Optimal Compression Ratio for 91 Octane Fuel
by NICAT. 09/25/18 02:01 PM
Anyone used Amsoil DZF 0w40 ?
by ofelas. 09/25/18 01:33 PM
No more Turo - What now?
by dogememe. 09/25/18 01:08 PM
Military small arms ammo
by Camprunner. 09/25/18 12:03 PM
Pennzoil must not be selling , OR ?
by Kjmack. 09/25/18 11:51 AM
New black car, light swirls and water spots
by Redright9. 09/25/18 11:37 AM
Rust Belt vs Sun Belt cars
by ZZman. 09/25/18 11:33 AM
Enginer rebuilder's view of GDI intake issues
by Brigadier. 09/25/18 11:09 AM
Oil for '84 Caddy w/HT-4100
by StillLearning. 09/25/18 10:41 AM
Interesting video of diff with clear cover
by mrdctaylor. 09/25/18 10:15 AM
The death of American footbal
by Brigadier. 09/25/18 10:01 AM
Tire leaking from bead/rim
by Brybo86. 09/25/18 09:39 AM
2000 4Runner 3.4L
by ka9mnx. 09/25/18 08:59 AM
VW 508 Spec 0w20 Updates?
by Zee09. 09/25/18 08:36 AM
Laptop Recommendations
by buster. 09/25/18 08:24 AM
Mac OSX Mojave - vid card requirements
by OVERKILL. 09/25/18 08:05 AM
Age of first drive
by madRiver. 09/25/18 08:02 AM
Peppz, Jfa02, ibsfusion, Fearcat707, Perseo
66069 Registered Users
107 registered members (14Accent, 2010Civic, 16HC, 2009Edge, 2004tdigls, 9 invisible), 1,547 guests, and 38 spiders.
Topics290,996
Posts4,854,018
Members66,069
Most Online3,590
Jan 24th, 2017
1992 Accord. Timing belt and timing (off a tooth?) #4526587
09/26/17 10:29 AM
09/26/17 10:29 AM
Austin, Texas
RemingtonHill Offline OP
Austin, Texas
I might be overly paranoid - I just bought the car and for preventive measure I immediately had the timing belt and water pump, etc., replaced. Shortly after, apparently the the distributor failed (car ran when it was replaced). Afterwards it had an idle problem, occasionally felt like misfiring at idle.
Took it to another mechanic who fixed an over tensioned timing belt (tensioner installed incorrectly) and adjusted the timing. Car still misfired at idle and now I heard pinging/detonation. Took it back and they adjusted the timing completely again. I asked if they thought the timing belt was off a tooth but they seemed to feel that adjusting the "mechanical and electrical components" of the timing was the solution. I also had them check for vacuum leaks (apparently none).
I'm still getting the occasional moment of roughness in the idle, though its very, very diminished. No pinging anymore.
Did they compensate for a timing belt being off a tooth by adjusting the timing? Part of the adjustment was the distributor. It was centered, but now you see in the image that it's rotated quite a bit from center.
The occasional roughness might be air in the coolant, or a bad idle (air?) control valve. (from my online research) I'm going to check those things too.
Car runs smooth and fine. Would it possibly run well if the timing belt was off a tooth?
Thanks.
1988 Acura Legend ~171K miles - MaxLife ATF, MaxLife Synth Blend, Liqui-Moly MoS2
1992 Honda Accord ~151K miles - MaxLife ATF, PP High Mileage.
Re: 1992 Accord. Timing belt and timing (off a tooth?) [Re: RemingtonHill] #4526592
09/26/17 10:35 AM
09/26/17 10:35 AM
USA
mk378 Online content
mk378  Online Content
USA
Valve adjustment, a valve too tight will misfire at idle.
The test jumper must be in place to adjust spark timing. Make sure your mechanic has actual experience on old Hondas.
Re: 1992 Accord. Timing belt and timing (off a tooth?) [Re: mk378] #4526608
09/26/17 10:51 AM
09/26/17 10:51 AM
Maryville, TN
SubyRoo Offline
SubyRoo  Offline
Maryville, TN
+1 on this. Its normal for the valves to become tighter as they wear on these engines. I've never had the distributor adjusted full lock like that on any of the Hondas I've worked on when the timing is set correctly. The test jumper is located under the dash just jump it with a paper clip to set the timing. The timing marks will be on the flywheel should be a small rubber plug you remove to see them.
1999 Acura Integra GS-R
1998 Honda CR-V EX
Re: 1992 Accord. Timing belt and timing (off a tooth?) [Re: SubyRoo] #4526628
09/26/17 11:11 AM
09/26/17 11:11 AM
Maryville, TN
SubyRoo Offline
SubyRoo  Offline
Maryville, TN
Still thinking but it was too late to edit my last post. You could remove the inspection plug so you can see the timing marks on the flywheel bring cyl 1 to top dead center then pull the valve cover to see if the cam is in the proper position.
1998 Honda CR-V EX
Re: 1992 Accord. Timing belt and timing (off a tooth?) [Re: RemingtonHill] #4526645
09/26/17 11:21 AM
09/26/17 11:21 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
On very mild cams a tooth off will be barely noticeable. To get more top end power I retarded the cam on my 1.8L VW fox one tooth (easy to do) and I couldn't tell the difference.
Is the engine rated under 50 HP per litre?
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: 1992 Accord. Timing belt and timing (off a tooth?) [Re: RemingtonHill] #4526648
09/26/17 11:26 AM
09/26/17 11:26 AM
N.H, U.S.A.
