snapped
My thoughts:
- Could a faulty PS pump have caused belt slippage and hence belt snap? Would this be the black belt dust near the PS pump?
- Was the PS fluid sprayed everywhere from the reservoir due to overheating and could this have caused the belt snap?
- One of the lines to/from the PS pump has been leaking fluid. Could this have contributed in any way?
And finally are power steering pumps rebuildable?
Any advice is greatly appreciated!
2003 Mitsubishi Diamante 6G74 3.5L. 5 Speed auto. 160,000 miles. Shell Helix Ultra 5W40 at 6k OCI
Re: Power steering belt snapped [Re: Spetz] #4530768
10/01/17 12:53 AM
10/01/17 12:53 AM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
-Yes, and yes.
-The belt snapped because the pump was killing itself slowly and eventually seized.
-Yes. Air in your power steering system is bad. Cavitation causes heat and friction.
PS pumps are rebuildable, but yours probably isn't. Further, your lines and rack are likely contaminated with metal from the lunched pump and will need replaced if they are.
"Zed's dead baby, Zed's dead."
Re: Power steering belt snapped [Re: Spetz] #4530772
10/01/17 01:04 AM
10/01/17 01:04 AM
Australia
Spetz Offline OP
Spetz  Offline OP
Australia
How can I find out whether there is metal from the pump?
Can I take the pump apart and look to see if it is in one piece inside?
As I really would not want to replace my rack...
The lines I assume can be flushed out?
Re: Power steering belt snapped [Re: Spetz] #4530825
10/01/17 03:12 AM
10/01/17 03:12 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Oils and coolants eat belts and hoses. Never run with leaking fluids if they get on engine belts or rubber vacuum lines, hoses, rubber brake lines, etc.
I could have just said "never run with leaking fluids" since pumps, etc will also die if not properly filled during operation.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Power steering belt snapped [Re: Spetz] #4530868
10/01/17 06:21 AM
10/01/17 06:21 AM
Margate England
Claud Offline
Claud  Offline
Margate England
I think the pump failed because it was run way too fast which also contributed to both overheated and aerated fluid. Unless you have an oversize pulley fitted?.
But you're at a race track, if you aren't breaking stuff you aren't trying hard enough. smile smile smile
Claud
Re: Power steering belt snapped [Re: Spetz] #4530884
10/01/17 07:11 AM
10/01/17 07:11 AM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
You might look into some sort of underdrive pulley kit to reduce the speed you are spinning the accessories.
And put a real cooler on it that is not blocked from air flow.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Power steering belt snapped [Re: Spetz] #4531163
10/01/17 01:06 PM
10/01/17 01:06 PM
maryland
bblackmon19 Offline
bblackmon19  Offline
maryland
As others have stated the pump is spinning too fast causing cavitation.
95' Infiniti g20t auto t25 turbo kit 190k, 0w-40 Mobil
Re: Power steering belt snapped [Re: Spetz] #4531501
10/01/17 07:20 PM
10/01/17 07:20 PM
Illinois
javacontour Offline
javacontour  Offline
Illinois
Why do you still have power steering on such a small racecar?
No PS pump losses means more power to the wheels smile
network down, IP packets delivered via UPS -BOFH
Re: Power steering belt snapped [Re: Spetz] #4531746
10/02/17 02:44 AM
10/02/17 02:44 AM
Australia
Spetz Offline OP
Spetz  Offline OP
Australia
Thanks guys.
I don't think the PS pump is spinning too fast as it is within the factory rpm limit not to mention other people have not had this issue.
The steering was really heavy once the belt snapped. Way too heavy to drive it well, mostly attributed to a large amount of caster.
My plan of action is to remove the PS pump, inspect it to ensure that no debris went to the rack, replace the pump, add a proper cooler.
Re: Power steering belt snapped [Re: Spetz] #4531748
10/02/17 03:06 AM
10/02/17 03:06 AM
North Carolina
North Carolina
Thanks guys.
Sounds like a good plan. I think the root cause of your failure was the leaking pump suction line you already identified. That can and will lead to cavitation and the groaning you were hearing.
If you decide you want to underdrive it, a local starter/alternator shop should have a larger diameter pulley that would fit for cheap; no need to get anything billet or fancy.
Re: Power steering belt snapped [Re: Spetz] #4531795
10/02/17 06:17 AM
10/02/17 06:17 AM
Australia
Spetz Offline OP
Spetz  Offline OP
Australia
Would my PS pump be damaged from all this would you say?
It spins freely by hand.
Also how do I fix the leaks?
It is leaking from what seems to be the high pressure out line