N.H, U.S.A.
Coil-in-cap honda distributers had a spate of cracked/crazed caps on the early 1990's. I got one from the factory NEW and got another from the Honda dealer, My car wouldn't even start on humid weather days. Actually it was my wifes Honda civic 1.5? or 1.6. Throttle body SOHC..
What a piece of garbage. engine was worn at 50K miles - all the rockers were eaten up by the rocker shaft and you couldn't get a good valve clearance. Dealer would do NOTHING.
Nice, NICE! chassis though. No front mac strut GARBAGE then back when Mr S.Honda was alive.
Re: 1992 Accord. Timing belt and timing (off a tooth?) [Re: ARCOgraphite] #4526659
09/26/17 11:39 AM
09/26/17 11:39 AM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
This car doesn't have a coil-in-cap distributor. It has an external coil.
2006 Ford Ranger Sport
1992 Honda Accord EX
2004 Honda CR-V LX
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: 1992 Accord. Timing belt and timing (off a tooth?) [Re: SubyRoo] #4526662
09/26/17 11:42 AM
09/26/17 11:42 AM
Austin, Texas
Austin, Texas
Do you think having the distributor adjusted full lock should be a cause for concern?
Re: 1992 Accord. Timing belt and timing (off a tooth?) [Re: RemingtonHill] #4526669
09/26/17 11:46 AM
09/26/17 11:46 AM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
Tooth off on a timing belt is somewhat hard to do unless the installer hasn't a clue with they are doing. Tooth off on the distributor is another story and may explain why the adjuster is at full lock. Both should be easy enough to verify given some time and disassembly and a proper service manual.
Re: 1992 Accord. Timing belt and timing (off a tooth?) [Re: RemingtonHill] #4526677
09/26/17 11:58 AM
09/26/17 11:58 AM
Maryville, TN
SubyRoo Offline
SubyRoo  Offline
Maryville, TN
Well the distributor will only fit into to camshaft one way it has an offset notch to make sure of it. I could see the possibility of the cam gear being a tooth off when the belt was installed effectively advancing or retarding the timing depending on which way the cam turned. Its easy to tell if it is off if you don't mind taking of the valve cover. These engines have two marks on the cam gear that are set to 9:00 and 3:00 and the word "up" stamped into it so you don't get the gear upside down. If they did not use the jumper in the test plug under the dash it would try to constantly adjust while turning the dist. attempting to adjust the timing. Looking at the pic it looks like it is adjusted towards the radiator which I believe is retarding the timing.
1998 Honda CR-V EX
Re: 1992 Accord. Timing belt and timing (off a tooth?) [Re: RemingtonHill] #4526679
09/26/17 12:02 PM
09/26/17 12:02 PM
San Diego, California
Jim_Truett Offline
Jim_Truett  Offline
It's actually not that hard to be off a tooth. You can inspect it by removing the side cover on the head. Set the crank to TDC and see where the marks on the cam sprocket line up with the head. You will be off around 9 degrees on the cam if it is off a tooth IIRC. That would be one reason for the distributor to be maxed out like that. It is keyed to only be inserted one way. Can't be off a tooth. You can force it in 180* out, but that usually results in breakage. The other possibility is a lousy aftermarket distributor. In my experience they are all junk.
2008 F250 6.4 PowerStroke 43k
2005 Honda CR-V 193k
2005 Honda Pilot 235k
1963 Nova SS 84k
2015 Civic Si 23k
2013 Mahindra 3016HST 99hrs
Re: 1992 Accord. Timing belt and timing (off a tooth?) [Re: Jim_Truett] #4526698
09/26/17 12:29 PM
09/26/17 12:29 PM
Austin, Texas
Austin, Texas
It is a new aftermarket Amazon distributor I paid about $75 for, so it might very well be lousy, and I have considered that possibility (and advised the new mechanic of this as well hoping they considered it their diagnosis).
The original mechanic was one I found off next-door website. He very well could have installed the belt wrong. He's the one that screwed up the tensioner/tension.
Re: 1992 Accord. Timing belt and timing (off a tooth?) [Re: ARCOgraphite] #4526703
09/26/17 12:40 PM
09/26/17 12:40 PM
Austin, Texas
Austin, Texas
It's 2.2L and 125 HP.
Re: 1992 Accord. Timing belt and timing (off a tooth?) [Re: RemingtonHill] #4526824
09/26/17 03:06 PM
09/26/17 03:06 PM
California
Kool1 Offline
Kool1  Offline
California
I remember a Honda Accord came into the garage I worked at and the owner complained that the vehicle was low on power. He told me the timing belt was changed a few thousand miles ago. I saw that the distributor was set like yours where it was maxed out in adjustment. The owner told me that he brought the vehicle to a garage the day before and they tried adjusting the timing. I could see file marks where they ground away part of the distributor housing to advance the distributor further. I took off the timing cover and set the engine to TDC. It was apparent that the timing belt was a tooth off. I disassembled and realigned everything which allowed the distributor placement back in the normal range with timing set and the customer was good to go.
Re: 1992 Accord. Timing belt and timing (off a tooth?) [Re: Kool1] #4526850
09/26/17 03:47 PM
09/26/17 03:47 PM
Austin, Texas
Austin, Texas
It's hard for me to judge whether it's unusually low on power. My other car is a more powerful V6, but this Honda certainly isn't very fast by comparison, but performance is adequate albeit not as powerful as I remember my parents 1990 Accord EX was back in the early '90s, but that was a long time ago.
